SMD1206-050
SMD1206-050
    JKSEMI(金开盛)
    SMD1206-050
SMD1206-050 数据手册
JSMD 1206 Series Surface Mount PTC Devices Performance Specification Maximum Model V max Imax Time To Trip Resistance I hold I trip Pd @25°C @25°C Typ. Current Time R i min R1max (V dc) (A) (A) (A) (W) (A) (Sec) () () JSMD1206-005 30.0 100 0.05 0.15 0.4 0.25 1.50 3.600 50.000 JSMD1206-005/60 60.0 100 0.05 0.15 0.4 0.25 1.50 3.600 50.000 JSMD1206-010 30.0 100 0.10 0.25 0.4 0.50 1.00 1.600 15.000 JSMD1206-010/60 60.0 100 0.10 0.25 0.4 0.50 1.00 1.600 15.000 JSMD1206-012 30.0 100 0.12 0.29 0.4 0.50 1.00 1.600 15.000 JSMD1206-012/60 60.0 100 0.12 0.29 0.4 0.50 1.00 1.600 15.000 JSMD1206-020 24.0 100 0.20 0.46 0.6 8.00 0.08 0.350 2.700 JSMD1206-020/30 30.0 100 0.20 0.46 0.6 8.00 0.08 0.350 2.700 JSMD1206-025 16.0 100 0.25 0.50 0.6 8.00 0.08 0.350 2.500 JSMD1206-025/24 24.0 100 0.25 0.50 0.6 8.00 0.08 0.350 2.500 JSMD1206-035 16.0 100 0.35 0.75 0.6 8.00 0.10 0.250 1.300 JSMD1206-035/30 30.0 100 0.35 0.75 0.6 8.00 0.10 0.250 1.300 JSMD1206-050 6.0 100 0.50 1.00 0.6 8.00 0.10 0.150 0.700 JSMD1206-050/8 8.0 100 0.50 1.00 0.6 8.00 0.10 0.150 0.700 JSMD1206-050/16 16.0 100 0.50 1.00 0.6 8.00 0.10 0.150 0.700 JSMD1206-050/24 24.0 100 0.50 1.00 0.6 8.00 0.10 0.150 0.700 JSMD1206-075 8.0 100 0.75 1.50 0.6 8.00 0.20 0.090 0.500 JSMD1206075/13.2 13.2 100 0.75 1.50 0.6 8.00 0.20 0.090 0.500 JSMD1206-075/16 16.0 100 0.75 1.50 0.6 8.00 0.20 0.090 0.500 JSMD1206-100 6.0 100 1.00 1.80 0.6 8.00 0.30 0.055 0.270 JSMD1206-100/8 8.0 100 1.00 1.80 0.6 8.00 0.30 0.055 0.270 JSMD1206-100/12 12.0 100 1.00 1.80 0.6 8.00 0.30 0.055 0.270 JSMD1206-110 6.0 100 1.10 2.20 0.6 8.00 0.30 0.050 0.250 JSMD1206-110/8 8.0 100 1.10 2.20 0.6 8.00 0.30 0.050 0.250 JSMD1206-110/12 12.0 100 1.10 2.20 0.6 8.00 0.30 0.050 0.250 JSMD1206-150 6.0 100 1.50 3.00 0.8 8.00 0.30 0.040 0.130 JSMD1206-150/8 8.0 100 1.50 3.00 0.8 8.00 0.30 0.040 0.130 JSMD1206-175 6.0 100 1.75 3.50 0.8 8.00 0.50 0.020 0.090 JSMD1206-200 6.0 100 2.00 3.50 0.8 8.00 1.50 0.018 0.080 V max = Maximum operating voltage device can withstand without damage at rated current (Imax). I max = Maximum fault current device can withstand without damage at rated voltage (Vmax). I hold = Hold Current. Maximum current device will not trip in 25°C still air. I trip = Trip Current. Minimum current at which the device will always trip in 25°C still air. Pd = Power dissipation when device is in the tripped state in 25°C still air environment at rated voltage. Ri min/max = Minimum/Maximum device resistance prior to tripping at25°C. R1max = Maximum device resistance is measured one hour post reflow. CAUTION : Operation beyond the specified ratings may result in damage and possible arcing and flame. http:// www.jksemi.com 2016-12-01 版次: c JSMD 1206 Series Surface Mount PTC Devices Environmental Specifications Test Conditions Resistance change Passive aging +85°C, 1000 hrs. ±5% typical Humidity aging +85°C, 85% R.H. , 168 hours ±5% typical Thermal shock +85°C to -40°C, 20 times ±33% typical Resistance to solvent MIL-STD-202,Method 215 No change Vibration MIL-STD-202,Method 201 No change Ambient operating conditions : - 40 °C to +85 °C Maximum surface temperature of the device in the tripped state is 125 °C Agency Approval and Environmental Complianc Agency File Number Regulation Standard UL E217453 2002/95/EC TUV pending EN14582 Thermal Derading Chart Recommended Hold Current(A) at Ambient Temperature(°C) Model Ambient Operation Temperature -40°C -20°C 0°C 25°C 40°C 50°C 60°C 70°C 85°C JSMD1206-005 0.074 0.066 0.058 0.05 0.0425 0.0375 0.035 0.03 0.0275 JSMD1206-010 0.148 0.132 0.116 0.10 0.085 0.075 0.07 0.06 0.055 JSMD1206-012 0.18 0.16 0.14 0.12 0.10 0.09 0.08 0.07 0.07 JSMD1206-020 0.30 0.26 0.23 0.20 0.17 0.15 0.14 0.12 0.11 JSMD1206-025 0.37 0.33 0.29 0.25 0.22 0.20 0.17 0.15 0.12 JSMD1206-035 0.50 0.45 0.40 0.35 0.30 0.27 0.24 0.21 0.15 JSMD1206-050 0.71 0.64 0.57 0.50 0.42 0.39 0.35 0.31 0.25 JSMD1206-075 1.14 1.01 0.88 0.75 0.65 0.59 0.54 0.49 0.41 JJSMD1206-100 1.45 1.31 1.15 1.00 0.84 0.77 0.69 0.61 0.48 JSMD1206-110 1.60 1.45 1.30 1.10 0.95 0.80 0.72 0.66 0.55 JSMD1206-150 2.18 1.94 1.72 1.50 1.28 1.17 1.06 0.96 0.77 JSMD1206-075 1.14 0.88 0.75 0.65 0.54 0.49 0.41 JSMD1206-200 2.88 2.34 2.00 1.74 1.42 1.17 0.93 http:// www.jksemi.com 1.01 2.63 0.59 1.58 2016-12-01 版次: c JSMD 1206 Series Surface Mount PTC Devices Thermal Derating Curve Percentageof DeratedCurrent Derating Curves for JSMD1206 Series 160 140 120 100 80 60 40 20 0 -40 -20 0 20 40 60 80 Temperature (°C) Average Time-Current Curve Average Time Current Curves 100 0.05A 0.10A 0.12A Time In Seconds 10 0.20A 0.25A 0.35A 1 0.50A 0.75A 1.00A 0.1 1.10A 1.50A 2.00A 0.01 0.1 1 10 Current InAmperes Soldering Parameters TP 20~40 S TP 260 Critical Zone Ramp-up TL to TP TL 217 tL 60~150 s Tsmax 200 Tsmin Ramp-down 150 ts Preheat 60~180 s 25 t 25°C to peak Time http:// www.jksemi.com 2016-12-01 版次: c JSMD 1206 Series Surface Mount PTC Devices Profile Feature Pb-Free Assembly Average Ramp-Up Rate(Ts max to T p) 3℃/second mac. Preheat -Temperature Min(Ts min) 150℃ -Temperature Max(Ts max) 200℃ -Time(Ts min to Ts max) 60~180 seconds Time maintained above: -Temperature(TL) 217℃ -Time(tL) 60~150 seconds Peak Temperature(Tp) 260℃ Ramp-Down Rate 6℃/second max. Time 25℃ to Peak Temperature 8 minutes max Storage Condition 0℃~35℃,≤70%RH Recommended reflow methods: IR, vapor phase oven, hot air oven, N2 environment for lead-free Recommended maximum paste thickness is 0.25mm Devices can be cleaned using standard industry methods and solvents. Note 1:All temperature refer to topside of the package, measured on the package body surface. Note 2: If reflow temperatures exceed the recommended profile, devices may not meet the performance requirements. Physical Dimensions(mm.) Model A B C D E Min. Max. Min. Max. Min. Max. Min. Min. JSMD1206-005 3.00 3.50 1.50 1.80 0.60 1.10 0.15 0.10 JSMD1206-005/60 3.00 3.50 1.50 1.80 0.60 1.10 0.15 0.10 JSMD1206-010 3.00 3.50 1.50 1.80 0.60 1.10 0.15 0.10 JSMD1206-010/60 3.00 3.50 1.50 1.80 0.60 1.10 0.15 0.10 JSMD1206-012 3.00 3.50 1.50 1.80 0.60 1.10 0.15 0.10 JSMD1206-012/60 3.00 3.50 1.50 1.80 0.60 1.10 0.15 0.10 JSMD1206-020 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 JSMD1206-020/30 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 JSMD1206-025 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 JSMD1206-025/24 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 JSMD1206-035 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 JSMD1206-035/30 3.00 3.50 1.50 1.80 0.40 0.90 0.15 0.10 JSMD1206-050 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 JSMD1206-050/8 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 http:// www.jksemi.com 2016-12-01 版次: c JSMD 1206 Series Surface Mount PTC Devices JSMD1206-050/16 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 JSMD1206-050/24 3.00 3.50 1.50 1.80 0.35 0.85 0.15 0.10 JSMD1206-075 3.00 3.50 1.50 1.80 0.30 0.80 0.15 0.10 JSMD1206075/13.2 3.00 3.50 1.50 1.80 0.30 0.80 0.15 0.10 JSMD1206-075/16 3.00 3.50 1.50 1.80 0.30 0.80 0.15 0.10 JSMD1206-100 3.00 3.50 1.50 1.80 0.40 0.80 0.15 0.10 JSMD1206-100/8 3.00 3.50 1.50 1.80 0.40 0.80 0.15 0.10 JSMD1206-100/12 3.00 3.50 1.50 1.80 0.40 0.80 0.15 0.10 JSMD1206-110 3.00 3.50 1.50 1.80 0.40 0.80 0.15 0.10 JSMD1206-110/8 3.00 3.50 1.50 1.80 0.40 0.80 0.15 0.10 JSMD1206-110/12 3.00 3.50 1.50 1.80 0.40 0.80 0.15 0.10 JSMD1206-150 3.00 3.50 1.50 1.80 0.50 1.20 0.15 0.10 JSMD1206-150/8 3.00 3.50 1.50 1.80 0.50 1.20 0.15 0.10 JSMD1206-175 3.00 3.50 1.50 1.80 0.50 1.20 0.15 0.10 JSMD1206-200 3.00 3.50 1.50 1.80 0.50 1.20 0.15 0.10 eristics Terminal pad materials:Tin-plated Nickel-Copper Terminal pad solder ability:Meets EIA specification RS186-9E and ANSI/J-STD-002 Category 3. Recommended Pad Layout (mm.) Packaging Quantity Part Number Quantity JSMD 005.005/60.010.010/60.012.012/60.035/30.050/24.075/16.100/12. 110/12.150.150/8. 175.200 3,500 pcs/reel The others 4,000 pcs/reel Tape & reel packaging per EIA481-1 http:// www.jksemi.com 2016-12-01 版次: c JSMD 1206 Series Surface Mount PTC Devices Tape And Reel Specifications (mm) Governing Specifications EIA 481-1 W 8.15 ± 0.3 P0 4.0 ± 0.10 P1 4.0 ± 0.10 P2 2.0 ± 0.05 A0 1.95 ± 0.10 B0 3.40 ± 0.10 B1max. 4.35 D0 1.50 + 0.1, -0 F 3.5 ± 0.05 E1 1.75 ± 0.10 E2min. 6.25 T 0.6 T1max. 0.1 K0 1.04 ± 0.1 Leader min. 390 Trailer min. 160 Reel Dimensions A max. 178 N min. 60 W1 9 ± 0.5 W2 12.6 ± 0.5 EIA Tape Component Dimensions P0 Embossment D T P2 E1 Cover F B K0 E2 T P1 EIA Reel Dimensions W2(measured at hub) A Cover tape N(hub dia.) W1(measured at hu Carrier tape Embossed cavity Storage And Handling ‧ Storage conditions:35°C max, 70% R.H. ‧ Devices may not meet specified performance if storage conditions are exceeded. Part Number System http:// www.jksemi.com W B0 2016-12-01 版次: c JSMD 1206 Series Surface Mount PTC Devices Cross Reference Cross Reference JKSEMI TYCO/Raychem Littelfuse JSMD1206-005 - JSMD1206-005/60 Bourns / Polytronics / SEA-LAND Multifuse® EVERFUSE® - - SMD1206P005TF nSMD005 - 1206L005/60 - - - JSMD1206-010 nanoSMDC010F - - SMD1206P010TF nSMD010 JSMD1206-010/60 - 1206L010/60 - - - JSMD1206-012 nanoSMDC012F 1206L012 MF-NSMF012 SMD1206P012TF nSMD012 JSMD1206-012/60 - - - - - JSMD1206-020 nanoSMDC020F 1206L020 MF-NSMF020 - nSMD020 - MF-NSMF020X SMD1206P020TF/30 nSMD020-30V JSMD1206-020/30 - JSMD1206-025 nanoSMDC025F 1206L025 - SMD1206P025TF nSMD025 JSMD1206-025/24 - - - SMD1206P025TF/24 nSMD025-24V JSMD1206-035 nanoSMDC035F 1206L035 MF-NSMF035 - nSMD035 JSMD1206-035/30 - 1206L035/30 - SMD1206P035TF/30 - JSMD1206-050 - 1206L050 MF-NSMF050 SMD1206P050TF nSMD050 JSMD1206-050/8 - - - - - JSMD1206-050/16 - - - - nSMD050-16V JSMD1206-050/24 - 1206L050/24 - SMD1206P050TF/24 nSMD050-24V JSMD1206-075 nanoSMDC075F - MF-NSMF075 SMD1206P075TFT nSMD075 JSMD1206-075/13.2 - 1206L075/13.2 - SMD1206P075TF/13.2 nSMD075-13.2V JSMD1206-075/16 - 1206L075/16 - SMD1206P075TF/16 nSMD075-16V JSMD1206-100 - - - - nSMD100 JSMD1206-100/8 - - - - - JSMD1206-100/12 - - - - - JSMD1206-110 nanoSMDC110F 1206L110 MF-NSMF110 SMD1206P110TFT nSMD110 JSMD1206-110/8 - - - - - JSMD1206-110/12 - - - - - JSMD1206-150 nanoSMDC150F 1206L150 MF-NSMF150 SMD1206P150TFT nSMD150 JSMD1206-150/8 - - - - - JSMD1206-175 - 1206L175 - SMD1206P175TF - JSMD1206-200 nanoSMDC200F 1206L200 MF-NSMF200 SMD1206P200TF nSMD200 “Raychem” is a registered trademark of Tyco Electronics. “Littelfuse” is a registered trademark of Littelfuse “Multifuse” is a registered trademark of bourns,Inc. “EVERFUSE” is a registered trademark of Polytronics Technology Corp. “SEA-LAND” is a registered trademark of Sea-Land electronic corp. Website: http://www.jksemi.com For additional information, please contact your local Sales Representative. ©Copyright 2016, jksemi is a registered trademark of jksemi All rights arereserved http:// www.jksemi.com 2016-12-01 版次: c
SMD1206-050 价格&库存
很抱歉,暂时无法提供与“SMD1206-050”相匹配的价格&库存,您可以联系我们找货
