PTS10L100
PTS10L100
    PFC(节能)
    DO-27(DO-201AA)
    特性:超低正向电压 (SLVF®) 降。 可靠的高温操作。 最软、快速开关能力。 150℃ 工作结温。 无铅涂层,符合 RoHS 标准。应用:电源应用
PTS10L100 数据手册
PTS10L100 PFC Device Corporation 10A 100V HPTR® Schottky Rectifier Major ratings and characteristics Characteristics Values Units IF(AV) Rectangular Waveform 10 A VRRM 100 V TJ Operating Junction Temperature -40 to +150 PTS10L100 o C Features DO-201AD   Super Low Forward Voltage ( SLVF® ) Drop Reliable High Temperature Operation    Softest, fast switching capability 150oC Operating Junction Temperature Lead Free Finish, RoHS Compliant Typical Applications Device optimized for ultra-low forward voltage drop to maximize efficiency in Power Supply applications Apr-2018 Version 4.2 1/5 www.pfc-device.com Characteristics PTS10L100 1. Characteristics Maximum Ratings Characteristics ( TA = 25 oC unless otherwise specified ) Parameter Symbol Values Units 100 Volts Io 10 Amps IFSM 150 Amps IRRM 1 DC Blocking Voltage VRM Working Peak Reverse Voltage VRWM Peak Repetitive Reverse Voltage VRRM Average Rectified Forward Current (Rated VR-20Khz Square Wave) - 50% duty cycle Peak Forward Surge Current - 1/2 60hz Peak Repetitive Reverse Surge Current (2uS-1Khz) Typical Thermal Resistance Maximum Rate of Voltage Change ( at Rated VR ) RθJc 22 dv/dt 10000 TJ - 40 to +150 TSTG - 40 to +150 Operating Junction Temperature Storage Junction Temperature Parameter Instantaneous Reverse Current C/W V/uS o C ( TA = 25 oC unless otherwise specified ) Electrical Characteristics Instantaneous Forward Voltage Amps o Test Conditions Symbol o IF = 10 A At VRM TJ = 25 C TJ = 125 oC TJ = 25 oC o TJ = 125 C VF* IR* Typ. Max. Units ---- 0.78 ---- 0.67 ---- 100 uA ---- 25 mA Volts * Pulse width < 300 uS, Duty cycle < 2% Version 4.2 2/5 www.pfc-device.com Characteristics PTS10L100 2. Characteristics Curves Ratings and Characteristics Curves ( TA = 25℃ unless otherwise specified ) 200 10 Peak Forward Surge Current (A) If, Average Forward Current (A) 12 8 6 4 2 0 0 25 50 75 100 Tc, Case Temp (oC) 125 100 50 0 1 150 Figure 1: Current Derating, Case 10 Number of Cycles at 60 Hz 100 Figure 2: Maximum Repetitive Surge Current 100000 100 10000 10 Ir, Reverse Current (uA) If, Instantaneous Forward Current (A) 150 Tj=150℃ Tj=125℃ 1 Tj=75℃ Tj=150℃ Tj=125℃ 1000 Tj=75℃ 100 10 Tj=25℃ 1 Tj=25℃ 0 100 200 300 400 500 600 700 Vf, Instantaneous Forward Voltage (mV) 800 Figure 3: Typical Forward Voltage 0 0 10 20 30 40 50 60 70 VR, Reverse Voltage (Volts) 80 90 100 Figure 4: Typical Reverse Current Capacitance (pF) 1000 100 10 0 1 10 100 Reverse Voltage (V) Figure 5: Typical Junction Capacitance Version 4.2 3/5 www.pfc-device.com Characteristics PTS10L100 3. Marking information Top Marking Rule PTS10L100 = Product Type Marking Code YYWW = Date Code YY = Last two digits of year WW = Week code S = Series Number PTS10L100 H = Halogen Free (N/A = common molding compound) YYWWSH 4. Package information Package Outline Dimensions millimeters DO-201AD Dim. A1 A2 B C D Min. Max. 25.4 typ. 25.4 typ. 7.20 9.50 1.20 1.30 4.80 5.30 All Dimensions in millimeter Version 4.2 4/5 www.pfc-device.com Characteristics PTS10L100 5. Ordering information Part Number Package Delivery mode PTS10L100 DO-201AD 800 pieces / ammo-pack Note: For Halogen Free molding compound, add "H" suffix to part number above. Mechanical   Molder Plastic: UL Flammability Classification Rating 94V-0 Device Weight : 0.04 ounces (1.1 grams) – DO-201AD PFC Device Corp reserves the right to make changes without further notice to any products herein. PFC Device Corp makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does PFC Device Corp assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. “Typical” parameters which may be provided in PFC Device Corp data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typical” must be validated for each customer application by customer’s technical experts. PFC Device Corp does not convey any license under its patent rights nor the rights of others. PFC Device Corp products are not designed, intended, or authorized for use as components in systems intended for surgical implant into the body, or other applications intended to support or sustain life, or for any other application in which the failure of the PFC Device Corp product could create a situation where personal injury or death may occur. Should Buyer purchase or use PFC Device Corp products for any such unintended or unauthorized application, Buyer shall indemnify and hold PFC Device Corp and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that PFC Device Corp was negligent regarding the design or manufacture of the part. Version 4.2 5/5 www.pfc-device.com
PTS10L100 价格&库存
很抱歉,暂时无法提供与“PTS10L100”相匹配的价格&库存,您可以联系我们找货
