U237-091N-4BLVS10-1
U237-091N-4BLVS10-1
    XKB(中国星坤)
    SMD
    USB连接器 Type-A 9P 沉板 端口数:1 额定电流:1.8A 工作温度:-40℃~+85℃
U237-091N-4BLVS10-1 数据手册
3.70 [0.146] 8.00 [0.315] 1.00 [0.039] 0.40 [0.016] 8.00 [0.315] 0.70 [0.028] 1.95 [0.077] 1.00 [0.039] Pitch 3.35 [0.132] 2.00 [0.079] 5 6 1 14.70 [0.579] RECOMMENDED PCB LAYOUT Pin # 1 12.00 [0.472] 8.00 [0.315] 4.50 [0.177] 2 11.70 [0.461] 6.00 [0.236] 5 6 4 7 3 8 2 Material 2 Housing Material:LCP, UL94V-0, blue 3 Contact Terminal: Copper Alloy 4 Metallic Shell:Spcc 5 Plating 6 Underplating: Nickel 7 Contact Plating: 1µ" Gold 8 Solder Tail: 100µ" Min. Tin 9 Metallic Shell: Nickel Shell Electrical Voltage Rating: 100 V AC Current Rating: 0.25A (Signal pins 2,3,5,6,7,8,9) 1.8A (Power Pins 1,4) Contact Resistance: 30mΩ Max. Insulation resistance: 1000MΩ Min. Dielectric withstanding voltage: 100V AC/Minute Mechanical Mating Force: 35N (3.57Kgf) Max Unmating Force: 10N (1.02Kgf) Min. initial, 8N min after test Environmental and Processing Operating Temperature: -40°C to +85°C 4.00 [0.158] 9 1 2.00 [0.079] 7.00 [0.275] X X X MARK 3 2.60 [0.102] 3.80 [0.149] 9 8 2.30 [0.090] 0.60 [0.024] 1.80 [0.071] 18.75 [0.738] 19.85 [0.782] 4 7 DATE DESCRIPTION REVISIONS www.xk-dg.cn www.helloxkb.com REVISED APPROVED ANGLAR L≤4 4
U237-091N-4BLVS10-1 价格&库存
很抱歉,暂时无法提供与“U237-091N-4BLVS10-1”相匹配的价格&库存,您可以联系我们找货
U237-091N-4BLVS10-1
  • 1+0.69358
库存:2
U237-091N-4BLVS10-1
  • 5+2.01528
  • 50+1.62972
  • 200+1.35702
  • 500+1.15085
  • 2500+1.05905
  • 5000+1.00397
库存:1052
