FM25F01B-SO-T-G
FM25F01B-SO-T-G
    FUDANMICRO(复旦微电子)
    SOP8
    FM25F01B-SO-T-G
FM25F01B-SO-T-G 数据手册
FM25F01B 1M-BIT SERIAL FLASH MEMORY Datasheet Aug.2020 FM25F01B 1M-BIT SERIAL FLASH MEMORY Ver.1.0 Datasheet 1 INFORMATION IN THIS DOCUMENT IS INTENDED AS A REFERENCE TO ASSIST OUR CUSTOMERS IN THE SELECTION OF SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCT BEST SUITED TO THE CUSTOMER'S APPLICATION; THEY DO NOT CONVEY ANY LICENSE UNDER ANY INTELLECTUAL PROPERTY RIGHTS, OR ANY OTHER RIGHTS, BELONGING TO SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD OR A THIRD PARTY. WHEN USING THE INFORMATION CONTAINED IN THIS DOCUMENTS, PLEASE BE SURE TO EVALUATE ALL INFORMATION AS A TOTAL SYSTEM BEFORE MAKING A FINAL DECISION ON THE APPLICABILITY OF THE INFORMATION AND PRODUCTS. PURCHASERS ARE SOLELY RESPONSIBLE FOR THE CHOICE, SELECTION AND USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN, AND SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD ASSUMES NO LIABILITY WHATSOEVER RELATING TO THE CHOICE, SELECTION OR USE OF THE SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS AND SERVICES DESCRIBED HEREIN.UNLESS EXPRESSLY APPROVED IN WRITING BY AN AUTHORIZED SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD REPRESENTATIVE, SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS ARE NOT RECOMMENDED, AUTHORIZED OR WARRANTED FOR USE IN MILITARY, AIR CRAFT, SPACE, LIFE SAVING, OR LIFE SUSTAINING APPLICATIONS, NOR IN PRODUCTS OR SYSTEMS WHERE FAILURE OR MALFUNCTION MAY RESULT IN PERSONAL INJURY, DEATH, OR SEVERE PROPERTY OR ENVIRONMENTAL DAMAGE. FUTURE ROUTINE REVISIONS WILL OCCUR WHEN APPROPRIATE, WITHOUT NOTICE. CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD SALES OFFICE TO OBTAIN THE LATEST SPECIFICATIONS AND BEFORE PLACING YOUR PRODUCT ORDER. PLEASE ALSO PAY ATTENTION TO INFORMATION PUBLISHED BY SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD BY VARIOUS MEANS, INCLUDING SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD HOME PAGE (HTTP://WWW.FMSH.COM/). PLEASE CONTACT SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD LOCAL SALES OFFICE FOR THE SPECIFICATION REGARDING THE INFORMATION IN THIS DOCUMENT OR SHANGHAI FUDAN MICROELECTRONICS GROUP CO., LTD PRODUCTS. Trademarks Shanghai Fudan Microelectronics Group Co., Ltd name and logo, the “复旦” logo are trademarks or registered trademarks of Shanghai Fudan Microelectronics Group Co., Ltd or its subsidiaries in China. Shanghai Fudan Microelectronics Group Co., Ltd, Printed in the China, All Rights Reserved. FM25F01B 1M-BIT SERIAL FLASH MEMORY Ver.1.0 Datasheet 2 1. Description The FM25F01B is a 1M-bit (128K-byte) Serial Flash memory, with advanced write protection mechanisms. The FM25F01B supports the standard Serial Peripheral Interface (SPI), Dual/Quad I/O as well as 2-clock instruction cycle Quad Peripheral Interface(QPI). They are ideal for code shadowing to RAM, executing code directly from Dual/Quad SPI (XIP) and storing voice, text and data. The FM25F01B can be programmed 1 to 256 bytes at a time, using the Page Program instruction. It is designed to allow either single Sector/Block at a time or full chip erase operation. The FM25F01B can be configured to protect part of the memory as the software protected mode. The device can sustain a minimum of 100K program/erase cycles on each sector or block. 2. Features  High Reliability – Endurance: 100,000 program/erase cycles – Data retention: 20 years  Green Package – 8-pin SOP (150mil) – 8-pin TSSOP – 8-pin USON(2x3mm) – All Packages are RoHS Compliant and Halogenfree 3. Packaging Type SOP 8 (150mil) CS# DO(DQ1) 1 2 8 7 WP#(DQ2) 3 4 6 5 VSS VCC HOLD#(DQ3) CLK DI(DQ0) TSSOP 8  1Mbit of Flash memory – 32 uniform sectors with 4K-byte each – 2uniform blocks with 64K-byte each or – 4uniform blocks with 32K-byte each – 256 bytes per programmable page  Wide Operation Range – 2.3V~3.6Vsingle voltage supply – Industrial temperature range  Serial Interface – Standard SPI: CLK, CS#, DI, DO, WP# – Dual SPI: CLK, CS#, DQ0, DQ1, WP# – Quad SPI: CLK, CS#, DQ0, DQ1, DQ2, DQ3 – QPI: CLK, CS#, DQ0, DQ1, DQ2, DQ3 – Continuous READ mode support – Allow true XIP(execute in place) operation  High Performance – Max FAST_READ clock frequency: 100MHz – Max READ clock frequency: 50MHz – Typical page program time: 0.5ms – Typical sector erase time: 80ms – Typical block erase time: 250/400ms – Typical chip erase time: 1s  Low Power Consumption – Typical Deep Power Down current:
FM25F01B-SO-T-G 价格&库存
很抱歉,暂时无法提供与“FM25F01B-SO-T-G”相匹配的价格&库存,您可以联系我们找货
