R125222000
R125222000
    RADIALL
    SMA
R125222000 数据手册
Technical Data Sheet STRAIGHT JACK SOLDER TYPE CABLE .085 PAGE 1/2 ISSUE 09-09-16J SERIES SMA PART NUMBER R125222000 All dimensions are in mm. . pn . ao COMPONENTS Body Center contact Outer contact Insulator Gasket Others parts - MATERIALS STAINLESS STEEL. BERYLLIUM COPPER PTFE - PLATING (m) GOLD 0.5 OVER NICKEL 2 GOLD 1.3 OVER NICKEL2 - - This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary. Technical Data Sheet STRAIGHT JACK SOLDER TYPE CABLE .085 PAGE 2/2 ISSUE 09-09-16J SERIES SMA PART NUMBER R125222000 PACKAGING Standard 100 Unit Contact us Other Contact us ELECTRICAL CHARACTERISTICS Impedance Frequency 1.07 + VSWR Insertion loss RF leakage -( Voltage rating Dielectric withstanding voltage Insulation resistance 50 0-18 0,0080 0.03 90 335 750 5000 ENVIRONMENTAL  GHz x F(GHz) Maxi F(GHz) dB Maxi - F(GHz)) dB Maxi Veff Maxi Veff mini M mini NA NA NA °C Atm.cm3/s SPECIFICATION 4051 019 - - MECHANICAL CHARACTERISTICS Center contact retention Axial force – Mating End Axial force – Opposite end Torque -65/+105 NA NA Operating temperature Hermetic seal Panel leakage CABLE ASSEMBLY Stripping mm N mini N mini N.cm mini a 3,17 b 0 c 0 d 0 e 0 f 0 Assembly instruction: Solder 01 Recommended torque Mating Panel nut Clamp nut A/F clamp nut Mating life Weight NA NA NA 6,0000 500 1,5630 N.cm N.cm N.cm mm Recommended cable(s) RG 405 KS 1 Cycles mini g Characteristics indicated on this data sheet are those that can be achieved with the highest performance cable. Intrinsic limitations of the cable may diminish the performance of the assembly Cable retention - pull off - torque 130 NA N mini N.cm TOOLING Part Number R282120010 R282051000 R282063000 R282730043 R282740000 R282744220 R282862060 R282914010 R282915010 R282744010 Description SMA TOOLBOX STRIPPING TOOL POINTER GAUGE INSULATOR MOUNTING TOOL SOLDERING MOUNTING SOLDERING POSITIONER(CENTER CONTACT) CONTROL GAUGE DIELETRIC RECESS GAUGE DIELECTRIC RECESS TOOL SOLDERING POSITIONER (BODY) Hexagon OTHER CHARACTERISTICS - This document contains proprietary information and such information shall not be disclosed to any third party for any purpose whatsoever or used for manufacturing purposes without prior written agreement from Radiall. The data defined in this document are given as an indication, in the effort to improve our products; we reserve the right to make any changes judged necessary.
R125222000 价格&库存
很抱歉,暂时无法提供与“R125222000”相匹配的价格&库存,您可以联系我们找货
R125222000
    • 1+176.90400
    • 200+68.46120
    • 500+66.05280
    • 1000+64.86480
