Nov 2014
SE30P12
P-Channel Enhancement-Mode MOSFET
Revision: A
Features
General Description
Advanced trench technology to provide
excellent RDS(ON), low gate charge and low
operation voltage. This device is suitable for
using as a load switch or in PWM applications.
Simple Drive Requirement
Small Package Outline
Surface Mount Device
For a single MOSFET
VDS = -30V
RDS(ON) = 11.5mΩ @ VGS=-10V
RDS(ON) = 18mΩ @ VGS=-4.5V
Pin configurations
See Diagram below
Absolute Maximum Ratings
Parameter
Symbol
Rating
Units
Drain-Source Voltage
VDS
-30
V
Gate-Source Voltage
VGS
±20
V
Drain Current
Total Power Dissipation
Continuous
Pulsed
@TA=25℃
Operating Junction Temperature Range
ShangHai Sino-IC Microelectronic Co., Ltd.
ID
-11
-50
A
PD
2
W
TJ
-55 to 150
1.
SE30P12
Electrical Characteristics
Symbol
(TJ=25℃ unless otherwise noted)
Parameter
Test Conditions
Min
Typ
-30
-33
Max
Units
OFF CHARACTERISTICS (Note 2)
BVDSS
Drain-Source Breakdown Voltage
ID=-250μA, VGS=0 V
IDSS
Drain to Source Leakage Current
VDS= -24V, VGS=0V
IGSS
Gate-Body Leakage Current
VGS= 20V
Gate Threshold Voltage
VDS= VGS, ID=-250μA
-1
VGS=-10V, ID=-10A
VGS(th)
RDS(ON)
Static Drain-Source On-Resistance
2
VGS=-4.5V, ID=-7A
V
-5
μA
100
nA
-1.5
-3
V
11.5
15
mΩ
18
25
mΩ
DYNAMIC PARAMETERS
Ciss
Input Capacitance
VGS=0V,
Coss
Output Capacitance
Crss
Reverse Transfer Capacitance
VDS=-15V,
f=1MHz
5270
pF
945
pF
745
pF
100
nC
14.5
nC
23
nC
14
ns
76.5
ns
SWITCHING PARAMETERS
Qg
Total Gate Charge 2
VGS=-10V,
VDS=-15V,
Qgs
Gate Source Charge
Qgd
Gate Drain Charge
td(on)
Turn-On Delay Time
VGS=-10V, VDS=-15V,
td(off)
Turn-Off Delay Time
RGEN=3Ω, RL=1Ω
td(r)
Turn-On Rise Time
16.5
ns
td(f)
Turn-Off Fall Time
37.5
ns
ID=-15A
Thermal Resistance
Symbol
RθJA
Parameter
Typ
Max
Units
Junction to Ambient (t≦10s)
26
40
℃/W
2.
SE30P12
Typical Characteristics
3.
SE30P12
4.
SE30P12
Package Outline Dimension
SOP-8
The SINO-IC logo is a registered trademark of ShangHai Sino-IC Microelectronics
Co., Ltd.
© 2005 SINO-IC - Printed in China - All rights reserved.
SHANGHAI SINO-IC MICROELECTRONICS CO., LTD
Add: Building 3, Room 3401-03, No.200 Zhangheng Road,
ZhangJiang Hi-Tech Park, Pudong, Shanghai 201203, China
Phone:
+86-21-33932402
33932403
33932405 33933508 33933608
Fax: +86-21-33932401
Email: szrxw002@126.com
Website: http://www.sino-ic.net
5.
很抱歉,暂时无法提供与“SE30P12”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.19297
- 50+0.94803
- 150+0.84305
- 500+0.71205
- 2500+0.58428
- 5000+0.54929
