MHCH201610A-1R0M-Q8
MHCH201610A-1R0M-Q8
    CHILISIN(奇力新)
    IND_2X1.6MM_SM
    功率电感 SMD,2x1.6x1mm
MHCH201610A-1R0M-Q8 数据手册
RoHS & Halogen Free & REACH Compliance. SPECIFICATION FOR APPROVAL Customer: : Customer P/N: : Drawing No: Quantity: : 0 Pcs. Date : 2015/03/02 MHCH201610A-SERIES : Chilisin P/N: SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED 奇力新電子股份有限公司 Chilisin Electronic sCorp No. 29, Alley 301, Tehhsin Rd., Hukou,Hsinchu 303, Taiwan TEL +886-3- 599-2646 FAX +886-3- 599-9176 E-mail sales@chilisin.com.tw http //www.chilisin.com.tw : : : : 奇力新電子( 奇力新電子(河南) 河南)有限公司 Chilisin Electronics (Henan) Co., Ltd. XiuWu Xian, industry gathering area JiaoZuo, Henan China Postal Code:454350 TEL:+86-391-717-0682 FAX:+86-391-717-0666 Drawn by 陳瑞揚 ryan.chen 東莞奇力新電子有限公司 Chilisin Electronics (Dongguan) Co., Ltd. No. 78, Puxing Rd., Yuliangwei Administration Area, Qingxi Town, Dongguan City, Guangdong,China TEL +86-769-8773-0251~3 FAX +86-769-8773-0232 E-mail cect@chilisin.com.tw : : : 奇力新電子( 奇力新電子(蘇州) 蘇州)有限公司 Chilisin Electronics (Suzhou) Co., Ltd. No.143,Song Shan Rd., Suzhou New District, Suzhou,China Postal Code:215129 TEL:+86-512-6841-2350 FAX:+86-512-6841-2356 E-mail suzhou@chilisin.com.tw Checked by 邱明傑 Joseph.Chiu Approved by 陳瑞揚 ryan.chen YG15300020 MHCH201610A Series Specification 1 Scope: This specification applies to Molding power inductors 2 Part Numbering: 3 Rating: Operating Temperature: -40℃~125℃(Including self - temperature rise) Storage Temperature: -40℃~125℃(after PCB) -5℃~35℃,Humidity 45%~85%(before PCB) 4 Marking: 5 Standard Testing Condition Temperature Humidity Unless otherwise specified Ordinary Temperature(15 to 35 ) Ordinary Humidity(25 to 85% RH) ℃ In case of doubt 20±2 60 to 70 % RH ℃ MHCH201610A Series Specification 6 Configuration and Dimensions: 7 Electrical Characteristics: Inductance (uH ) Test Freq. Irms(A) Max.(Typ) Isat(A) Max.(Typ) MHCH201610A-R24M-Q8 0.24 2MHz,0.2V 3.9(4.8) MHCH201610A-R33M-Q8 0.33 2MHz,0.2V 4.7(5.1) MHCH201610A-R47M-Q8 0.47 2MHz,0.2V MHCH201610A-R68M-Q8 0.68 MHCH201610A-1R0M-Q8 1 MHCH201610A-1R5M-Q8 MHCH201610A-2R2M-Q8 Part No. NOTE: 1.Operating temperature range RDC(mΩ) Max.(Typ) Tolerance (±%) 5.6(7.0) 27(21) 20 5.3(6.0) 23(17.5) 20 3.5(4.2) 3.9(4.8) 42(33) 20 2MHz,0.2V 2.7(3.4) 3.2(4.0) 56(43) 20 2MHz,0.2V 2.5(3.1) 2.9(3.6) 65(53) 20 1.5 2MHz,0.2V 2.3(2.7) 2.5(2.8) 85(75) 20 2.2 2MHz,0.2V 1.8(2.2) 2.4(2.7) 135(112) 20 -40℃~125℃(Including self - temperature rise) 2.Isat for Inductance drop 30% from its value without current. ℃ temprature rise from 25℃ ambient. ℃ ambient 3.Irms for a 40 4.All test data is referenced to 25 MHCH201610A Series Specification 8 MHCH201610A Series 8.1 Construction: 8.2 Material List: MHCH252010A Series Specification 9 Reliability of Molding Power Inductor 1-1.Mechanical Performance No Item 1-1-1 Flexure Strength Test Method Specification The forces applied on the right Test device shall be soldered on the substrate conditions must not damage Substrate Dimension: 100x40x1.6mm the terminal electrode and the Deflection: 2.0mm metal body Keeping Time: 30sec 1-1-2 Vibration Test device shall be soldered on the substrate Oscillation Frequency: 10 to 55 to 10Hz for 1min Amplitude: 1.5mm Time: 2hrs for each axis (X, Y & Z), total 6hrs 1-1-3 Resistance to Soldering Heat Appearance: No damage Pre-heating: 150 , 1min More than 75% of the terminal.Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free) electrode should be covered Solder Temperature: 260±5 with solder. Immersion Time: 10±1sec Inductance: within ±20% of initial value 1-1-4 Solder ability The electrodes shall be at Pre-heating: 150 , 1min least 95% covered with new Solder Composition: Sn/Ag3.0/Cu0.5(Pb-Free) solder coating Solder Temperature: 245±5 Immersion Time: 4±1sec ℃ ℃ ℃ ℃ 1-1-5 Terminal Strength Test No split termination Chip Chip F F Test device shall be soldered on the substrate, then apply a force in the direction of the arrow. Force : 5N Keeping Time: 10±1sec Mounting Pad Mounting Pad 1-2.Environmental Performance No Item 1-2-1 Temperature Cycle 1-2-2 Humidity Resistance 1-2-3 High Temperature Resistance 1-2-4 Low Temperature Resistance Test Method Specification Appearance: No damage Inductance:within±20% of initial value One cycle: Step Time (min) Temperature ( ) 1 -40±3 30 2 25±2 2 3 125±3 30 4 25±2 2 Total: 100cycles Measured after exposure in the room condition for 24hrs Temperature: 60±2 Relative Humidity: 90 ~ 95% / Time: 500hrs Measured after exposure in the room condition for 12hrs Temperature: 85±3 Relative Humidity: 0% / Time: 500hrs Measured after exposure in the room condition for 12hrs Temperature: -40±3 Relative Humidity: 0% / Time: 500hrs Measured after exposure in the room condition for 12hrs ℃ ℃ ℃ ℃ MHCH252010A Series Specification MHCH201610A Series Specification 10 Test Data for Pre-production Samples Chilisin P/N: MHCH201610A-1R0M-Q8 Measured Item L0 (uH) Spec Customer 1±20% Suggest L1 (uH)Max. RDC (mΩ)Max. A m/m B m/m C m/m D m/m L0*0.7 65(53typ) 2.0±0.2 1.6±0.2 1.0 Max. 0.5±0.3 Test Freq. Isat=0A 2MHz 0.2V Isat=2.9A 2MHz 0.2V 1 0.95 0.759 49.1 2.12 1.75 0.96 0.46 2 0.901 0.718 49.7 2.12 1.74 0.98 0.48 3 0.937 0.733 48.8 2.12 1.75 0.96 0.48 4 0.935 0.731 49.5 2.12 1.75 0.98 0.5 5 0.959 0.738 49.4 2.12 1.74 0.94 0.46 X 0.9364 0.7358 49.3 2.12 1.746 0.964 0.476 R 0.058 0.041 0.9 0 0.01 0.04 0.04 6 7 8 9 10 11 12 13 14 15 Customer Sample Test Instrument L : Agilent E4991A/HP4287A+16197A RDC : CHEN HWA 502BC / HP4338B Isat : Agilent E4980A+HP42841A Irms : Agilent 6641 SYSTEM DC POWER SUPPLY Appearance and Dimensions: SPEC : Refer to Item 6 Test Method : Visual Inspection and Measured with Slide Calipers. Test Conditions: Unless Otherwise Specified Temperature Ordinary Temperature (15 to 35 ) Humidity Ordinary Humidity (25 to 85 %RH) ℃ Downloaded From Oneyac.com ln Case of Doubt ℃ 20 ± 2 60 to 70 %RH MHCH201610A Series Specification 11 Packaging: 11.1 Packaging -Cover Tape The force for tearing off cover tape is 10 to 100 grams in the arrow direction. 11.2 Packaging Quantity 11.3 Reel Dimensions MHCH201610A Series Specification 11 Packaging: 11.4 Tape Dimensions in mm 12 Recommended Land Pattern: 13 Note: 1. Please make sure that your product has been evaluated and confirmed against your specifications when our product is mounted to your product. 2. Do not knock nor drop. 3. All the items and parameters in this product specification have been prescribed on the premise that our product is used for the purpose,under the condition and in the environment agreed upon between you and us. You are requested not to use our product deviating from such agreement. 4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950) 5.After manufacturing process, there might be slight irregular shape on the edge of the products, and it's a normal phenomenon that can be neglectable.
MHCH201610A-1R0M-Q8 价格&库存
很抱歉,暂时无法提供与“MHCH201610A-1R0M-Q8”相匹配的价格&库存,您可以联系我们找货
