MT6815
Magnetic Angle Position Encoder Sensor
Features and Benefits
■ Based on advanced AMR Sensing Technology
with 0°~360° Full Range Angle Sensing
■ Contactless Angle Measurement
■ Independent Output Interface: I2C, SPI,
Analog, ABZ, PWM and UVW
■ Incremental ABZ programmable binary and
decimal pulse-counts: 32, 48, 64, 128, 256, 512,
1024, 2048, 100, 200, 500, 1000, 2000, 2500
pulses per cycle
■ 14 bit Core Resolution
■ 12 bit DAC/PWM Resolution
■ User Programmable Resolution & Zero Index
Position
■ RoHS Compliant 2011/65/EU
■ SOP-8 or QFN-16 Package
General Description
The MagnTek rotary position sensor MT6815 is an
IC based on advanced AMR magnetic sensing
technology. A rotating magnetic field in the x-y
sensor plane delivers two sinusoidal output
signals indicating the angle (α) between the
sensor and the magnetic field direction. Within a
homogeneous field in the x-y plane, the output
signals are relatively independent of the physical
placement in the z direction.
The sensor is only sensitive to the magnetic field
direction as the sensing element output is
specially designed to be independent from the
magnet field strength. This allows the device to be
less sensitive to magnet variations, stray magnetic
fields, air gap changes and off-axis misalignment.
Applications
■ Absolute Linear Position Sensor
■ BLDC Motor Control
■ Robotics Control
■ Contactless Potentiometer
■ Power Tools
www.magntek.com.cn | Magnetic Tech Makes Magic Change
The incremental ABZ output mode is available in
this sensor series, making the chip suitable to
replace various optical encoders. The maximum
resolution is 2048 pulse/8192 steps per revolution
in binary mode and 2500 pulse/10000 steps per
revolution in decimal mode.
A standard I2C or SPI (3-Wire or 4-Wrie) interface
allows a host microcontroller to read the 14-bit
absolute angle position data from MT6815. The
absolute angle position is also provided as PWM
output or linear analog signal proportional to
VDD from a 12 bit DAC.
1
Rev 3.0
2019.11
MT6815
Table of Contents
Features and Benefits………….……………..……………...…………………………………….…….………1
Applications……………………………….……….…………………………………………………………….…….1
General Description……..………………..…………………………………….…………………………………1
1
Pin Configuration…………………………..…………………..……………………………..……….…….3
1.1
SOP-8 Package……...…………………….…………………...………………………………………………3
1.2 QFN-16 Package…….…………….…………………………………………………………………………….4
2
Function Diagram………….………………………………………………………….………………………5
3
Absolute Maximum Ratings……………………………………………………………………………..5
4
Electrical Characteristics…………………………………….……………………………………...……..6
5
Magnetic Input Specifications..………………………….……………………………………...……..7
6
Output Mode……………………………………………………………………………..…………..………….8
6.1
I/O Pin Configuration……..…………….…….…………………...……………………….…………….…8
6.2
Step, Direction and Index Output Signal (SDI Mode).…………………………..……..…..10
6.3
Quadrature A,B and Zero-Position Output Signal (ABZ Mode) …….…..…..10
6.4
UVW Output Mode……………………….………………………...……………………..……..….12
6.5
Analog Output Mode…………………….……………….………...……..…….……………..……..….13
6.6
Pulse Width Modulation (PWM) Output Mode………...………………………………….…15
6.7
I2C Interface………………..……………….……………………………...…….………………………….…16
6.7.1
I2C Timing Diagram……………..…..…...…….……………..…………………..…………..….16
6.7.2
I2C Read Angle Registers….….…………………………...………………………………….…17
6.7.3
I2C Burst Read………………….….…………………………...………………………………….…18
6.7.4
I2C Write………………………..….….…………………………...………………………………….…18
6.8
SPI Interface…………….……………………..……..………………………………………………….19
6.8.1
SPI Timing Diagram…………………….………………..…….…………………………………….20
6.8.2
4-Wire SPI………...………..………….…………………………...………………………………….…21
6.8.3
3-Wire SPI............………………………….………………..…….…………………………………….21
6.8.4
SPI Read Angle Register…………..………………………...………………………………….…22
7
Magnet Placement…………………..……..………….…………………………………………………………….24
8
Mechanical Angle Direction….……….….…….…………………………………….……………………….25
9
Package Information……..……………..….…….………………….……………………………………...……..26
9.1
SOP-8 Package………………….…..…………………………...……………………………………………26
9.2
QFN-16 Package…………..….…..………….……………………………………………………….……. 27
10 Copy Rights and Disclaimer…….……………………………………………………………….……...……..28
2
Rev 3.0
2019.11
MT6815
1.
Pin Configuration
1. 1 SOP-8 Package
Figure 1: Pin Configuration for SOP-8 Package
Pin List
Name
Type
Description
CSN
1
Digital Input
SPI/I2C Selection
HVPP
2
Analog Input
OTP Programming Supply or SPI/I2C Selection
OUT
3
Analog/Digital Output
Analog or PWM Output
VDD
4
Power Supply
3.3~5.0V Supply
A/U
5
Digital Input/output
Incremental Signal A/U or Speed or SPI MOSI, SDAT or I2C Data
B/V
6
Incremental Signal B/V or Direction or SPI MISO
Z/W
7
Digital Input
Incremental Signal Z/W or Index or SPI Clock or I2C Clock
GND
8
Ground
Ground
Family Members
Part Number
Description
MT6815CT
SOP-8 Package, Tube Pack (100pcs/Tube) or Tape & Reel Pack (3000pcs/Reel)
*SOP-8 Reflow Sensitivity Classification: MSL-3
3
Rev 3.0
2019.11
MT6815
1. 2 QFN-16 Package
Figure 2: Pin Configuration for QFN-16 Package
Pin List
Name
Type
Description
A
1
Incremental Signal A or Speed or SPI MOSI, SDAT or I2C Data
B
2
Incremental Signal B or Direction or SPI MISO
Z
3
Digital Input
Incremental Signal Z or Index or SPI Clock or I2C Clock
GND
4
Ground
Ground
CSN
5
Digital Input
SPI/I2C Selection
NC
6
NC
7
NC
8
NC
9
NC
10
OUT
11
HVPP
12
Analog Input
W
13
Incremental Output W
V
14
Incremental Output V or –B
U
15
Incremental Output U or –A
VDD
16
Power Supply
3.3~5.0V Supply
Family Members
Part Number
Description
MT6815QT
QFN-16 Package, Reel Pack (3000pcs/Reel)
*QFN-16 Reflow Sensitivity Classification: MSL-1
4
Rev 3.0
2019.11
MT6815
2. Functional Diagram
The MT6815 is manufactured in a CMOS standard process and uses advanced magnet sensing
technology to sense the magnetic field distribution across the surface of the chip. The integrated
magnetic sensing element array is placed around the center of the device and delivers a voltage
representation of the magnetic field at the surface of the IC.
Figure 3: Block Diagram
Figure 3 shows a simplified block diagram of the chip, consisting of the magnetic sensing element
modeled by two interleaved Wheatstone bridges to generate cosine and sine signals, gain stages,
analog-to-digital converters (ADC) for signal conditioning, and a digital signal processing (DSP) unit
for encoding. Other supporting blocks such as LDO, etc. are also included.
3. Absolute Maximum Ratings (Non-Operating)
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage
to the device. These are stress ratings only. Functional operation of the device at these or any other
conditions beyond those indicated under “Operating Conditions” is not implied. Exposure to
absolute maximum rating conditions for extended periods may affect device reliability.
Name
Min.
Max.
Unit
DC Voltage at Pin VDD
-0.5
7
V
DC Voltage at Pin HVPP
-0.5
8
V
Storage Temperature
-55
150
Operating Temperature
-40
125
Electrostatic Discharge (HBM)
±3.0
KV
Electrostatic Discharge (CDM)
±1.5
KV
5
Rev 3.0
2019.11
MT6815
4. Electrical Characteristics
Operation conditions: Ta=-40 to 125℃, VDD=3.0~5.5V unless otherwise noted.
Symbol
Parameter
Conditions/Notes
Min.
Typ.
Max.
Unit
VDD
Supply Voltage
3.0
3.3~5.0
5.5
V
HVPP
Supply Voltage
6.75
7.0
7.25
V
Idd
Supply Current
6.0
9.0
mA
LSB
Resolution (ABZ or SDI Mode)
N Steps per Cycle
INL
Integral Non-Linearity
Note (1)
±1
±1.5
DNL
Differential Non-Linearity (ABZ
or SDI Mode), Figure 4
≤10 bit
±0.1
LSB
>10bit
±0.03
TN
Transition Noise
(ABZ or SDI Mode)
25℃
0.011
°rms
Hyst
Hysteresis (ABZ Mode)
≤12bit
0.5
LSB
>12bit
0.176
TPwrUp
Power-Up Time
VDD Ramp
很抱歉,暂时无法提供与“MT6815CT-AKD”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+15.68160
- 10+15.23880
- 30+14.95800
- 100+14.51520
