D52EXT1
D52EXT1
    GARMIN
    D52EXT1
D52EXT1 数据手册
MODULE FORM FACTORS D52 ANT SoC Modules are available in multiple form factors including drop-in compatible layouts with past ANT Wireless module solutions and optional on-board accelerometer. Module solutions using the nRF52832 SoC from Nordic Semiconductor to fast-track time to market for ultra low power sport & fitness (including ANT+) and IoT mesh applications. D52Q M6 Development Module D52QD2M6IA-A D52M M8 Form Factor D52MD2M8IA D52MPMM8IA D52Q M4 Form Factor D52QD2M4IA D52QD2M4IA-A D52QPMM4IA D52QPMM4IA-A DEVELOPMENT / STARTER KITS D52 MODULE SERIES BENEFITS Run ANT and Bluetooth® low energy concurrently Rely on high accuracy for ANT & Bluetooth with peripheral crystal clocks Scale your use case with IoT solutions like ANT BLAZE* mesh networks D52 Starter Kits contain everything you need to get started with evaluating D52 modules, the nRF52832 SoC, ANT & Bluetooth low engery. WHY USE A MODULE? Accelerate time-to-revenue with a complete RF design Reduce costly fees associcated with RF certification Streamline development with a suite of starter kits, tools & online resources D52DK2 STARTER KIT * ANT BLAZE runs on premium D52 module series SKUs D52EXT1 EXTENDER KIT THISISANT.COM/D52 INFO@THISISANT.COM MODULE HARDWARE • Integrated printed antenna • On-board 32MHz and 20ppm 32.768 kHz crystal clocks • Supply Voltage range: - 1.7V to 3.6V (D52QD2M4IA) - 1.71V to 3.6V (D52QD2M4IA-A) • Operating temperature: Industrial (-40°C to +85°C) • Up to 30 GPIOs (D52QD2M4IA), 24 GPIOs (D52QD2M4IA-A, D52CD2M8IA) • Programmable output/channel from -20dBm to 4dBm • RoHS compliant • Layout compatible options with N5 M4, AP2, C7 D52 MODELS • Excellent receiver sensitivity -93dBm ANT mode (D52Q) -96dBm BLE mode (D52Q) • 1dBm resolution RSSI • Total 512kB flash, 64kB RAM • SPI, I2C and UART interface • Onboard 3-axis MEMS accelerometer (D52QD2M4IA-A) • 2 programmable interrupt pins • Radio regulatory approval for major markets • BLUETOOTH SIG qualification • Pre-loaded with S210 ANT SoftDevice and Network Processor application ANT® OPERATION ANT® OPERATION DESCRIPTION ORDERING/PACKAGE INFO* PART STATUS D52QD2M4IA D5QPMM4IA-A 20x20mm, 30GPIOs, 8 analog inputs TRAY: 20pc in 4x5 tray REEL: 800pc on 13”reel Active D52QD2M4IA-A D52QPMM4IA-A 20x20mm, 30 GPIOs, 8 analog inputs, 3-axis MEMS accelerometer TRAY: 20pc in 4x5 tray REEL: 800pc on 13” reel Active D52MD2M8IA D52MPMM8IA 14.0x9.8x2.0mm, 24GPIOs, 8 analog inputs TRAY: 40pc in 8x5 tray REEL: 1500pc on 13” reel Active D52D2M6IA-A D52Q w/ accelerometer on board for starter kit & TRAY: 10 pc on 150x165mm tray development use BLUETOOTH® OPERATION* (when loaded S212 S332 SoftDevice) (when loaded withwith S212 or S332or SoftDevice) • 79 selectable RF channels (2402 to 2480 MHz) • Simple to complex network topologies: peer-to-peer, star, tree, star-to-star and more • Broadcast, acknowledged, and burst data communication modes • Built-in device search and pairing • Built-in interference handling and radio coexistence management with application radio disable requests and application flash write/erase requests • Enhanced ANT features - Supports up to 15 logical channels, each with configurable channel periods. (5.2ms - 2s) PART NUMBER - Advanced burst data transfer modes (up to 60kbps) - Optional channel encryption mode (AES-128) - Supports up to 8 public, private and/or managed networks - Advanced power management features to optimize application power consumption including Event Filtering & Selective data updates - Asynchronous transmit channel - Fast channel initiation (when loaded with the S332 SoftDevice) • Bluetooth 4. 2 compliant low energy single mode protocol stack suitable for Bluetooth low energy products • Concurrent Central, Observer, Peripheral, and Broadcaster roles with up to: - Multiple connections as a central - One connection as a peripheral - Observe & Broadcaster • Link layer • L2CAP, ATT, and SM protocols • GATT and GAP APIs • GATT Client and Server Active
D52EXT1 价格&库存
很抱歉,暂时无法提供与“D52EXT1”相匹配的价格&库存,您可以联系我们找货
