MS252010-4R7M-W
MS252010-4R7M-W
    COILMX(迈翔)
    SMD,2.5x2mm
    功率电感 SMD,2.5x2x1mm
MS252010-4R7M-W 数据手册
SPECIFICATION FOR APPROVAL 产品规格承认书 Unibody Inductor 一体成型功率电感 CUSTOMER. MODEL NO. MS252010-SERIES CUSTOMER'S PART NO. LILE NO. DATE. 2021-7-6 REVISION. A/0 CUSTOMER APPROVE DATE: DRAWING DRAWN BY CHECK BY APPROVAL BY DATE: 深圳市迈翔科技有限公司 SHENZHEN MOTTO TECHNOLOGY Co., Ltd 香港瑞德科技有限公司 黄冈市迈翔电子有限公司 Motto Technology park, niu e ling village no#214 xintian,nghua Town, Guanlan Street, Longhua District,Shenzhen TEL: +86 0755-8948751~2 89487610 Fax: +86 0755-61624574 IATF16949 / ISO9001 / ISO14000 Http://www.coilmx.com E-mail: sales@mottotech.com 1/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MS252010-SERIES REVISION A/0 DATE 2021-7-6 REVISIONS REW PROJECT CHANGE DESCRIPTION Date 2/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MS252010-SERIES REVISION A/0 DATE 2021-7-6 1.PRODUCT DIMENSION UNIT:mm 2.ELECTRICAL REQUIREMENTS PARAMETER L0 (Μh) inductance@(0A) DCR (mΩ) Isat (A) Idc (A) 1MHz, 0.1V TYP. MAX. MAX. MAX. MS252010-R47M-W 0.47±20 % 35 46 3.5 3.1 MS252010-1R0M-W 1.0±20 % 60 78 2.7 2.5 MS252010-1R5M-W 1.5±20 % 90 108 2.1 1.9 MS252010-2R2M-W 2.2±20 % 130 156 1.9 1.5 MS252010-3R3M-W 3.3±20 % 195 228 1.5 1.2 MS252010-4R7M-W 4.7±20 % 250 300 1.3 1.0 MS252010-6R8M-W 6.8±20 % 415 516 1.1 0.76 MS252010-100N-W 10±30 % 590 689 1.00 0.68 3.CHARACTERISTICS (1). All test data is based on 25℃ ambient. (2). Idc current(A)that will cause an approximate △T40℃ (3). Isat current(A)that will cause L0 to drop approximately 30%Typ (4). Operating temperature range: -55℃~+125℃ (5).The part temperature (ambient + temp rise)should not exceed 125℃ under worst case operating conditions. circuit design, component.PWB trace size and thickness,airflow and other cooling provision all affect the part temperature. Part temperature should be verified in the den application 4.SPECIAL REQUEST (1)NO Marking on top of the body. 3/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MS252010-SERIES REVISION A/0 DATE 2021-7-6 5.PRODUCT IDENTIFICATION XX XXXXXX ① ② ①、 Product Symbol - XXX ③ X ④ ②、 Dimensions ④、 Tolerance: M±20%, N±30%. X ⑤ ③、 Inductance ⑤ 、Material 6.ELECTRICAL SCHEMATICS 7.APPLICATION (1)Low profile,high current power supplies. (2)Battery powered devices. (3)DC/DC converters in distributed power systeMS. (4)DC/DC converters for field programmable gate array. 8.FEATURES (1)ROHS compliant. (2)Super low resistance,ultra high current rating. (3)high performance(I sat)realized by metal dust core. (4)Frequency Range:up to 1MHZ. 9.RECOMMENDED PCB LAYOUT H 2 S 1.2 M 2.8 4/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MS252010‐R47M MS252010‐1R5M MS252012‐3R3M MS252012‐6R8M MS252010-SERIES REVISION A/0 DATE 2021-7-6 MS252010‐1R0M MS252010‐2R2M MS252012‐4R7M MS252012‐100N 5/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MS252010-SERIES REVISION A/0 DATE 2021-7-6 11.可靠性Reliability 项目Item 规格与需求 Specification and Requirement 沾锡面积不得小于95%上锡面 可焊性 Solder a bility test 振动测试 Vibration test 冲击测试 Shock test 冷热冲击 Thermal shock Terminals area must have 95% min solder coverage 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break 感值变化:不超过±5% 且无破裂等机械损伤产生 Inductance change: Within±5% Without mechanical damage such as break 测试方法Test Method 上锡升温曲线Solder heat proof: (1) 预热:160±10℃持续90s Preheating: 160±10℃ for 90 seconds (2) 恒温时段:245±5℃持续2±0.5s Retention time: 245±5℃ for 2±0.5 seconds (1) 振动频率(10Hz 55Hz 10Hz)60s为一个周期 Vibration frequency: (10Hz to 55Hz to 10Hz) in 60 seconds as a period (2) 振动时间 Vibration time: 三维正交坐标系每个方向振动(周期) 循环2小时 Period cycled for 2 hours in each of 3 mutual perpendicular directions (3) 振幅 Amplitude: 1.5 mm Max (1) 最大振幅 Peak value: 100G (2) 脉冲波长 Duration of pulse: 11MS (3) 三维正交坐标系每个方向正负方向冲击3次 Times in each positive and negative direction of 3 mutual perpendicular directions (1)重复以上100个循环Repeat 100 cycle as follow (-55±2℃,30±3分钟) 室温5分钟 (-55±2℃,30±3 minutes) Room temperature,5 minutes (+125±2℃,30±3分钟) 室温5分钟 (+125±2℃,30±3 minutes) Room temperature,5 minutes (2)恢复:测试于标准条件下恢复48+4/-0小时 (参考注释1) Recovery:48+4/-0 hours of recovery under the standard condition after the test. (see Note1) 感值变化:不超过±5% 耐高温测试 且无破裂等机械损伤产生 High temperature life Inductance change: Within±5% Without test mechanical damage such as break (1)环境条件:85±2℃ Environment condition : 85±2℃ 应用电流:额定电流 Applied current: Rated current (2)持续时间:1000+4/-0 小时(参考注释1) Duration:1000+4/-0 hours (see Note1) 感值变化:不超过±5% 耐湿测试 且无破裂等机械损伤产生 Humidity Resistance Inductance change: Within±5% Without mechanical damage such as break (1)环境条件:60±2℃ Environment condition : 60±2℃ 湿度:90~95% Humidity:90~95% 应用电流:额定电流 Applied current: Rated current (2)持续时间:1000+4/-0 小时(参考注释1) Duration:1000+4/-0 hours (see Note1) 感值变化:不超过±5% 低温存放测试Low 且无破裂等机械损伤产生 temperature life test Inductance change: Within±5% Without mechanical damage such as break (1)存储温度 Store temperature -55±2℃下存放 1000+4/-0 小时 -55±2℃for total 1000+4/-0 hours 感值变化:不超过±5% 高温存放测试High 且无破裂等机械损伤产生 temperature life test Inductance change: Within±5% Without mechanical damage such as break (1)存储温度 Store temperature +125±2℃下存放 1000+4/-0 小时 +125±2℃for total 1000+4/-0 hours 6/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MS252010-SERIES REVISION A/0 DATE 2021-7-6 12、包装 Packaging 12.1、尺寸 Dimensions 12.1.1 包装料带尺寸 Tape packaging dimensions D 0 P P2 T B0 W F E P0 D1 K0 A0 W A0 B0 K0 P F E D0 P0 T 8.0 ±0.10 2.8 ±0.05 2.35 ±0.05 1.35 ±0.05 4.0 ±0.10 3.5 ±0.1 1.75 ±0.10 1.50 ±0.10 4.0 ±0.10 0.25 ±0.05 12.1.2 卷轴尺寸 Reel dimensions 项目 尺寸(mm) A 330.0 ± 2.0 B 100.0 ± 1.0 C 13.0 ± 1.0 D 1.9 ± 0.4 W 30.4 Max W1 24.4 ± 1.0 项目 数量(PCS) 1卷轴 3000 1内箱 12000 1外箱 36000 12.1.3 外箱尺寸Carton dimensions 7/8 深圳市迈翔科技有限公司 CUSTOMER MODEL NO. FILE NO. PART NO. MS252010-SERIES REVISION A/0 DATE 2021-7-6 Reflow curve ※ Reflow Profile 1. Reflow Soldering Method 2. Soldering iron method :350±5℃ Max.3 seconds. 8/8
MS252010-4R7M-W
物料型号:MS252010-SERIES
器件简介:文档描述的是一体成型功率电感,由深圳市迈翔科技有限公司生产。
引脚分配:文档中没有提供具体的引脚分配图,但提供了电感的尺寸信息。
参数特性: - 产品尺寸:最大10mm x 0.6mm x 0.2mm - 电气要求:包括电感值(LO)、直流电阻(DCR)、饱和电流(Isat)和额定直流电流(Idc),具体数值依据不同型号而变化。
功能详解: - 所有测试数据基于25°C环境温度。 - Idc电流是指导致电感值下降大约40°C的电流值。 - Isat电流是指导致电感值下降大约30%的典型电流值。 - 工作温度范围:-55°C至+125°C。 - 部件温度(环境温度+温升)在最坏情况下的操作条件下不应超过125°C。
应用信息: - 低剖面、高电流电源。 - 电池供电设备。 - 分布式电源系统中的DC/DC转换器。 - 现场可编程门阵列的DC/DC转换器。
封装信息:文档中提供了产品的尺寸信息和推荐的PCB布局,但没有提供封装的详细描述。
可靠性测试:包括可焊性测试、振动测试、冲击测试、冷热冲击测试、耐高温测试、耐湿测试、低温存放测试和高温存放测试,所有测试均要求电感值变化不超过±5%,且无破裂等机械损伤。
包装信息:提供了包装料带尺寸、卷轴尺寸和外箱尺寸的详细信息。
回流焊接曲线:提供了回流焊接方法和烙铁焊接方法的参数和步骤。
MS252010-4R7M-W 价格&库存
很抱歉,暂时无法提供与“MS252010-4R7M-W”相匹配的价格&库存,您可以联系我们找货
