PT4121E
60V Step-down High Brightness
LED Controller
GENERAL DESCRIPTION
FEATURES
The PT4121E is a high efficiency step-down
Simple low parts count
controller. It is designed to operate in continuous
Wide input voltage range: 6V to 60V
conduction mode and drive single or multiple
High efficiency (up to 97%)
series connected LED efficiently from a voltage
Single pin on/off and brightness control using
source higher than the total LED chain voltage. It
DC Voltage or PWM
operates with a wide input voltage from 6V to 60V
Up to 1MHz switching frequency
and provides an externally adjustable output
Adjustable Constant LED Current
current.
Typical 3% output current accuracy
The PT4121E includes a high-side output
High-Side Current Sense
current sense circuit, which uses an external
Hysteretic Control: No need compensation
resistor to set the nominal average output current,
Inherent RCS open protection
and a dedicated DIM input accepts either a DC
Inherent open-circuit LED protection
voltage or PWM dimming.
Inherent short-circuit LED protection
Over Temperature Protection
The PT4121E is available in SOT23-6 or SOP-8
packages.
APPLICATIONS
Low voltage halogen replacement LEDs
Automotive/Decorative lighting
Low voltage industrial lighting
LED back-up lighting
Signs/Emergency lighting
SELV lighting
LCD TV backlighting
ORDERING INFORMATION
PACKAGE
TEMPERATURE
ORDERING PART
TRANSPORT
RANGE
NUMBER
MEDIA
Tape and Reel
3000 units
o
o
SOT23-6
-40 C to 125 C
PT4121EE23F
SOP-8
-40℃ to 125℃
PT4121EESOH
Tape and Reel
4000 units
MARKING
4121E
PT4121E
xxxxxX
TYPICAL APPLICATION CIRCUIT
D1
VIN
6.0V~50V
CIN
Rcs
VIN
VCC
CSN
PT4121E
DIM
DRV
L1
GND
CR POWTECH (SHANGHAI) CO., LTD.
PT4121E_DS_Rev EN 1.1
WWW.CRPOWTECH.COM
Page 1
PT4121E
LED Controller
PIN ASSIGNMENT
CSN
2
DIM
3
6
VCC
5
DRV
4
GND
NC
1
VCC
2
DRV
3
GND
4
SOT23-6
PT4121E
1
4121E
VIN
8
NC
7
CSN
6
VIN
5
DIM
SOP-8
PIN DESCRIPTIONS
PIN No.
SOP-8
PIN No.
SOT23-6
1
PIN
NAMES
NC
2
6
VCC
3
5
DRV
4
4
GND
5
3
DIM
6
1
VIN
7
2
CSN
8
NC
DESCRIPTION
Not connected.
Internal Regulator Output. Connect a 1µF decoupling cap from this
pin to ground.
Gate-Driver Output. Connect this pin to the gate of the external
MOSFET.
Signal and power ground. Connect directly to ground plane.
Logic level dimming input. Drive DIM low to turn off the current
regulator. Drive DIM high to enable the current regulator.
Input Supply Pin. Connect a decoupling capacitor from VIN pin to
GND.
LED Current Sense Input. Connect a current-sense resistor that
programs LED average current to the VIN pin.
Not connected.
ABSOLUTE MAXIMUM RATINGS
SYMBOL
VIN
(note1)
PARAMETER
Supply Voltage
CSN
Current sense input (Respect to VIN)
VI/O
Other I/O PIN Input Voltage
θJA
TJ
TOP
TSTG
VALUE
UNIT
-0.3~60
V
+0.3~(-6.0)
V
-0.3~6
V
220
o
SOP-8 Thermal Resistance
145
o
Junction Temperature
150
o
-40~125
o
-55 to 150
o
SOT23-6 Thermal Resistance
Operating Temperature Range
Storage Temperature Range
ESD Susceptibility
(Note 2)
2
C /W
C /W
C
C
C
kV
Note 1: Exceeding these Absolute Maximum Ratings may damage the device. Recommended Operating
Range indicates conditions for which the device is functional. Electrical Characteristics state DC and AC
electrical specifications under particular test conditions which guarantee specific performance limits. This
assumes that the device is within the Operating Range. Specifications are not guaranteed for parameters
where no limit is given, however, the typical value is a good indication of device performance.
Note 2: Human body model, 100pF discharged through a 1.5kΩ resistor.
WWW.CRPOWTECH.COM
Page 2
PT4121E
LED Controller
ELECTRICAL CHARACTERISTICS
(Note 3)
o
The following specifications apply for VIN=24V, TA=25 C, unless specified otherwise.
SYMBOL
ITEMS
VIN
CONDITIONS
Input Voltage
VCC
UVLO hysterisis
FSW
Typ.
6
Internal Regulated Voltage
VUVLO_HYS
Min.
4.5
VCC falling
Max. Switching Frequency
5.0
Max.
UNIT
60
V
5.5
V
0.3
V
1
MHz
Current Sense
VCSN
Current sense threshold voltage
VCSN_HYS
VIN-VCSN
Nominal
194
Sense threshold hysteresis
ICSN
CSN Pin input current
VIN-VCSN=50mV
200
206
mV
±15
8
µA
Operating Current
ISD
Shutdown supply current
Quiescent supply current with
IOFF
output off
60
100
µA
No switching
0.16
0.3
mA
DIM floating
4.2
DIM Input
VDIM
Internal supply voltage
VDIM_H
DIM input voltage High
VDIM_L
DIM input voltage Low
VDIM_HYS
RDIM
V
2.5
DIM input voltage hysterisis
DIM pull up resistor to Internal
supply voltage
50
0.3
V
80
mV
200
KΩ
IDIM_H
DIM input leakage high
VDIM=5V
2.8
µA
IDIM_L
DIM input leakage low
VDIM = 0
22
µA
Gate driver source resistor
VGS=5.0V
6
Ω
2
Ω
4.8
V
Driver
R_source
R_sink
Gate driver sink resistor
VOH
Gate driver output-voltage high
IDRV=10mA
VOL
Gate driver output-voltage low
IDRV=10mA
0.5
V
Output Switch
TON_MIN
Minimum on time
Guarantee by
100
nS
TOFF_MIN
Minimun off time
Designer
100
nS
140
150
Thermal Shutdown
TREG
TSD
Note 3:
Thermal Regulation
Temperature
Thermal Shutdown Temperature
Datasheet min/max specification limits are guaranteed by design, test, or statistical analysis.
WWW.CRPOWTECH.COM
Page 3
PT4121E
LED Controller
SIMPLIFIED BLOCK DIAGRAM
REGULATOR
VIN
VCC
CS
CURRENT
SENSE COMPARATOR
Thermal
Derating
REFERENCE
GATE
DRIVER
DRV
UVLO
COMPARATOR
GND
DIM
BUFFER
DIM
OPERATION DESCRIPTION
The PT4121E in conjunction with current
sense resistor. The PT4121E allows dimming
sense resistor (RCS),the inductor (L1), and
with a PWM signal at the DIM input. A logic level
MOSFET
below 0.3V at DIM forces PT4121E to turn off the
forms
a
self
oscillating
continuous-mode buck converter.
LED and the logic level at DIM must be at least
When input voltage VIN is first applied, the
2.5V to turn on the full LED current. The
initial current in L1 and RCS is zero and there is
frequency of PWM dimming ranges from 100Hz
no output from the current sense circuit. Under
to 20 kHz.
this condition, the output of CS comparator is
The DIM pin can be driven by an external DC
high. This turns on switch, causing current to flow
voltage (VDIM) to adjust the output current to a
from VIN to ground, via RCS, the LED(s),L1 and
value below the nominal average value defined
external MOSFET. The current rises at a rate
by RCS. The DC voltage is valid from 0.5V to 2.5V.
determined by VIN and L1 to produce a voltage
When the DC voltage is higher than 2.5V, the
ramp (VCSN) across RCS. When (VIN-VCSN) >
output current keeps constant.
230mV, the output of CS comparator switches
Additionally, to ensure the reliability, the
low and the switch turns off. The current flowing
PT4121E is built with an over temperature
on the RCS decreases at another rate. When
protection. If the junction temperature exceeds
(VIN-VCSN) < 170mV, the switch turns on again
TREG, the device will reduce output current to
and the mean current on the LED is determined
avoid system cause to damage.
by 200mV/RCS.
The high-side current-sensing scheme and
on-board current-setting circuitry minimize the
number of external components while delivering
LED current with ±3% accuracy, using a 1%
WWW.CRPOWTECH.COM
Page 4
PT4121E
LED Controller
TYPICAL PERFORMANCE CHARACTERASTICS
VIN=24V,3LEDs,IOUT=1A,TA=25℃,unless otherwise noted.
Efficiency
Steady State
2µS/div
Input Power On
Input Power Off
2mS/div
100mS/div
EN Power On
EN Power Off
400µS/div
200µS/div
WWW.CRPOWTECH.COM
Page 5
PT4121E
LED Controller
TYPICAL PERFORMANCE CHARACTERASTICS (continued)
PWM Dimming (2KHz,50%)
PWM Dimming (2KHz,1%)
400µS/div
400µS/div
Short LED+ to LED- Protection
Short LED+ to LED- Recovery
20µS/div
20µS/div
Open LED Load Protection
Open LED Load Recovery
2mS/div
40µS/div
WWW.CRPOWTECH.COM
Page 6
PT4121E
LED Controller
Open RCS Protection
2S/div
APPLICATION NOTES
Setting nominal average output current with
cycle PWM can be applied to the DIM pin, to
external resistor RCS
adjust the output current to a value below the
The nominal average output current in the
nominal average value set by resistor RCS:
LED(s) is determined by the value of the external
I OUT
current sense resistor (RCS) connected between
VIN and CSN and is given by:
IOUT=0.2/RCS
0.2 D
RCS
(0≤D≤100%,2.5V
很抱歉,暂时无法提供与“PT4121EE23F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.22127
- 50+0.94911
- 150+0.83247
- 500+0.68699
- 3000+0.61679
- 6000+0.57780
