AO3422A
AO3422A
    UMW(友台)
    SOT-23
    AO3422A
AO3422A 数据手册
UMW R UMW AO3422A N-Channel 60-V(D-S) MOSFET V(BR)DSS RDS(on)MAX 105mΩ@10V 125mΩ@4.5V 60 V FEATURE ※ TrenchFET Power MOSFET ID 2.1A SOT–23 APPLICATION ※ Load Switch for Portable Devices ※ DC/DC Converter MARKING Equivalent Circuit 1. GATE 2. SOURCE 3. DRAIN Maximum ratings ( Ta=25℃ unless otherwise noted) Parameter Symbol Value Drain-Source Voltage VDS 60 Gate-Source Voltage VGS ±20 ID 2.1 IDM 10 Continuous Source-Drain Current(Diode Conduction) IS 0.85 Power Dissipation PD 1.25 W RθJA 125 ℃/W TJ 150 ℃ TSTG -55~+150 ℃ Continuous Drain Current Pulsed Diode Curren Thermal Resistance from Junction to Ambient (t≤5s) Operating Junction Storage Temperature www.umw-ic.com 1 Unit V A 友台半导体有限公司 UMW R UMW AO3422A MOSFET ELECTRICAL CHARACTERISTICS Static Electrical Characteristics (Ta = 25 ℃ Unless Otherwise Noted) Parameter Symbol Test Condition Min VGS = 0V, ID = 250µA 60 VGS(th) VDS =VGS, ID = 250µA 1 Gate-source leakage IGSS Zero gate voltage drain current IDSS Typ Max Unit Static Drain-source breakdown voltage V(BR)DSS Gate-source threshold voltage Drain-source on-state resistancea RDS(on) V 2.5 V VDS =0V, VGS = ±20V ±100 nA VDS = 60V, VGS =0V 1 µA VGS = 10V, ID = 3A 80 105 mΩ VGS = 4.5V, ID = 2A 89 125 mΩ Forward transconductancea gfs VDS = 4.5V, ID = 2.1A 11 S Diode forward voltage VSD IS=1.5A,VGS=0V 0.8 1.3 V 214 300 pF Dynamic Input capacitance Ciss Output capacitance Coss Reverse transfer capacitanceb Crss Total gate charge Qg Gate-source charge Qgs Gate-drain charge Qgd Gate resistance VDS = 25V,VGS =0V, f=1MHz VDS = 25V,VGS = 4.5V, ID = 3A Rg f=1MHz 31 pF 12.6 pF nC 2.6 3.3 0.6 nC 0.8 nC 1.3 3 Ω Switchingb Turn-on delay time Rise time Turn-off delay time Fall time td(on) tr td(off) VDS= 25V RL=6Ω, ID ≈ 1A, VGEN= 10V,Rg=3Ω tf 2.3 ns 2.4 ns 16.5 ns 2 ns Drain-source body diode characteristics Continuous Source-Drain Diode Current Tc=25℃ IS 3 A Note : 1. Repetitive Rating : Pulse width limited by maximum junction temperature. 2. Surface Mounted on FR4 Board, t < 5 sec. 3. Pulse Test : Pulse Width≤300µs, Duty Cycle ≤ 2%. 4. Guaranteed by design, not subject to production testing. www.umw-ic.com 2 友台半导体有限公司 UMW R Symbol A A1 A2 b c D E E1 e e1 L L1 θ www.umw-ic.com UMW AO3422A Dimensions In Millimeters Min. Max. 0.900 1.150 0.000 0.100 0.900 1.050 0.300 0.500 0.080 0.150 2.800 3.000 1.200 1.400 2.250 2.550 0.950 TYP. 1.800 2.000 0.550 REF. 0.300 0.500 0° 8° 3 Dimensions In Inches Min. Max. 0.035 0.045 0.000 0.004 0.035 0.041 0.012 0.020 0.003 0.006 0.110 0.118 0.047 0.055 0.089 0.100 0.037 TYP. 0.071 0.079 0.022 REF. 0.012 0.020 0° 8° 友台半导体有限公司
AO3422A
1. 物料型号:UMW AO3422A 2. 器件简介:TrenchFET Power MOSFET,适用于便携设备的负载开关和DC/DC转换器。 3. 引脚分配:SOT-23封装,引脚1为栅极(GATE),引脚2为源极(SOURCE),引脚3为漏极(DRAIN)。 4. 参数特性: - 漏源电压(VDS)最大60V。 - 栅源电压(VGS)最大+20V。 - 连续漏电流(ID)最大2.1A。 - 脉冲二极管电流(IDM)最大10A。 - 连续源漏电流(IS)最大0.85A。 - 功率耗散(PD)最大1.25W。 - 从结到环境的热阻(RθJA)125°C/W。 - 工作结温(TJ)最高150°C。 - 存储温度范围-55~+150°C。 5. 功能详解:提供了详细的电气特性,包括静态电气特性和动态特性,如漏源击穿电压、栅源阈值电压、栅源漏电流、零栅源电压漏电流、漏源导通电阻、正向跨导、二极管正向电压、输入电容、输出电容、反向传输电容、总栅电荷、栅源电荷、栅漏电荷、栅电阻、开关延迟时间、上升时间和下降时间等。 6. 应用信息:适用于便携设备的负载开关和DC/DC转换器。 7. 封装信息:SOT-23,提供了详细的封装尺寸。
AO3422A 价格&库存
很抱歉,暂时无法提供与“AO3422A”相匹配的价格&库存,您可以联系我们找货
AO3422A
    • 1+0.23650
    • 200+0.15180
    • 1500+0.13200
    • 3000+0.11660
    库存:3000
    AO3422A
      • 10+0.18445
      • 100+0.17255
      • 500+0.16065
      • 2000+0.14280
      • 5000+0.13685
      • 10000+0.13328
      库存:2990
