K1206L Series
Features
◆ Surface Mount Devices
◆ Standard 3216mm(1206mils) footprint
◆ Surface mount packaging for automated assembly
◆ Compatible with Pb and Pb-free solder Re flow profiles.
◆ UL(E352136), C-UL(E352136), TUV(R50306075)
◆ RoHS, Reach, HF compliance
Applications
◆ Mobile phones- Battery and port protection
◆ PC motherboards - Plug and Play protection
◆ PDAS/Digital cameras
◆ USB port protection
◆ HDMI source protection
◆ Game console port protection
电气特性 :
保持电流
跳脱电流
最大电压
最大电流
最大动作时间
消耗功率
电阻范围(Ω)
IH, (A)
IT, (A)
V max, (V)
I max, (A)
(A)
(Sec.)
Pd typ, (W)
R min,
R1 max,
P/N
K1206L005AR
K1206L010AR
K1206L012AR
K1206L020YR
K1206L025YR
K1206L035YR
K1206L050YR
K1206L075YR
K1206L100AR
K1206L110AR
K1206L150AR
K1206L200AR
0.05
0.15
30
10
0.25
1.50
0.40
2.500
40.00
0.10
0.25
30
10
0.50
1.20
0.40
1.400
15.00
0.12
0.29
30
10
1.00
0.20
0.40
1.350
8.500
0.20
0.46
24
10
1.00
0.60
0.60
0.600
2.600
0.25
0.55
16
10
1.25
0.60
0.60
0.400
2.400
0.35
0.75
6
40
8.00
0.10
0.60
0.300
1.200
0.50
1.00
13.2
40
8.00
0.10
0.40
0.150
0.750
0.75
1.50
6
100
8.00
0.10
0.40
0.100
0.400
1.00
2.00
6
100
8.00
0.10
0.60
0.060
0.280
1.10
2.20
6
100
8.00
0.10
0.60
0.060
0.280
1.50
3.00
6
100
8.00
0.30
0.60
0.030
0.170
2.00
4.00
6
100
8.00
1.00
0.70
0.020
0.120
产品尺寸 (U nit: mm) :
A
Top and Bottom View
Side View
T02
B
D
T 02
Manufacturer's Trademark
Part Identification
C
D
Min.
Max.
Min.
Max.
Min.
Max.
Min.
K1206L005AR
T0
3.00
3.40
1.40
1.80
0.80
1.20
0.25
K1206L010AR
T1
3.00
3.40
1.40
1.80
0.80
1.20
0.25
K1206L012AR
T01
3.00
3.40
1.40
1.80
0.80
1.20
0.25
K1206L020YR
T02
3.00
3.40
1.40
1.80
0.60
1.00
0.25
K1206L025YR
T03
3.00
3.40
1.40
1.80
0.60
1.00
0.25
K1206L035YR
T04
3.00
3.40
1.40
1.80
0.60
1.00
0.25
K1206L050YR
T05
3.00
3.40
1.40
1.80
0.55
0.75
0.25
K1206L075YR
T07
3.00
3.40
1.40
1.80
0.45
0.85
0.25
K1206L100AR
T10
3.00
3.40
1.40
1.80
0.60
1.00
0.25
K1206L110AR
T10
3.00
3.40
1.40
1.80
0.60
1.00
0.25
K1206L150AR
T15
3.00
3.40
1.40
1.80
0.60
1.00
0.25
K1206L200AR
T20
3.00
3.50
1.40
1.80
0.60
1.00
0.25
C
A
B
Marking
(标识)
P/N
1/2
K1206L Series
环境温度与工作电流关系特性曲线 :
工作环境温度
P/N
K1206L005AR
K1206L010AR
K1206L012AR
K1206L020YR
K1206L025YR
K1206L035YR
K1206L050YR
K1206L075YR
K1206L100AR
K1206L110AR
K1206L150AR
K1206L200AR
-40℃
-20℃
0℃
25℃
40℃
50℃
60℃
70℃
85℃
0.08
0.07
0.06
0.05
0.05
0.04
0.04
0.03
0.03
0.16
0.14
0.13
0.10
0.09
0.08
0.08
0.07
0.06
0.19
0.17
0.15
0.12
0.11
0.10
0.09
0.08
0.07
0.30
0.27
0.24
0.20
0.18
0.16
0.14
0.12
0.11
0.38
0.34
0.30
0.25
0.23
0.20
0.18
0.15
0.14
0.51
0.46
0.40
0.35
0.30
0.27
0.24
0.22
0.18
0.76
0.68
0.59
0.50
0.44
0.40
0.35
0.32
0.26
1.11
1.00
0.85
0.75
0.67
0.61
0.52
0.50
0.42
1.60
1.40
1.30
1.00
0.90
0.80
0.75
0.70
0.60
1.64
1.46
1.30
1.10
0.92
0.83
0.80
0.65
0.52
2.20
1.99
1.77
1.50
1.34
1.23
1.10
1.01
0.84
2.88
2.61
2.28
2.00
1.80
1.66
1.51
1.39
1.19
动作电流时间曲线表 :
The Time to Trip curves represent typical performance
of a device in a simulated application environment.
Actual performance in specific customer applications
may differ from these values due to the influence of
other variables.
标准包装数量 :
Model
Q’t y/Reel
K1206L005AR~K1206L012AR K1206L100AR~K1206L200AR
K1206L020AYR~K1206L075YR
Note: Reel packaging per EIA-481-1 standard
2/2
3500pcs
4000pcs
很抱歉,暂时无法提供与“K1206L010AR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.29920
- 200+0.19250
- 1750+0.16830
- 3500+0.14740
- 国内价格
- 10+0.31355
- 100+0.25445
- 300+0.22490
- 1000+0.20274
- 3500+0.16950
- 10500+0.16058
