ESD9X12VD
ESD9X12VD
1-Line, Uni-directional, Normal-Capacitor
Http//:www.willsemi.com
Transient Voltage Suppressors
Descriptions
The
ESD9X12VD
is
a
transient
voltage
suppressors (TVS) which provide a very high level
protection for sensitive electronic components that
SOD-923
may be subjected to electrostatic discharge (ESD). It is
designed to replace multilayer varistors (MLV) in
consumer equipments applications such as mobile
phone, notebook, PAD, STB, LCD TV etc.
The ESD9X12VD was past ESD transient voltage
up to ±30KV (contact) according to IEC61000-4-2 and
Pin configuration (Top view)
withstand peak current up to 3.5A for 8/20us pulse
according to IEC61000-4-5.
The ESD9X12VD
package.
Standard
is
available in
products
are
SOD-923
Pb-free
C
and
Halogen-free.
SOD-923
Features
C
= Device code
Marking
Working voltage
: 12V
Peak power (tp=8/20us)
: 84W
ESD protection
IEC61000-4-2 (Contact)
: ±30KV
IEC61000-4-2 (Air)
: ±30KV
Low leakage current
Small package
Order information
Device
Package
Shipping
ESD9X12VD-2/TR
SOD-923
10000/Tape&Reel
Applications
Mobile phone
PAD
Notebook
STB
LCD TV
Digital camera
Other electronics equipments
Will Semiconductor Ltd.
1
Jul, 2014 - Rev. 1.3
ESD9X12VD
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp=8/20us)
Ppk
84
W
Peak pulse current (tp=8/20us)
Ipp
3.5
A
ESD voltage IEC61000-4-2 air
±30
VESD
ESD voltage IEC61000-4-2 contact
Junction temperature
150
o
260
o
-55~150
o
TJ
Lead temperature
TL
Storage temperature
KV
±30
Tstg
C
C
C
Electronics characteristics (Ta=25 oC, unless otherwise noted)
Parameter
Symbol
Reveres maximum working voltage
VRWM
IR
Reveres breakdown voltage
VBR
Clamping voltage
VC
Junction capacitance
C
110
100
90
80
70
60
50
40
30
Min.
Typ.
VRWM=12V
IT=1mA
Max.
Unit
12
V
1
uA
13.5
V
Ipp=1A tp=8/20us
18
V
Ipp=3.5A tp=8/20us
24
V
F=1MHz, VR=0V
30
pF
100
90
Front times=1.25*( t90-t10) =8us
Peak Pulse Current (%)
Reveres leakage current
Condition
Duration=20us
10
10
15
30
Peak Pulse time (us)
35
30ns
tr=0.7~1ns
40
8/20us waveform
60ns
IEC61000-4-2 waveform
2
t
ESD9X12VD
Typical
o
characteristics (Ta=25 C, unless otherwise noted)
40
C - Junction capacitance (pF)
28
VC - Clamping voltage (V)
Pulse waveform: tp=8/20us
24
12
2
3
Fsignal =1MHz
Vsignal =50mVrms
35
30
25
2
3
4
Ipp - Peak pulse current (A)
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reveres voltage
5
1000
% of Rated power
Peak Pulse Power (W)
100
100
10
80
60
40
10
100
Pulse Duration(us)
1000
50
75
100
125
TA - Ambient temperature ( C)
Non-Repetitive Peak Pulse Power vs. Pulse time
Power derating vs. Temperature
ESD Clamping
ESD Clamping
(IEC61000-4-2 +8KV contact)
(IEC61000-4-2 -8KV contact)
150
o
3
ESD9X12VD
Package outline dimensions
SOD-923
Dimensions in millimeter
Symbol
Min.
Typ.
Max.
A
0.350
0.450
A1
0.000
0.050
b
0.150
0.270
c
0.180
D
0.550
0.600
0.650
E
0.900
1.000
1.100
E1
0.750
0.800
0.850
o
θ
7 Ref.
Recommend PCB Layout (Unit: mm)
0.40
0.90
0.30
0.60
4
0.30
很抱歉,暂时无法提供与“ESD9X12VD-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.35694
- 100+0.28836
- 300+0.25402
- 1000+0.22832
- 5000+0.20769
- 10000+0.19743
