ABS210
ABS210
    TDD(台冠电子)
    ABS210
ABS210 数据手册
ABS201 THRU ABS210 2A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: PINNING • Glass Passivated Chip Junction • Reverse Voltage - 100 to 1000 V • Forward Current - 2 A • High Surge Current Capability • Designed for Surface Mount Application PIN DESCRIPTION 1 Input Pin(~) 2 Input Pin(~) 3 Output Anode(+) 4 Output Cathode(-) MECHANICAL DATA • Case: ABS/LBF • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight: 88mg 0.0031oz 3 — 4 2 1 ABS/LBF Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols ABS201 ABS202 ABS204 ABS206 ABS208 ABS210 Units Maximum Repetitive Peak Reverse Voltage V RRM 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 100 200 400 600 800 1000 V Parameter Average Rectified Output Current at T c = 115 °C Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load (JEDEC Method) IO 2.0 A I FSM 55 A Forward Voltage per element @I F =2.0A VF 1.0 V Maximum DC Reverse Current at Rated DC Blocking Voltage @ T A =25 °C @ T A =125 °C IR 5.0 100 μA Cj 25 pF RθJA RθJC 60 16 °C/W T j , T stg -55 ~ +150 °C Typical Junction Capacitance(Note1) Typical Thermal Resistance(Note2) Operating and Storage Temperature Range Note: 1. Measured at 1MHz and applied reverse voltage of 4 V D.C. 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. Page 3 of 3 ABS201 THRU ABS210 Fig.2 Typical Reverse Characteristics Instaneous Reverse Current( μA) Average Rectified Output Current (A) Fig.1 Average Rectified Output Current Derating Curve 2.4 2.0 1.6 1.2 0.8 0.4 Resistive or Inductive Load 0.0 25 50 75 100 125 150 175 100 TJ=125°C 10 1.0 TJ=25°C 0.1 CaseTemperature (°C) 0.1 pulse with 300μs 1% duty cycle 1.0 1.5 2.0 Junction Capacitance (pF) Instaneous Forward Current (A) 1.0 0.5 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance TJ=25°C 0.01 0.0 20 percent of Rated Peak Reverse Voltage (%) Fig.3 Typical Instaneous Forward Characteristics 10 00 100 TJ=25℃ 10 1 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 60 50 40 30 20 10 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles Page 3 of 3 ABS201 THRU ABS210 PACKAGE OUTLINE Plastic surface mounted package; 4 leads ABS/LBF ∠ALL ROUND ∠ALL ROUND C A a L1 L d B e D e E ABS/LBF mechanical data A C D E B d e max 1.5 0.22 5.3 4.6 6.5 4.2 0.7 min 1.3 0.15 5.0 4.3 6.1 3.8 0.5 max 59 8.7 209 181 256 165 28 min 51 5.9 197 169 240 150 20 UNIT mm mil The recommended mounting pad size L L1 a 0.95 0.6 0.2 5° 37 24 4 Marking Type number 6.2 244 2.0 79 Marking code ABS201 4.0 157 1.0 39 ∠ Unit : mm (mil) ABS201 ABS202 ABS202 ABS204 ABS204 ABS206 ABS206 ABS208 ABS208 ABS210 ABS210 ABSxx Page 3 of 3
ABS210 价格&库存
很抱歉,暂时无法提供与“ABS210”相匹配的价格&库存,您可以联系我们找货
