XMP-12V
XMP-12V
    JST
    P=2.5mm
    1X12P 2.5MM
XMP-12V 数据手册
XMCONNECTOR CONNECTOR XM 2.5mm mmpitch/Crimp pitch/Crimpstyle stylewire-to-wire wire-to-wireconnectors connectors 2.5 Specifications • Current rating: 3 A AC/DC • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 500 MΩ min. • Withstanding voltage: 1,500 VAC/minute • Applicable wire: AWG #28 to #20 0.08 to 0.50 mm2 • Applicable panel thickness: 0.5 to 1.8 mm XMCONNECTOR CONNECTOR XM * In using the products,refer to "Handling Precautions for Terminals and Connectors" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. The retainer provides added protection against non-insertion or disconnection. ● ● ● ● ● Inner-housing lock Secondary retainers Housing lance Mountable on a variety of panels Contacts smoothly insert into the housings without colliding with internal obstacles ® Standards ® ® Recognized E60389 Certified LR20812 ® Panel Layout and Assembly layout ® (18 circuits) 15.5 7.9 (2 to 12 circuits) (24.4) (24.4) +0.1 A 0 +0.1 B±0.05 No. of circuits Receptacle housing +0.1 0 B±0.05 Panel hole dimensions (mm) General tolerance A+0.1 0 B±0.05 2 XMR-02V 9.3 12.6 3 XMR-03V 10.3 13.6 4 XMR-04V 12.8 16.1 5 XMR-05V 15.3 18.6 6 XMR-06V 17.8 21.1 7 XMR-07V 20.3 23.6 8 XMR-08V 22.8 26.1 9 XMR-09V 25.3 28.6 10 XMR-10V 27.8 31.1 11 XMR-11V 30.3 33.6 12 XMR-12V 32.8 36.1 18 XMR-18V 25.3 28.6 Note: 1  . Punch holes in the panel according to the sketch and table shown above. Burrs must be removed. 2. The strength of the panel must be considered when punching two or more holes. 3. The connector must be inserted from the same side as the hole is punched. 1 15.8 11.6±0.05 +0.1 0 8.2 5.5±0.05 A 0 Applicable panel thickness (mm) 0.5~1.8 XM CONNECTOR Contact Pin contact Socket contact 6.5 1.9 1.9 12.5 XM-Con 2.5 2.9 1.3 3.1 XM CONNECTOR 2.9 1.3 2.3 2.4 6.3 0.8 0.8 Applicable wire Model No. Pin contact SXM-001T-P0.6 *SXM-01T-P0.6 - Q’ty/reel mm2 AWG # Insulation O.D. (mm) SXA-001T-P0.6 0.08~0.33 28~22 0.8~1.9 7,000 8,000 SXA-01T-P0.6 0.22~0.50 24~20 1.5~1.9 7,000 8,000 SXA-001T-P0.6L 0.13~0.33 26~22 1.3~1.9 - 8,000 Socket contact Pin contact Socket contact Material and Finish Phosphor bronze, tin-plated (reflow treatment) RoHS2 compliance Note: 1. Contact JST for special products. 2. *Marked product is not UL/CSA approved. Contact SXM-001T-P0.6 SXM-01T-P0.6 Crimping machine Crimp applicator AP-K2N MKS-L Applicator Dies Crimp applicator with dies Contact MK/SXA/M-001-06 APLMK SXA/M001-06 SXA-001T-P0.6 MK/SXA/M-01-06 SXA-01T-P0.6 APLMK SXA/M01-06 Crimping machine Crimp applicator Applicator Dies Crimp applicator with dies MK/SXA/M-001-06 APLMK SXA/M001-06 AP-K2N MKS-L MK/SXA/M-01-06 APLMK SXA/M01-06 MK/SXA-001-06L APLMK SXA001-06L SXA-001T-P0.6L Note: Contact JST for fully automatic crimping applicator. Note: Contact JST for fully automatic crimping applicator. Contact position location numbers Retainer Contact position numbers are stamped Retainer Plug housing Receptacle housing 1 2 3 4 5 6 7 8 9 10 11 12 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 12 11 10 9 8 7 6 5 4 3 2 1 9 8 7 6 5 4 3 2 1 18 17 16 15 14 13 12 11 10 2 XM CONNECTOR XM-hausing Receptacle housing (for Pin contact) No. of circuits XMR-02V XMR-03V XMR-04V XMR-05V XMR-06V XMR-07V XMR-08V XMR-09V 15.5 XMR-10V XMR-11V XMR-12V XMR-18V 2 4 B A 5 2.5 2.5 B 3 6 10.8 7 20.2 7.9 10.8 (18 circuits) 8 9 20.2 10 11 12 A 10.8 20.2 Q’ty/bag 2.5 8.9 1,000 5.0 9.9 1,000 7.5 12.4 500 10.0 14.9 500 12.5 17.4 500 15.0 19.9 500 17.5 22.4 500 20.0 24.9 500 22.5 27.4 500 25.0 29.9 500 27.5 32.4 500 20.0 24.9 500 Material and Finish 2.5 B A 2.5 18 7.9 Dimensions (mm) A B Model No. A (2 to 12 circuits) PA 66, UL94V-0 RoHS2 compliance Note: Receptacle housings without panel lock device are also available for 2, 3, 4, 6, 7, 8 and 9 circuits. 15.5 XM-hausing-Plug Plug housing (for Socket contact) No. of circuits (2 to 12 circuits) 2 3 2.5 5 6 7 6.3 7.7 11.5 12.0 (18 circuits) 8 13.7 14.6 9 10 11 12 11.5 12.0 13.7 14.6 Q’ty/bag 2.5 8.8 1,000 5.0 9.8 1,000 7.5 12.3 1,000 10.0 14.8 500 12.5 17.3 500 15.0 19.8 500 17.5 22.3 500 20.0 24.8 500 22.5 27.3 500 25.0 29.8 500 27.5 32.3 500 20.0 24.8 500 Material and Finish 2.5 2.5 A B A B 18 6.3 7.7 XMP-02V XMP-03V XMP-04V XMP-05V XMP-06V XMP-07V XMP-08V XMP-09V XMP-10V XMP-11V XMP-12V XMP-18V A B A B 4 2.5 11.5 12.0 Dimensions (mm) A B Model No. PA 66, UL94V-0 RoHS2 compliance XM-Reta Retainer No. of circuits 2 3 4 5 6 2.5 A 7 8 9・18 10 11 7.8 0.95 2.5 12 Model No. XMS-02V XMS-03V XMS-04V XMS-05V XMS-06V XMS-07V XMS-08V XMS-09V XMS-10V XMS-11V XMS-12V Dimensions A (mm) Q’ty/bag 2.5 1,000 5.0 1,000 7.5 1,000 10.0 1,000 12.5 1,000 15.0 1,000 17.5 1,000 20.0 1,000 22.5 1,000 25.0 1,000 27.5 1,000 Material and Finish Glass-filled PA 66, UL94V-0 3 RoHS2 compliance Note: Commonly used for 9-circuit and 18-circuit housings.
XMP-12V 价格&库存
很抱歉,暂时无法提供与“XMP-12V”相匹配的价格&库存,您可以联系我们找货
XMP-12V
    • 1+2.061271+0.26668
    • 10+1.5284910+0.19775
    • 50+1.1616550+0.15029
    • 100+1.09178100+0.14125
    • 500+1.03064500+0.13334
    • 1000+1.004441000+0.12995
    • 2000+0.995702000+0.12882
    库存:327
    XMP-12V
      • 1+1.510141+0.19538
      • 100+1.44376100+0.18679
      • 300+1.09527300+0.14171
      • 500+1.02889500+0.13312
      • 1000+0.979111000+0.12668
      • 4000+0.937624000+0.12131
      • 5000+0.937625000+0.12131
      库存:174
      XMP-12V
        库存:980
        XMP-12V
          库存:403
          XMP-12V
            库存:2000
