KH-2.54FH-1X15P-H8.5 数据手册
SPECIFICATIONS
∅1.02
RECOMMEND P.C.B LAYOUT
PCB TOLERANCE: ±0.05 (TOP VIEW)
Current Rating:
3Amps
Insulation Resistance:1000M Ω Min
Contact Resistance: 20 mΩ Max
Withstanding Voltage: AC 1000V
Operation Temperature:-40 °to+105°
Contact Material:
Brass
Standard:
PBT
Insrlator Material:
Polyester(UL 94V-0)
Contact Plating:
Gold Flash
Max.Processing Temp: 200 °C for30-60seconds
(220 °C for5seconds)
Code Description
(1) Pin Spacing:254=2.54mm
(2) Product Name:FH=Female Header
(3) No.of Rows:1=Single Row ;2=Dual Row
(4) No.of Pins Per Row:1~40
(5) Insulator Material Height:50=5.0mm;85=8.5mm
(6) Connector Type:S=Straight;R=Right Angle;M=SMT
(7)Connector Material Length:30=3.0mm;32=3.2mm
(8) Insulator Material Width: 50=5.0mm;55=5.5mm
(9) Contact Plating: G0=Gold Flash;AU15=Au 1.5u"
(10)Connector Material Type:U=U Type;Y=Y Type
(11)Insulator Material Option:
A=BK-PBT;B=BK-PA6T;C=BK-PA46;D=KB-LCP;S=Special
深圳市金航标电子有限公司
WWW.BDS666.COM
0755-83044319
UNLESS OTHEWIXE SPECIFIED TOLERANCE
X
:±0.3
X.X :±0.2
X.XX:±0.1
X°
:±5°
X.X° :±1°
X.XX°:±0.5°
CHECKED: LI BEI LIN
12/03/07
DRAWM NAME:
SIZE
REV
A4
A
CHECKED:
2.54FH
No. of DIM.A
1
GYS
1xnPin H8.5 DIP
SCALE
PROUCT NO.
UNIT
PROJECT
APPROVED:
PAGE
1/1
0.00
DIM.B
2.54
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
No. of DIM.A
DIM.B
KH-2.54FH-1X15P-H8.5 价格&库存
很抱歉,暂时无法提供与“KH-2.54FH-1X15P-H8.5”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.99879
- 50+0.79208
- 200+0.68872
- 400+0.61118
- 2400+0.51862
- 5000+0.48762
