SS34AHE THRU SS320AHE
Reverse Voltage - 40 to 200 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
Metal silicon junction,majority carrier conduction
For surface mounted applications
1
2
Low power loss,high efficiency
For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
Top View
Simplified outline SMAHE and symbol
Mechanical Data
PINNING
PIN
Case : JEDEC SMAHE Molded plastic body
Terminals : Solderable per MIL-STD-750,Method 2026
Weight : 0.0010 ounce, 0.030grams
DESCRIPTION
1
Cathode
2
Anode
Mechanical Data
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
SS34AHE
SS36AHE
SS310AHE
SS315AHE
SS320AHE
SYMBOLS
MDD
SS34
MDD
SS36
MDD
SS310
MDD
SS315
MDD
SS320
UNITS
VRR
RMM
VRMS
40
28
60
42
150
105
200
140
VDC
40
60
100
70
100
150
200
V
V
V
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
IF(AV)
3.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
80
A
Maximum instantaneous forward voltage at 3.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
IR
TA=25℃
TA=100℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction temperature range
Storage temperature range
CJ
0.55
0.5
10
180
0.70
0.85
0.3
5.0
150
TJ
100
-55 to +150
TSTG
-55 to +150
RJA
V
0.95
mA
pF
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 3.81X3.81cm copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
Reverse Voltage - 20 to 200 Volts
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
3.5
10
4
10
3
10
2
TJ=100°C
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μ
A
Average Forward Current (A)
3.0
TJ=75°C
40V
60~200V
101
TJ=25°C
Case Temperature (°C)
40
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
500
TJ=25°C
Junction Capacitance (pF)
Instaneous Forward Current (A)
10
1.0
40V
60V
100V
150~200V
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
100
50
40V
60~200V
10
1.8
0.1
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
°C /
W)
60
40
Sine Wave
(JEDEC Method)
00
Number of Cycles at 60Hz
100
Transient Thermal Impedance(
Peak Forward Surage Current (A)
80
10
100
Fig.6- Typical Transient Thermal Impedance
100
1
10
Reverse Voltage (V)
Instaneous Forward Voltage (V)
8.3 ms Single Half
1
200
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A2
Page :2
SS3AHE THRU SS320AHE
Packing information
∠ALL ROUND
∠ALL ROUND
A
C
HE
E
e
g
pad
E
d
Top View
mil
g
Bottom View
A
C
D
E
HE
d
e
g
h
max
1.20
0.35
4.10
2.70
5.20
1.90
3.05
1.50
1.2
min
0.90
0.20
3.70
2.30
4.80
1.70
2.85
1.30
1.0
max
47
13.8
161
106
205
75
120
59
47
min
35
7.9
145
90
189
67
112
51
39
UNIT
mm
h
pad
D
12°
The recommended mounting pad size
5.2
3.2
(126)
2.0
(79)
(205)
1.6
(63)
1.3
(51)
Unit: m m
( mi l)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“SS34AHE”相匹配的价格&库存,您可以联系我们找货
