MPB06-1C54-R-SMT-TR
MPB06-1C54-R-SMT-TR
    CUIDEVICES
    MPB06-1C54-R-SMT-TR
MPB06-1C54-R-SMT-TR 数据手册
Additional Resources: Product Page | 3D Model | PCB Footprint date 06/03/2021 page 1 of 4 SERIES: MPB06 │ DESCRIPTION: MINI PUSH BUTTON SWITCH FEATURES • single pole • surface mount • tape and reel SPECIFICATIONS parameter conditions/description min typ rated voltage rated current withstanding voltage units 28 Vdc 14 for 1 minute 500 contact resistance insulation resistance max 50 at 500 Vdc 500 operating force 150 actuator travel 250 -25 life 350 see material table RoHS yes PART NUMBER KEY MPB06 - 1 X XX - R - SMT - TR Base Number Circuit Type: C = SPDT: ON-(ON) cuidevices.com Actuator Height: 00 = Flush 33 = 3.3 mm 54 = 5.4 mm gf mm 80 20,000 flammability rating mΩ MΩ 1.1 operating temperature mA Vac °C cycles Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: MPB06 │ DESCRIPTION: MINI PUSH BUTTON SWITCH date 06/03/2021│ page 2 of 4 MECHANICAL DRAWING (SPDT CIRCUIT) units: mm tolerance: ±0.3 mm unless otherwise noted ITEM FLUSH ACTUATOR PLATING/COLOR 1 actuator PA46 (UL94V-0) white 2 housing PA46 (UL94V-0) white 3 terminals brass gold 4 bracket phosphor bronze tin 3.3 MM ACTUATOR EPOXY SEAL 8.60 MATERIAL Flatness tolerance ±0.1 3.30 4.50 EPOXY SEAL 8.60 1.40 1.20 4.70 1.50 Flatness tolerance ±0.1 5.08 5.08 4.50 DESCRIPTION 1.40 1.20 1.20 6.90 4.70 8.80 1.50 ACTUATOR POSITION ( ): MOMENTARY 1.20 6.90 8.80 15.70 NORMAL DOWN ON 2-3 (ON) 2-1 SCHEMATIC 15.70 5.4 MM ACTUATOR EPOXY SEAL 8.6 Flatness tolerance ±0.1 5.08 4.5 (3) (2) (1) 1.4 0.3 5.08 1.5 1.2 4.7 7 6.9 8.8 15.7 2.54 2.54 2.8 1.6 (1) (2) 1. 2- (3) 2.4 2.8 4 4.6 1 1.2 3.3 5 2.8 5.4 2.8 9.8 6 1.4 7 Recommended PCB Layout Top View cuidevices.com 1.2 2.54 Additional Resources: Product Page | 3D Model | PCB Footprint CUI Devices │ SERIES: MPB06 │ DESCRIPTION: MINI PUSH BUTTON SWITCH date 06/03/2021│ page 3 of 4 SOLDERABILITY parameter conditions/description min 255 Temperature (°C) reflow soldering 260 217 min 30 s 200 150 60 to 150 s 60 to 180 s 25 25˚C to Peak Temp (8 minutes) Time (sec) PACKAGING units: mm QTY: 500 pcs cuidevices.com typ max units 260 °C Additional Resources: Product Page | 3D Model CUI Devices │ SERIES: MPB06 │ DESCRIPTION: MINI PUSH BUTTON SWITCH | PCB Footprint date 06/03/2021│ page 4 of 4 REVISION HISTORY rev. 1.0 description date initial release 06/03/2021 The revision history provided is for informational purposes only and is believed to be accurate. CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website. CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may result from its use. CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. cuidevices.com
MPB06-1C54-R-SMT-TR 价格&库存
很抱歉,暂时无法提供与“MPB06-1C54-R-SMT-TR”相匹配的价格&库存,您可以联系我们找货
