R141004000
R141004000
    RADIALL
    BNC
R141004000 数据手册
TECHNICAL DATA SHEET 1/2 R141.004.000 STRAIGHT PLUG CLAMP TYPE Series : BNC CABLE 2.6/50+75 All dimensions are in mm. . pn . ao COMPONENTS BODY CENTER CONTACT OUTER CONTACT INSULATOR GASKET OTHERS PARTS - MATERIALS BRASS BRASS PTFE SILICONE RUBBER BRASS - PLATING (µm) NICKEL 2 GOLD 0.5 OVER NICKEL 2 - NICKEL 2 - Issue : 0324 M In the effort to improve our products, we reserve the right to make changes judged to be necessary. TECHNICAL DATA SHEET 2/2 R141.004.000 STRAIGHT PLUG CLAMP TYPE Series : BNC CABLE 2.6/50+75 PACKAGING SPECIFICATION Standard 100 Unit ‘W’ option Other Contact us QAE 06-02 - - CABLE ASSEMBLY ELECTRICAL CHARACTERISTICS Impedance 50 Ω Frequency 0-4 GHz VSWR 1.3 + 0,0000 x F(GHz) Maxi Insertion loss 0.115 √F(GHz) dB Maxi RF leakage -( 57 - F(GHz)) dB Maxi Voltage rating 500 Veff Maxi Dielectric withstanding voltage 1500 Veff mini Insulation resistance 5000 MΩ mini MECHANICAL CHARACTERISTICS Center contact retention Axial force – Mating end Axial force – Opposite end Torque 27.2 N mini 27.2 N mini NA N.cm mini Stripping a b c d e f mm 4,00 2,00 9,00 2,00 5,00 0,00 Assembly instruction : Clamp 01 Recommended cable(s) RG 316 RG 188 RG 187 RG 179 KX 22A Characteristics indicated on this data sheet are those that can be achieved with the highest performance cable. Intrinsic limitations of the cable may diminish the performance of the assembly Cable retention - pull off - torque 110 N mini NA N.cm TOOLING Recommended torque Mating Panel nut Clamp nut A/F clamp nut NA NA 450 11,0000 Mating life Weight 500 Cycles mini 19,0300 g N.cm N.cm N.cm mm Part Number . . . OTHER CHARACTERISTICS - ENVIRONMENTAL Operating temperature Hermetic seal Panel leakage Description Hexagon -65/+165 ° C NA Atm.cm3/s NA Issue : 0324 M In the effort to improve our products, we reserve the right to make changes judged to be necessary.
R141004000 价格&库存
很抱歉,暂时无法提供与“R141004000”相匹配的价格&库存,您可以联系我们找货
