DATA SHEET
TRANSIENT VOLTAGE SUPPRESSORS
AC/DC POWER SUPPLY
P6SMB series
Product specification– June 15, 2022 V.4
RoHS compliant & Halogen free
Circuit Protection
Product Specification
Transient Voltage Suppressors
2
8
P6SMB
Transient Voltage Suppressors (TVS) Data Sheet
Features
For surface mounted applications in order to optimize board space
Low profile package
Built-in strain relief
Glass passivated junction
Low inductance
Excellent clamping capability
600W peak pulse power capability at 10/1000μs waveform, repetition rate (duty cycle): 0.01%
Fast response time
Typical IR less than 1μA above 12V
High Temperature soldering: 260℃/10 seconds at terminals
Plastic package has underwriters laboratory flammability 94V-0
Meets MSL level 1, per J-STD-020
Safety certification: UL: E244458
IEC61000-4-2 ESD 30KV Air, 30KV contact compliance
Mechanical Data
Case: JEDEC DO-214AA. Molded plastic over glass passivated junction
Terminal: Tin plated, solderable per MIL-STD-750, Method 2026
Polarity: Color band denotes cathode except bi-directional models
Standard Packaging: 12mm tape (EIA STD RS-481)
Weight: 0.10g
Applications
■ I/O interface
■ AC/DC power supply
■ Low frequency signal transmission line (RS232, RS485, etc.)
Maximum Ratings and Characteristics
Ratings at 25℃ ambient temperature unless otherwise specified.
Rating
Symbol
Value
Units
Peak pulse power dissipation at 10/1000μs waveform
(Note1, Note2, Fig.1)
PPPM
Minimum 600
Watts
Peak pulse current of at 10/1000μs waveform (Note 1, Fig.3)
IPPM
See Table
Amps
PM(AV)
5.0
Watts
IFSM
100
Amps
TJ,TSTG
-55 to +150
Typical thermal resistance junction to lead
RθJL
℃/W
Typical thermal resistance junction to ambient
RθJA
100
℃/W
Steady state power dissipation at TA=50℃ (Fig.5)
Peak forward surge current, 8.3ms single half sine-wave
superimposed on rated load, (JEDEC Method) (Note3, Fig.6)
Operating junction and Storage Temperature Range.
Notes: 1. Non-repetitive current pulse, per Fig.3 and derated above TA=25℃ per Fig.2.
2. Mounted on 5.0mm×5.0mm (0.03mm thick) copper pads to each terminal.
3. 8.3ms single half sine-wave, or equivalent square wave, duty cycle=4 pulses per minutes maximum.
www.yageo.com
Jun. 15, 2022 V.4
Circuit Protection
3
8
P6SMB
Dimensions (SMB/DO-214AA)
Product:
Millimeters
Inches
Symbol
Cathode Band
Min.
Max.
Min.
Max.
L
4.06
4.57
0.160
0.180
D
3.30
3.94
0.130
0.155
D1
1.95
2.20
0.077
0.086
T
5.21
5.59
0.205
0.220
T1
0.76
1.52
0.030
0.060
d
0.203
0.008
H
2.15
2.65
0.085
0.104
H1
2.13
2.47
0.084
0.097
D1 D
L
H1 H
d
T1
T
2.18mm
Pad:
1.75mm
2.16mm
1.75mm
Electrical Characteristics (TA=25℃)
Part Number
Device
Marking
Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
P6SMB6.8A
P6SMB6.8CA
6V8A
6V8C
5.80
6.45~7.14
10
10.5
58.1
1000
P6SMB7.5A
P6SMB7.5CA
7V5A
7V5C
6.40
7.13~7.88
10
11.3
54.0
500
P6SMB8.2A
P6SMB8.2CA
8V2A
8V2C
7.02
7.79~8.61
10
12.1
50.4
200
P6SMB9.1A
P6SMB9.1CA
9V1A
9V1C
7.78
8.65~9.55
1
13.4
45.5
50
P6SMB10A
P6SMB10CA
10A
10C
8.55
9.50~10.50
1
14.5
42.1
10
P6SMB11A
P6SMB11CA
11A
11C
9.40
10.50~11.60
1
15.6
39.1
5
P6SMB12A
P6SMB12CA
12A
12C
10.20
11.40~12.60
1
16.7
36.5
5
P6SMB13A
P6SMB13CA
13A
13C
11.10
12.40~13.70
1
18.2
33.5
1
P6SMB15A
P6SMB15CA
15A
15C
12.80
14.30~15.80
1
21.2
28.8
1
P6SMB16A
P6SMB16CA
16A
16C
13.60
15.20~16.80
1
22.5
27.1
1
P6SMB18A
P6SMB18CA
18A
18C
15.30
17.10~18.90
1
25.2
24.2
1
P6SMB20A
P6SMB20CA
20A
20C
17.10
19.00~21.00
1
27.7
22.0
1
P6SMB22A
P6SMB22CA
22A
22C
18.80
20.90~23.10
1
30.6
19.9
1
P6SMB24A
P6SMB24CA
24A
24C
20.50
22.80~25.20
1
33.2
18.4
1
www.yageo.com
Jun. 15, 2022 V.4
Circuit Protection
Part Number
8
P6SMB
Device
Marking
Code
4
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping
Voltage
@IPP
Peak
Pulse
Current
Reverse
Leakage
@VRWM
Unidirectional
Bidirectional
UNI
BI
VRWM(V)
VBR(V)
IT(mA)
VC(V)
IPP(A)
IR(μA)
P6SMB27A
P6SMB27CA
27A
27C
23.10
25.70~28.40
1
37.5
16.3
1
P6SMB30A
P6SMB30CA
30A
30C
25.60
28.50~31.50
1
41.4
14.7
1
P6SMB33A
P6SMB33CA
33A
33C
28.20
31.40~34.70
1
45.7
13.3
1
P6SMB36A
P6SMB36CA
36A
36C
30.80
34.20~37.80
1
49.9
12.2
1
P6SMB39A
P6SMB39CA
39A
39C
33.30
37.10~41.00
1
53.9
11.3
1
P6SMB43A
P6SMB43CA
43A
43C
36.80
40.90~45.20
1
59.3
10.3
1
P6SMB47A
P6SMB47CA
47A
47C
40.20
44.70~49.40
1
64.8
9.4
1
P6SMB51A
P6SMB51CA
51A
51C
43.60
48.50~53.60
1
70.1
8.7
1
P6SMB56A
P6SMB56CA
56A
56C
47.80
53.20~58.80
1
77.0
7.9
1
P6SMB62A
P6SMB62CA
62A
62C
53.00
58.90~65.10
1
85.0
7.2
1
P6SMB68A
P6SMB68CA
68A
68C
58.10
64.60~71.40
1
92.0
6.6
1
P6SMB75A
P6SMB75CA
75A
75C
64.10
71.30~78.80
1
103.0
5.9
1
P6SMB82A
P6SMB82CA
82A
82C
70.10
77.90~86.10
1
113.0
5.4
1
P6SMB91A
P6SMB91CA
91A
91C
77.80
86.50~95.50
1
125.0
4.9
1
P6SMB100A
P6SMB100CA
100A
100C
85.50
95.00~105.00
1
137.0
4.5
1
P6SMB110A
P6SMB110CA
110A
110C
94.00
105.00~116.00
1
152.0
4.0
1
P6SMB120A
P6SMB120CA
120A
120C
102.00
114.00~126.00
1
165.0
3.7
1
P6SMB130A
P6SMB130CA
130A
130C
111.00
124.00~137.00
1
179.0
3.4
1
P6SMB150A
P6SMB150CA
150A
150C
128.00
143.00~158.00
1
207.0
2.9
1
P6SMB160A
P6SMB160CA
160A
160C
136.00
152.00~168.00
1
219.0
2.8
1
P6SMB170A
P6SMB170CA
170A
170C
145.00
162.00~179.00
1
234.0
2.6
1
P6SMB180A
P6SMB180CA
180A
180C
154.00
171.00~189.00
1
246.0
2.5
1
P6SMB200A
P6SMB200CA
200A
200C
171.00
190.00~210.00
1
274.0
2.2
1
P6SMB220A
P6SMB220CA
220A
220C
185.00
209.00~231.00
1
328.0
1.9
1
P6SMB250A
P6SMB250CA
250A
250C
214.00
237.00~263.00
1
344.0
1.8
1
P6SMB300A
P6SMB300CA
300A
300C
256.00
285.00~315.00
1
414.0
1.5
1
P6SMB350A
P6SMB350CA
350A
350C
300.00
332.00~368.00
1
482.0
1.3
1
P6SMB400A
P6SMB400CA
400A
400C
342.00
380.00~420.00
1
548.0
1.1
1
P6SMB440A
P6SMB440CA
440A
440C
376.00
418.00~462.00
1
602.0
1.04
1
P6SMB480A
P6SMB480CA
480A
480C
408.00
456.00~504.00
1
658.0
0.9
1
P6SMB510A
P6SMB510CA
510A
510C
434.00
485.00~535.00
1
698.0
0.9
1
P6SMB530A
P6SMB530CA
530A
530C
450.00
503.50~556.50
1
725.0
0.8
1
P6SMB540A
P6SMB540CA
540A
540C
459.00
513.00~567.00
1
740.0
0.8
1
P6SMB550A
P6SMB550CA
550A
550C
467.00
522.50~577.50
1
760.0
0.8
1
P6SMB600A
P6SMB600CA
600A
600C
510.00
570.00~630.00
1
828.0
0.75
1
www.yageo.com
Jun. 15, 2022 V.4
Circuit Protection
5
8
P6SMB
Ratings and Characteristic Curves (TA=25℃ unless otherwise noted)
Figure 2. Pulse Derating Curve
PPPM - Peak Pulse Power (kW)
100
10
1
0.2×0.2″(5.0×5.0mm)
Copper Pad Area
0.1
1
100
10
1000
Peak Pulse Power (PPP) or Current (IPP)
Derating in Percentage %
Figure 1. Peak Pulse Power Rating Curve
100
80
60
40
td-Pulse Width (µs)
Cj (pF)
IPPM - Peak Pulse Current, %IRSM
100
2.0
3.0
1
4.0
6
5
4
3
2
1
75
100
125
TA-Ambient Temperature (℃)
150
175
100
1000
Figure 6. Maximum Non-Repetitive Forward
Surge Current Uni-Directional Only
IFSM - Peak Forward Surve Current (A)
PM(AV), Steady State Power Dissipation (W)
Figure 5. Steady State Power Dissipation Derating
Curve
10
VBR-Reverse Breakdown Voltage (V)
t-Time (ms)
25
Bi-directional @VR
TJ=25℃
f=1.0MHz
Vsig=50mVp-p
1
td
Uni-directional V=0V
10
10/1000µs Waveform
as defined by R.E.A
1.0
175
Uni-directional @VR
50
Bi-directional V=0V
1000
Half Value IPPM (IPPM/2)
100
10000
Peak Value IPPM
100
75
Figure 4. Typical Junction Capacitance
TJ=25℃
Pulse Width(td) is defined as
the point where the peak
current decays to 50% of IPPM
tr=10µs
50
Figure 3. Pulse Waveform
150
25
120
100
80
60
40
10
100
Number of Cycles at 60Hz
www.yageo.com
Jun. 15, 2022 V.4
Circuit Protection
6
8
P6SMB
Recommended Soldering Conditions
Reflow Soldering
Critical Zone
TL to TP
tP
TP
Ramp-up
TL
tL
Temperature
TS max
TS min
Ramp-down
tS
Preheat
25
t 25℃ to Peak
Time
Recommended Conditions
Profile Feature
Pb-Free Assembly
Average ramp-up rate (TL to TP)
3℃/second max.
Preheat
-Temperature Min (TS min)
-Temperature Max (TS max)
-Time (min to max) (tS)
150℃
200℃
60-180 seconds
TS max to TL
-Ramp-up Rate
3℃/second max.
Time maintained above:
-Temperature (TL)
-Time (tL)
217℃
60-150 seconds
Peak Temperature (TP)
260℃
Time within 5℃ of actual Peak Temperature (tP)
Ramp-down Rate
Time 25℃ to Peak Temperature
20-40 seconds
6℃/second max.
8 minutes max.
www.yageo.com
Jun. 15, 2022 V.4
Circuit Protection
7
8
P6SMB
Marking Code
Cathode Band
YXXX
YXXX
6V8C
6V8A
Logo
Internal control code
Marking Code
Logo
Marking Code
Part Number Code
P6SMB
XXX C A / XXXX
Package Code
TR7:7 inch reel package
TR13:13 inch reel package
5% VBR Voltage Tolerance
Bidirectional
VBR Voltage
Series Code
Ordering Code for Different Package
7 inch reel package: Add suffix “ /TR7 ” at the end of the part number, such as P6SMBXXXCA/TR7
13 inch reel package: Add suffix “ /TR13 ” at the end of the part number, such as P6SMBXXXCA/TR13
www.yageo.com
Jun. 15, 2022 V.4
Circuit Protection
8
8
P6SMB
Packaging
Tape
P0
P1
P2
D0
B
T
E
F
W
B0
D1
A
A
K0
B
SECTION B-B
Symbol
Dimension (mm)
W
12.00±0.20
P0
4.00±0.10
P1
8.00±0.10
P2
2.00±0.10
D0
Φ1.55±0.10
D1
Φ1.5±0.10
E
1.75±0.10
F
5.50±0.10
A0
3.86±0.15
B0
5.65±0.10
K0
2.75±0.15
T
0.25±0.05
D2
Φ178.0±2.0
D3
Φ50.0Min.
D4
Φ13.0±0.5
W1
16.0±2.0
A0
SECTION A-A
7” Reel
D4
D3
D2
13” Reel
W1
Quantity: 500PCS
D5
Φ330.0±2.0
D6
Φ13.5±0.5
H
2.5±1.0
W2
16.0±2.0
Quantity: 3000PCS
www.yageo.com
Jun. 15, 2022 V.4
很抱歉,暂时无法提供与“P6SMB62CA/TR7”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.611891+0.46864
- 10+2.1852510+0.28354
- 50+1.5736850+0.20419
- 100+1.29602100+0.16816
- 国内价格 香港价格
- 500+1.01871500+0.13218
- 1500+0.845131500+0.10966
- 国内价格
- 2000+0.45946
- 5000+0.44737
