11.24
6.40
4.80
3.50
2.50
1.50
H
Optional shell spring
2x 1.80
2x 1.40
16x 0.20±0.05
A
0.50
8x0.30
A4B9
G
B8 A5 B7 A6 A7 B6 A8 B5
B1 A12
2x 2.20
A
3.54
8.94
2x 1.80
1.60
6.5
F
As viewed from component side
Solder Area
6.69
Tolerance:±0.05mm
3.16
0.80
0.78
A12
1.20
0.70
B12
B1
11.24
2.10
0.80
4.00
Pin
Signal
Mating
Sequence
Pin
Signal
A1
GND
First
B12
GND
First
VBUS
First
B9
VBUS
First
A5
CC1
Second
B8
SBU2
Second
A6
Dp1
Second
B7
Dn2
Second
A7
Dn1
Second
B6
Dp2
Second
A8
SBU1
Second
B5
CC2
Second
A9
VBUS
First
B4
VBUS
First
A12
GND
First
B1
GND
2.50
3.50
4.55
5.05
6.15
6.65
A
1
B1 A12
0.20
0.50
1.50
0.70±0.05
A1 B12
SHELL
First
GND
0.70
Plug
Ordering Grid
X
Contact Plating
03 = 3µ" Gold
Plug and Receptacle Mating View
Part Number
Product Description
USB4500
USB Type C Receptacle for USB 2.0, SMT Type,
Mid Mount, 0.8mm Offset
By
Detail
Revision
Date
5
CC
Drawing
Release
A
01/07/21
Tolerances (Except as Noted)
Length
Angle
X.X ± 0.30
X.XX ± 0.20
X.XXX ± 0.10
Units:
Metric (mm)
C
3rd Angle Projection
6
A
Request Samples
and Quotation
Packing Options
A = Tape & Reel
Shell Spring
0 = Without
1 = With
Section A-A
4
03
USB4500
1st July 2021
3
5.00A collectively for VBUS pins
6.25A collectively for GND pins
1.25A for B5 pin
0.25A per pin for all other pins
Voltage Rating: 20V DC
Contact Resistance: 40mΩ max initial.
50mΩ max after test
Dielectric Withstanding Voltage: 100V AC
Insulation Resistance 100MΩ min
Mechanical & Environmental
Operating Temperature: -25°C to +85°C
Mating Force: 5 to 20 N.
Unmated Force: 6 to 20 N after test
Durability: 10,000 cycles
Drawing Date
2
Electrical
Current Rating:
2.05 Min
B4A9
1.20±0.05
B
GND
4.60
4.45
2.63
6.5 Max.
0.16
C
Mating
Sequence
A4
SHELL
A4B9
Plating
Terminal:
Contact Area: See Ordering Grid
Solder Tails: Gold Flash
Underplating: 50µ" Min. Nickel All Over
Shell: 30µ" Min. Nickel
Mid Plate: Cleaning
Component Outline
0.10
D
PCB Edge
Recommended PCB Layout
Thickness=0.80mm
8.34
A1
Material
Insulator: LCP, E130i, UL 94V-0, Black
Contact: Copper Alloy, C18400-H, T=0.12mm
Shell: Stainless steel , SUS304-1/2H, T=0.30mm
Mid Plate:Stainless Steel, SUS301-3/4H, T=0.15mm
4x 0.60
4x1.00
9.24
+0.06
-0.02
2.56±0.04
E
Specifications
4.00
4.60
5.70
A1 B12
4x 0.60
B4 A9
7
(1400 pcs/reel)
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
1/2
Folder Paper Board
H
Unloaded Section
1400 PCS
Unloaded Section
(16 Pockets)
Paper Board
(16 Pockets)
G
Detail E
Direction of Unreeling
F
Peeling
Angle
Vacuum Bag
165°~180°
Reel and Tape
E
Ø330
Carton
D
3
320
Ø1
Label
Paper Board
W+0.5
34
C
4.00
2.00
Pcs /
Reel
1400
1.75
24.00
B
Product Description
USB4500
1st July 2021
By
Detail E
1
2
Detail
3
4
Total
Quantity
14000 pcs
Part Number
Drawing Date
12.00
A
Reels /
Carton
10
Revision
Date
5
CC
Drawing
Release
A
01/07/21
Length
Angle
Units:
Metric (mm)
C
6
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
CC
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB4500-03-1-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.45957
- 10+4.56482
- 25+4.26656
- 50+4.06174
- 100+3.87608
- 250+3.62334
- 500+3.46524
- 1400+3.23286
- 2800+3.09272
- 4200+2.99929
- 国内价格 香港价格
- 1400+3.791991400+0.49285
- 2800+3.610982800+0.46932
- 4200+3.509164200+0.45609
- 7000+3.385017000+0.43995
- 9800+3.305629800+0.42963
- 14000+3.2235414000+0.41897
