MURS140A-MURS160A
Surface Mount Rectifiers
VOLTAGE RANGE: 400 --- 600 V
CURRENT: 1.0 A
Features
Low cost
Low leakage
Low forward voltage drop
High current capability
Easily cleaned with Alcohol,Isopropanol
and similar solvents
The plastic material carries U/L recognition 94V-0
SMA/DO-214AC
0. 181( 4. 60)
0. 161( 4. 10)
0. 108( 2. 75)
0. 096( 2. 45)
0. 063(1.60)
0. 051(1.30)
0. 209( 5. 30)
0. 193( 4. 90)
Mechanical Data
0. 012(0.30)
0. 006(0.15)
Case:JEDEC DO-214AC,molded plastic
Terminals: Solderable per
MIL- STD-202,Method 208
Polarity: Color band denotes cathode
Weight: 0.002 ounces,0.064 grams
Mounting position: Any
0.096(2.45)
0.078(2.00)
0. 059( 1. 50)
0. 035( 0. 90)
0.008(0.20)
0. 002(0.05)
Dimensions in inches and(millimeters)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS
Ratings at 25 ambient temperature unless otherwise specified.
Single phase,half wave,60 Hz,resistive or inductive load. For capacitive load,derate by 20%.
MURS140A
MURS160A
UNITS
Maximum recurrent peak reverse voltage
VRRM
400
600
V
Maximum RMS voltage
VRMS
VDC
420
600
V
Maximum DC blocking voltage
280
400
Maximum average forw ard
rectified current
@TL=110
V
IF(AV)
1.0
A
IFSM
35
A
t rr
50
ns
Peak forw ard surge current
8.3ms single half-sine-w ave
superimposed on rated load
@TJ=125
Typical reverse recovery time (Note1)
Maximum reverse current
at rated DC blocking voltage
@TA=25
@T A=125
IR
Maximum instantaneous forw ard
VF
voltage at 1.0 A
Typical thermal resistance
(Note2)
Operating junction temperature range
Storage temperature range
RθJL
5.0
150
A
1.25
V
13
/W
TJ
- 55 ---- + 150
TSTG
- 55 ---- + 150
NOTE: 1. Measured with I F =0.5A, I R=1A, I rr=0.25A.
2. Junction to ambient.
ht t p : //
Revision:20170701-P1
www.lgesemi .c o m
mail:lge@lgesemi.com
MURS140A-MURS160A
Ratings AND Charactieristic Curves
10
TJ=25
Pulse Width=300uS
4
2
1.0
AMPERES
0.4
0.2
0.1
0.06
0.04
0.02
0.01
0.6
0.8
1.0
1.2
1.4
1.6
1.8
2.0
INSTANTANEOUS REVERSE LEAKAGE CURRENT
100
FIG.2 -- TYPICAL REVERSE LEAKAGE
CHARACTERISTICS
1000
100
O
TJ=125 C
10
O
TJ=75 C
1
TJ=25OC
0.1
0.01
60
80
100
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FIG.3 -- PEAK FORWARD SURGE CURRENT
FIG.4 -- FORWARD DERATING CURVE
AVERAGE FORWARD CURRENT
AMPERES
INSTANTANEOUS FORWARD VOLTAGE,VOLTS
45
40
TJ =125
8.3ms Single Half
Sine-Wave
35
AMPERES
INSTANTANEOUS FORWARD CURRENT
FIG.1 -- TYPICAL FORWARD CHARACTERISTIC
30
25
10
5
1
2
4
8 10
20 40
60 80 100
1.2
1.0
0.8
0.6
0.4
Single Phase
Half Wave 60H Z
Resistive or
Inductive Load
0.2
50
NUMBER OF CYCLES AT 60Hz
100
125
150
175
LEAD TEMPERATURE,
PACKAGE
SPQ/PCS
CARTON
SPQ/PCS
CARTON
SIZE/CM
CARTON
GW/KG
CARTON
NW/KG
SMA
5000/REEL
80000
36X30.6X31
12.00
11.00
ht t p : //
75
www.lgesemi .c o m
很抱歉,暂时无法提供与“MURS160A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.57553
- 50+0.47288
- 150+0.42156
- 500+0.38307
- 2500+0.29345
- 5000+0.27800
