K1812L Series
Features
◆ Surface Mount Devices
◆ Standard 4532mm(1812mils) footprint
◆ Surface mount packaging for automated assembly
◆ Compatible with Pb and Pb-free solder Re flow profiles.
◆ UL(E352136), C-UL(E352136), TUV(R50322001)
◆ RoHS, Reach, HF compliance
Applications
◆ Over current and over temperature protection of automotive electronics
◆ PC motherboards, Hard disk driver, and PC peripherals
◆ POS Equipment
◆ USB port protection
◆ HDMI source protection
电气特性 :
保持电流
跳脱电流
最大电压
最大电流
最大动作时间
消耗功率
IH, (A)
IT, (A)
V max, (V)
K1812L010DR
0.10
0.30
60
K1812L014DR
0.14
0.34
K1812L020DR
0.20
K1812L020/60DR
0.20
K1812L030DR
0.30
电阻范围(Ω)
I max, (A)
(A)
(Sec.)
Pd typ, (W)
R min,
R1 max,
10
0.5
1.50
0.8
0.700
15.00
60
10
1.5
0.15
0.8
0.400
6.50
0.40
30
10
8.0
0.20
0.8
0.750
5.00
0.40
60
10
1.5
0.15
0.8
0.400
6.000
0.60
30
10
8.0
0.10
0.8
0.300
3.000
P/N
K1812L035PR
0.35
0.70
16
40
8.0
0.10
0.8
0.200
1.800
K1812L050PR
0.50
1.00
15
40
8.0
0.15
0.8
0.150
1.000
K1812L075PR
0.75
1.50
16
40
8.0
0.20
0.8
0.110
0.450
K1812L075/24PR
0.75
1.50
24
40
8.0
0.20
0.8
0.110
0.450
K1812L075/33PR
0.75
1.50
33
40
8.0
0.20
0.8
0.110
0.450
K1812L110PR
1.10
2.20
6
100
8.0
0.30
0.8
0.040
0.225
K1812L110/16PR
1.10
2.20
16
100
8.0
0.50
0.8
0.040
0.225
K1812L110/24DR
1.10
2.20
24
100
8.0
0.50
1.2
0.055
0.180
K1812L125PR
1.25
2.50
6
40
8.0
0.40
0.8
0.035
0.140
K1812L150PR
1.50
3.00
6
100
8.0
0.50
0.8
0.030
0.120
K1812L150/12PR
1.50
3.00
12
100
8.0
0.50
1.0
0.030
0.120
K1812L150/16PR
1.50
3.00
16
100
8.0
0.50
0.8
0.030
0.120
K1812L150/24MR
1.50
3.00
24
100
8.0
1.50
1.2
0.030
0.140
K1812L160PR
1.60
3.20
8
100
8.0
1.00
1.0
0.025
0.120
K1812L160/12PR
1.60
3.20
12
100
8.0
1.00
1.0
0.025
0.120
K1812L160/16PR
1.60
3.20
16
40
8.0
1.00
1.0
0.025
0.120
K1812L200DR
2.00
4.00
8
100
8.0
3.00
1.2
0.020
0.080
K1812L250/16DR
2.50
5.00
16
100
8.0
5.00
1.2
0.015
0.100
K1812L260DR
2.60
5.20
6
100
8.0
5.00
1.2
0.015
0.080
K1812L300DR
3.00
6.00
6
100
8.0
5.00
1.2
0.012
0.060
1/3
K1812L Series
产品尺寸 (U nit: mm) :
Top and Bottom View
Side View
C
A
T020
T 020
B
Manufacturer's Trademark
Part Identification
D
A
B
C
D
Marking
(标识)
Min.
Max.
Min.
Max.
Min.
Max.
Min.
K1812L010DR
T010
4.37
4.73
3.07
3.41
0.80
1.20
0.30
K1812L014DR
T014
4.37
4.73
3.07
3.41
0.80
1.20
0.30
K1812L020DR
T020
4.37
4.73
3.07
3.41
0.80
1.20
0.30
K1812L020/60DR
T020
4.37
4.73
3.07
3.41
0.80
1.20
0.30
K1812L030DR
T030
4.37
4.73
3.07
3.41
0.80
1.20
0.30
K1812L035PR
T035
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L050PR
T050
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L075PR
T075
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L075/24PR
T075
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L075/33PR
T075
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L110PR
T110
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L110/16PR
T110
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L110/24DR
T110
4.37
4.73
3.07
3.41
0.80
1.20
0.30
K1812L125PR
T125
4.37
4.73
3.07
3.41
0.45
0.85
0.30
3.07
3.41
0.45
0.85
0.30
P/N
K1812L150PR
T150
4.37
4.73
K1812L150/12PR
T150
4.37
4.73
3.07
3.41
0.45
0.85
0.30
K1812L150/16PR
T150
4.37
4.73
3.07
3.41
0.45
0.85
0.30
3.07
3.41
1.20
1.70
0.30
K1812L150/24MR
T150
4.37
4.73
K1812L160PR
T160
4.37
4.73
3.07
3.41
0.45
0.85
0.30
K1812L160/12PR
T160
4.37
4.73
3.07
3.41
0.45
0.85
0.30
3.07
3.41
0.45
0.85
0.30
K1812L160/16PR
T160
4.37
4.73
K1812L200DR
T200
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L250/16DR
T250
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L260DR
T260
4.37
4.73
3.07
3.41
0.60
1.00
0.30
K1812L300DR
T300
4.37
4.73
3.07
3.41
0.60
1.00
0.30
2/3
K1812L Series
环境温度与工作电流关系特性曲线 :
工作环境温度
P/N
-40℃
-20℃
0℃
25℃
40℃
50℃
60℃
70℃
85℃
K1812L010DR
0.16
0.14
0.12
0.10
0.08
0.07
0.06
0.05
0.03
K1812L014DR
0.23
0.19
0.17
0.14
0.12
0.10
0.09
0.08
0.06
K1812L020DR
0.29
0.26
0.23
0.20
0.17
0.15
0.14
0.12
0.10
K1812L020/60DR
0.29
0.26
0.23
0.20
0.17
0.15
0.14
0.12
0.10
K1812L030DR
0.44
0.39
0.35
0.30
0.26
0.23
0.21
0.18
0.15
K1812L035PR
0.51
0.46
0.41
0.35
0.30
0.27
0.25
0.21
0.18
K1812L050PR
0.77
0.68
0.59
0.50
0.44
0.40
0.37
0.33
0.29
K1812L075PR
1.15
1.01
0.88
0.75
0.65
0.60
0.55
0.49
0.43
K1812L075/24PR
1.15
1.01
0.88
0.75
0.65
0.60
0.55
0.49
0.43
K1812L075/33PR
1.15
1.01
0.88
0.75
0.65
0.60
0.55
0.49
0.43
K1812L110PR
1.59
1.43
1.26
1.10
0.95
0.87
0.80
0.71
0.60
K1812L110/16PR
1.59
1.43
1.26
1.10
0.95
0.87
0.80
0.71
0.60
K1812L110/24DR
2.00
1.70
1.40
1.10
0.95
0.88
0.80
0.73
0.61
K1812L125PR
1.80
1.63
1.43
1.25
1.08
0.99
0.91
0.81
0.68
K1812L150PR
2.17
1.95
1.72
1.50
1.30
1.18
1.09
0.97
0.82
K1812L150/12PR
2.17
1.95
1.72
1.50
1.30
1.18
1.09
0.97
0.82
K1812L150/16PR
2.17
1.95
1.72
1.50
1.30
1.18
1.09
0.97
0.82
K1812L150/24MR
2.17
1.95
1.72
1.50
1.30
1.18
1.09
0.97
0.82
K1812L160PR
2.30
2.20
1.90
1.60
1.45
1.30
1.15
1.03
0.91
K1812L160/12PR
2.30
2.20
1.90
1.60
1.45
1.30
1.15
1.03
0.91
K1812L160/16PR
2.30
2.20
1.90
1.60
1.45
1.30
1.15
1.03
0.91
K1812L200DR
3.08
2.71
2.35
2.00
1.80
1.60
1.50
1.40
1.25
K1812L250/16DR
3.85
3.45
3.00
2.50
2.05
1.85
1.75
1.30
1.10
K1812L260DR
4.00
3.52
3.06
2.60
2.34
2.08
1.95
1.39
1.04
K1812L300DR
4.40
3.90
3.50
3.00
2.60
2.30
2.10
1.80
1.50
动作电流时间曲线表 :
The Time to Trip curves represent typical performance
of a device in a simulated application environment.
Actual performance in specific customer applications
may differ from these values due to the influence of
other variables.
3/3
很抱歉,暂时无法提供与“K1812L020DR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.33264
- 100+0.26525
- 300+0.23156
- 1500+0.19289
- 4500+0.17270
- 10500+0.16254
