IDC
3.96mm
VR CONNECTOR
Disconnectable Insulation displacement connectors
pitch
Features ––––––––––––––––––––––––
• Twin U-slot insulation displacement section
The insulation displacement section connected to each wire
consists of two tin-plated slots (twin U-slots), which ensures
reliable connection.
• Two types of connections
This receptacle can be used for both daisy chain (through)
connections and end connections. The end connections can
be made from either direction.
Specifications –––––––––––––––––––
This 3.96 mm pitch insulation displacement
connector is used with printed circuit
boards. Since the connector can
accommodate 18 AWG wires and has a
large pitch, it is ideal for connecting power
supply circuits.
End connection
Daisy connection
• Current rating: 7 A AC, DC (AWG #18)
• Voltage rating: 250 V AC, DC
• Temperature range: -25˚C to +85˚C
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 1,500 VAC/minute
• Applicable wire: UL1007(Contact JST for details regarding other UL
wires.)
AWG #26, #24, #22, #20, #18
Conductor construction/
AWG #26 to #22: 7 strands, tin-coated
AWG #20: 7 and 26 strands, tin-coated
AWG #18: 34 and 43 strands
Insulation O.D./1.3 to 2.1 mm
• Applicable PC board thickness: 0.8 to 1.6 mm
* Temperature Range:
The aforementioned temperature range of this connector is
described in JST Standard Product Specification.
* Refer to "General Instruction and Notice when using
Terminals and Connectors" at the end of this catalog.
* Contact JST for details.
* Compliant with RoHS.
Note:
Do not branch in parallel current which exceeds the rated current. If branched in
parallel, current imbalance or other problems may develop. If it is absolutely
necessary to branch a large current in parallel, design the circuits without
causing imbalance and provide an extra margin for each circuit.
Color indication
Standards ––––––––––––––––––––––
Recognized E60389
1
Certified LR20812
1
VR
CONNECTOR
Cover –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
For end connection
Circuits
A
11.6
8.5
5.94
Model No.
Dimensions A
(mm)
Q'ty/box
For end
connection
For daisy
connection
2
VRC-02E
VRC-02D
7.92
1,000
3
VRC-03E
VRC-03D
11.88
1,000
4
VRC-04E
VRC-04D
15.84
500
5
VRC-05E
VRC-05D
19.80
500
6
VRC-06E
VRC-06D
23.76
500
8
VRC-08E
VRC-08D
31.68
250
VRC-12D
47.52
200
12
For daisy connection
Material
3.5
Polyvinyl chloride, UL94V-0 (black)
A
11.6
RoHS compliance
Note:
1. The use of this cover keeps the terminated part from dust.
2. Contact JST if cover is required.
5.94
Receptacle –––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
B
A
9.2
(1.98)
17.7
3.96
Model No.
Circuits
AWG #26
(natural/white)
AWG #24
(black)
AWG #22
(red)
Dimensions (mm)
AWG #20
(brown)
AWG #18
(orange)
A
B
Q’ty/bag
2
02VR-6S
02VR-4K
02VR-2R
02VR-AN
02VR-BO
3.96
7.92
2,000
3
03VR-6S
03VR-4K
03VR-2R
03VR-AN
03VR-BO
7.92
11.88
1,000
4
04VR-6S
04VR-4K
04VR-2R
04VR-AN
04VR-BO
11.88
15.84
1,000
5
05VR-6S
05VR-4K
05VR-2R
05VR-AN
05VR-BO
15.84
19.80
1,000
6
06VR-6S
06VR-4K
06VR-2R
06VR-AN
06VR-BO
19.80
23.76
1,000
8
08VR-6S
08VR-4K
08VR-2R
08VR-AN
08VR-BO
27.72
31.68
500
9
09VR-6S
09VR-4K
09VR-2R
09VR-AN
09VR-BO
31.68
35.64
500
10
10VR-6S
10VR-4K
10VR-2R
10VR-AN
10VR-BO
35.64
39.60
500
12
12VR-6S
12VR-4K
12VR-2R
12VR-AN
12VR-BO
43.56
47.52
250
15
15VR-6S
15VR-4K
15VR-2R
15VR-AN
15VR-BO
55.44
59.40
250
Material and Finish
Contact: Brass, Copper-undercoated, tin-plated (reflow treatment)
Housing: PA 66, UL94V-2
RoHS compliance This product displays (LF)(SN) on a label.
Note:
1. In addition to mating with the VR headers, the VR receptacle will also mate with VH and VS headers.
2. Color indication is shown by a line on each receptacle.
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
02VR-6SStandard color: AWG #26: S…natural (white), AWG #24: K…black, AWG #22: R…red, AWG #20: N...brown, AWG #18: O…orange
Others: TR…tomato red E…blue M…green
2
VR
CONNECTOR
Locking header (Friction lock header) ––––––––––––––––––––––––––––––––––––––––
Circuits
B
(1.98)
Top
entry
type
Side
entry
type
10.54
3.18 10.63
3.64
17.45
3.3
1.14
2
B2P-VR
B2PS-VR
3
B3P-VR
B3PS-VR
4
B4P-VR
5
3.18
7.75
Side entry type
B
B
Side
entry
type
3.96
7.92
1,000
250
7.92
11.88
500
250
B4PS-VR
11.88
15.84
250
250
B5P-VR
B5PS-VR
15.84
19.80
250
250
6
B6P-VR
B6PS-VR
19.80
23.76
250
100
8
B8P-VR
B8PS-VR
27.72
31.68
200
100
9
B9P-VR
B9PS-VR
31.68
35.64
100
100
10
B10P-VR
B10PS-VR
35.64
39.60
100
100
12
B12P-VR-P B12PS-VR-P
43.56
47.52
100
100
15
B15P-VR-P B15PS-VR-P
55.44
59.40
100
100
A
Post: Brass, copper-undercoated, tin-plated (reflow treatment)
Wafer: 2 to 10 circuits / PA 66, UL94V-0, natural (white)
12 and 15 circuits / PBT, UL94V-0, natural (white)
10.54
5.4
A
Material and Finish
3.3
1.14
3.96
3.18 10.63
(1.98)
Q'ty/box
Top
entry
type
A
3.96
Dimensions (mm)
Model No.
Top entry type
3.18
3.6
7.75
Polarizing key ––––––––––––––––––––––––––––––––––––––––––––––––––––––––––––
Model No.
Q'ty/bag
PK-VR
5,000
Material
2.2
2
1.5
7.5
1.1
RoHS compliance
Note: Not UL/CSA approved.
1.8
0.8
Glass-filled PA 66, UL94V-0, natural (gray)
PC board layout (viewed from soldering side) and Assembly layout –––––––––––––––––––
Top entry type
2min.
9.2
φ1.65 +0.1
3.18min.
3.96
±0.05
26.85
2min.
7.75
±0.05
11 max.
3.96
Side entry type
φ1.65 +0.1
11max.
Note:
1. Tolerances are non-cumulative: ±0.05 mm for all centers.
2. Hole dimensions differ according to the type of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details.
3
很抱歉,暂时无法提供与“B4P-VR(LF)(SN)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.68740
- 50+1.30799
- 250+1.14534
