6.35
H
Ø0.75
GND
GND
2.54
1.50
0.37
Solder Area
0.79
Card Inserted
Component Outline
Without Card
(Normally Close)
GND
GND
CD
CD
Electrical
Voltage rating: 30V AC/DC
Current Rating: 1.0 Amp AC/DC Max.
Contact Resistance:
Signal contact: 100 mΩ Max.
CD to GND: 200 mΩ Max.
Dielectric Withstanding Voltage:500V AC (60 Sec Min. )
Insulation Resistance: 1000 MΩ Min.@500V DC
Ordering Grid
7x 14.50
2x 0.75
C
4x 1.50
Keep Out Area
SIM8066
6
1
14
01
A
Request Samples
and Quotation
No. of Contacts
6
Switch
1 = With
B
Packing Options
A = Tape & Reel
Mechanical & Environmental
Operating Temperature: -40°C to +85°C
Durabillity : 5,000 cycles
(1500pcs per reel)
Locating Peg
01 = With
Profile Height
14 = 1.44mm
7x 0.45
2x 13.09
Part Number
Product Description
SIM8066
Nano SIM Card Connector
Push-Push Type, SMT, 6Pin, 1.44mm Profile
Drawing Date
19th March 2021
By
Detail
3
4
Material
Housing&Slide : High Temperature Thermoplastic,
UL94V-0, Black
Contact Terminal: Copper Alloy
Metallic Shell: Stainless Steel
Spring: SWP-B
Link: Stainless Steel
Plating
Contact :
Contact Area: Gold Flash over Nickel
Soldering Tail: Gold Flash over Nickel
Shell:
Spring&Link: Cleaning
Circuit Diagram for Card Detect Switch
8.50
2
0.70
8.50
13.00
Recommended PCB Layout
2x Ø0.60
2x 12.75
2.14
(Viewed from Component Side - Tolerance:±0.05mm)
D
1
Specifications
6.80
1.85
E
A
0.84
2.55
3.21
1.25
12.00
1.25
6.77
4.20 ref. Card eject position
C3 C7 C2 C6 C1 C5 CD
1.20
0.47±0.10
12.29
9.02
2.05
GND
GND
1.50 ref. Card lock position
2x 2.00
F
13.72
G
0.95
1.44
0.65 ref. Push stroke position
1.67
2.10
0.95
1.14
0.80
4.83
1.27
3.40
0.10
1.27
Revision
Date
5
CC
Drawing
Release
A2
15/03/22
Tolerances (Except as Noted)
Length
Angle
X.X ± 0.30
X.XX ± 0.20
X.XXX ± 0.10
± 2°
Units:
Metric (mm)
C
3rd Angle Projection
6
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/3
H
25.00mm Mini
G
15.00mm Micro
12.30mm Nano
D
8.80mm Nano
E
12.00mm Micro
15.00mm Mini
F
C1----->VCC
C2----->RST
Nano SIM
C3----->CLK
C5----->GND
C6----->Vpp
C7----->I/O
Micro SIM
Mini SIM
C
Reference
B
Part Number
Product Description
SIM8066
Drawing Date
A
19th March 2021
By
Detail
1
2
3
4
Revision
Date
5
CC
Drawing
Release
A2
15/03/22
Length
Angle
X.X ± 0.30
X.XX ± 0.20
X.XXX ± 0.10
± 2°
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/3
Pull out direction
H
2.00
16.00
G
Pull out direction
F
Empty15 pcs
24.00
11.50
4.00
Empty15 pcs
Product1500 pcs
Cover Tape
Pcs/Reel
Void Filler
Reels/Carton Pcs/Carton
1500
10
15000
Ø100
Ø330
E
D
Carton
PE Foam
Adhesive Tape
340
Vacuum Bag
10 Reels
C
Label
35
B
35
1500pcs x 10=15000pcs
Part Number
Product Description
SIM8066
Drawing Date
A
19th March 2021
By
Detail
1
2
3
4
Revision
Date
5
CC
Drawing
Release
A2
15/03/22
Length
Angle
X.X ± 0.30
X.XX ± 0.20
X.XXX ± 0.10
± 2°
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
3/3
SIM8066-6-1-14-01-A 价格&库存
很抱歉,暂时无法提供与“SIM8066-6-1-14-01-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+12.81390
- 10+10.63590
- 30+9.45010
- 100+8.09490
- 500+7.50200
- 国内价格
- 1+11.43720
- 10+9.49320
- 30+8.43480
- 100+7.22520
- 500+6.69600
- 国内价格 香港价格
- 1+11.102031+1.44048
- 10+9.4271410+1.22317
- 25+8.8390125+1.14686
- 50+8.4160250+1.09198
- 100+8.01339100+1.03973
- 250+7.51103250+0.97455
- 500+7.15225500+0.92800
