MMSZ13VCW
MMSZ13VCW
    YONGYUTAI(永裕泰)
    SOD123
    MMSZ13VCW
MMSZ13VCW 数据手册
MMSZxxxCW SOD-123 Plastic-Encapsulate Zener Diode SOD-123 特征 Features  齐纳击穿阻抗低; Low Zener Impedance  最大功率耗散 500mW; Power Dissipation of 500mW  高稳定性和可靠性。High Stability and High Reliability 机械数据 Mechanical Data     封装: SOD-123 封装 SOD-123 Small Outline Plastic Package 极性: 色环端为负极 Polarity: Color band denotes cathode end 环氧树脂 UL 易燃等级 Epoxy UL: 94V-0 安装位置: 任意 Mounting Position: Any 极限值和温度特性(TA = 25℃ 除非另有规定) Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.) 参数 Parameters 符号 Symbol 数值 Value 单位 Unit 功率消耗 Power Dissipation Pd 500 1) mW 正向压降 Forward Voltage @IF=10mA Vf 0.9 2) V 存储温度 Storage temperature range Ts -65-+150 ℃ RthA 400 K/W Thermal resistance junction to ambient air Warmewiderstand Sperrschicht 1) –umgebende Luft 1) 2) 3) Device mounted on ceramic PCB: 7.6mm x 9.4mm x 0.87mm with pad areas 25mm² Short duration test pulse used to minimize self-heating effect f=1KHz 电特性 (TA = 25℃ 除非另有规定) Electrical Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified). Zener Voltage Range Device Marking Vz@Izt Izt Nom(V) Min(V) Max(V) mA Maximum Zener 3) Impedance Zzt Zzk Izk @Izt @Izk mA Ω Maximum Reverse Current IR VR uA V Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC mA MMSZ2V0CW WY 2.0 1.80 2.15 5 150 600 1.0 100 1.0 -3.5 0 5 MMSZ2V4CW WX 2.4 2.2 2.6 5 100 600 1.0 50 1.0 -3.5 0 5 MMSZ2V7CW W1 2.7 2.5 2.9 5 100 600 1.0 20 1.0 -3.5 0 5 MMSZ3V0CW W2 3.0 2.8 3.2 5 95 600 1.0 10 1.0 -3.5 0 5 MMSZ3V3CW W3 3.3 3.1 3.5 5 95 600 1.0 5 1.0 -3.5 0 5 MMSZ3V6CW W4 3.6 3.4 3.8 5 90 600 1.0 5 1.0 -3.5 0 5 MMSZ3V9CW W5 3.9 3.7 4.1 5 90 600 1.0 3 1.0 -3.5 0 5 MMSZ4V3CW W6 4.3 4.0 4.6 5 90 600 1.0 3 1.0 -3.5 0 5 MMSZ4V7CW W7 4.7 4.4 5.0 5 80 500 1.0 3 2.0 -3.5 0.2 5 MMSZ5V1CW W8 5.1 4.8 5.4 5 60 480 1.0 2 2.0 -2.7 1.2 5 MMSZ5V6CW W9 5.6 5.2 6.0 5 40 400 1.0 1 2.0 -2.0 2.5 5 MMSZ6V2CW WA 6.2 5.8 6.6 5 10 150 1.0 3 4.0 0.4 3.7 5 MMSZ6V8CW WB 6.8 6.4 7.2 5 15 80 1.0 2 4.0 1.2 4.5 5 MMSZ7V5CW WC 7.5 7.0 7.9 5 15 80 1.0 1 5.0 2.5 5.3 5 MMSZ8V2CW WD 8.2 7.7 8.7 5 15 80 1.0 0.7 5.0 3.2 6.2 5 MMSZ9V1CW WE 9.1 8.5 9.6 5 15 100 1.0 0.5 6.0 3.8 7.0 5 MMSZ10VCW WF 10 9.4 10.6 5 20 150 1.0 0.2 7.0 4.5 8.0 5 www.yongyutai.com PAGE 1 MMSZxxxCW Zener Voltage Range Device Marking Vz@Izt Izt Nom(V) Min(V) Max(V) mA Maximum Zener Impedance Zzt Zzk Izk @Izt @Izk mA Ω Maximum Reverse Current IR VR uA V Typical Temperature coefficent @ IZTC=mV/℃ Min Max Test Current IZTC mA MMSZ11VCW WG 11 10.4 11.6 5 20 150 1.0 0.1 8.0 5.4 9.0 5 MMSZ12VCW WH 12 11.4 12.7 5 25 150 1.0 0.1 8.0 6.0 10.0 5 MMSZ13VCW WI 13 12.4 14.1 5 30 170 1.0 0.1 8.0 7.0 11.0 5 MMSZ15VCW WJ 15 13.8 15.6 5 30 200 1.0 0.1 10.5 9.2 13.0 5 MMSZ16VCW WK 16 15.3 17.1 5 40 200 1.0 0.1 11.2 10.4 14.0 5 MMSZ18VCW WL 18 16.8 19.1 5 45 225 1.0 0.1 12.6 12.4 16.0 5 MMSZ20VCW WM 20 18.8 21.2 5 55 225 1.0 0.1 14.0 14.4 18.0 5 MMSZ22VCW WN 22 20.8 23.3 5 55 250 1.0 0.1 15.4 16.4 20.0 5 MMSZ24VCW WO 24 22.8 25.6 5 70 250 1.0 0.1 16.8 18.4 22.0 5 MMSZ27VCW WP 27 25.1 28.9 2 80 300 0.5 0.1 18.9 21.4 25.3 2 MMSZ30VCW WQ 30 28.0 32.0 2 80 300 0.5 0.1 21.0 24.4 29.4 2 MMSZ33VCW WR 33 31.0 35.0 2 80 325 0.5 0.1 23.1 27.4 33.4 2 MMSZ36VCW WS 36 34.0 38.0 2 90 350 0.5 0.1 25.2 30.4 37.4 2 MMSZ39VCW WT 39 37.0 41.0 2 130 350 0.5 0.1 27.3 33.4 41.2 2 MMSZ43VCW WU 43 40.0 46.0 2 100 700 1.0 0.1 32.0 10.0 12.0 5 MMSZ47VCW WV 47 44.0 50.0 2 100 750 1.0 0.1 35.0 10.0 12.0 5 MMSZ51VCW WW 51 48.0 54.0 2 125 750 1.0 0.1 38.0 10.0 12.0 5 MMSZ56VCW XW 56 52.0 60.0 2 135 700 1.0 0.1 39.0 10.0 12.0 5 MMSZ62VCW 6E 62 58.0 66.0 2 200 1000 1.0 0.2 47.0 10.0 12.0 5 MMSZ68VCW 6F 68 64.0 72.0 2 250 1000 1.0 0.2 52.0 10.0 12.0 5 MMSZ75VCW 6H 75 70.0 79.0 2 300 1000 1.0 0.2 57 10.0 12.0 5 Breakdown characteristics at Tj=constant (pulsed) Forward characteristics www.yongyutai.com Admissible power dissipation versus ambient temperature PAGE 2 MMSZxxxCW Pulse thermal resistance versus pulse duration Dynamic resistance versus Zener current Capacitance versus Zener voltage Dynamic resistance versus Zener current Dynamic resistance versus Zener current Thermal differential resistance versus Zener voltage www.yongyutai.com PAGE 3 MMSZxxxCW Dynamic resistance versus Zener voltage Temperature dependence of Zener voltage versus Zener voltage Temperature dependence of Zener voltage versus Zener voltage Change of Zener voltage versus junction temperature Change of Zener voltage versus junction temperature Change of Zener voltge from turn-on up to the point of thermal equilibrium versus Zener voltage www.yongyutai.com PAGE 4 MMSZxxxCW SOD-123 PACKAGE OUTLINE Plastic surface mounted package θ θ 焊盘设计参考 Precautions: PCB Design Recommended land dimensions for SOD-123 diode. Electrode patterns for PCBs 技术要求: 3.24 1.0 中心距: 3.24 1, 塑封体尺寸: 2.70 X 1.60 脚 宽: 0.55 2: 未注公差为: ±0.05 焊盘宽: 1.00 3, 所有单位: mm 脚 长: 0.50 焊盘长: 0.80 0.8 www.yongyutai.com PAGE 5
MMSZ13VCW 价格&库存
很抱歉,暂时无法提供与“MMSZ13VCW”相匹配的价格&库存,您可以联系我们找货
