BTR9S23A10-MS
BTR9S23A10-MS
    MSKSEMI(美森科)
    SOD-923
    C 双向ESD 5V截止 峰值浪涌电流:5A
BTR9S23A10-MS 数据手册
www.msksemi.com BTR9S23A10-MS Semiconductor Compiance SOD-923 ◇ ◇ ◇ ◇ ◇ ◇ ◇ Bi-Directional Transient Voltage Suppressor Low capacitance and Low Leakage ESD Protection, IEC61000-4-2 Level 4 SOD923 SMD RoHS compliant UL-94 V-0 / Green EMC Matte Tin Lead finish (Pb-Free) Ordering Information P/N BTR9S23A10-MS Package Shipping SOD923 Tape & Reel 8000pcs /7” Reel Tape wide Emboss pitch Tape specification 8 mm 2 mm Conductive Notes Absolute Maximum Ratings (Ta = 25 ℃) Symbol IPP *1 Parameter Units 5.0 A ESD Voltage IEC61000-4-2 Air ±15 kV ESD Voltage IEC61000-4-2 Contact ±8 kV Junction Temperature 150 ℃ Storage Temperature -55 to +150 ℃ 150 mW Maximum Reverse Peak Pulse Current VESD-Air VESD-contact TJ TSTG PD *1 t P Value Power Dissipation =8/20μs Electrical Characteristics (Ta = 25 ℃) Symbol Parameter Conditions VRWM Reverse Working Peak Voltage - VBR Reverse Breakdown Voltage Pin 1 to 2 IT = 1mA IR Reverse Current VRWM = ±5V CD Diode Capacitance VR = 0V, f = 1MHz Min Typ 5.6 13 Max Units 5.0 V 8.2 V 1.0 μA pF www.msksemi.com BTR9S23A10-MS Semiconductor Compiance Electrical Parameter Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM IR Working Peak Reverse Voltage Maximum Reverse Leakage Current @ VRWM IT Test Current VBR Breakdown Voltage @ IT FIG1: Pulse Waveform FIG2:Power Derating www.msksemi.com BTR9S23A10-MS Semiconductor Compiance PACKAGE MECHANICAL DATA Dim Millimeters Inches Min Nom Max Min Nom Max A 0.36 0.40 0.43 0.014 0.016 0.017 b 0.15 0.20 0.25 0.006 0.008 0.010 c 0.07 0.12 0.17 0.003 0.005 0.007 D 0.75 0.80 0.85 0.030 0.031 0.033 E 0.55 0.60 0.65 0.022 0.024 0.026 HE 0.95 1.00 1.05 0.037 0.039 0.041 L 0.05 0.10 0.15 0.002 0.004 0.006 Dimensions: Millimeters REEL SPECIFICATION P/N BTR9S23A10-MS PKG SOD-923 QTY 8000 www.msksemi.com BTR9S23A10-MS Semiconductor Compiance Attention ■ Any and all MSKSEMI Semiconductor products described or contained herein do not have specifications that can handle applications that require extremely high levels of reliability, such as life-support systems, aircraft's control systems, or other applications whose failure can be reasonably expected to result in serious physical and/or material damage. Consult with your MSKSEMI Semiconductor representative nearest you before using any MSKSEMI Semiconductor products described or contained herein in such applications. ■ MSKSEMI Semiconductor assumes no responsibility for equipment failures that result from using products at values that exceed, even momentarily, rated values (such as maximum ratings, operating condition ranges, or other parameters) listed in products specificationsof any andall MSKSEMI Semiconductor products described orcontained herein. ■ Specifications of any and all MSKSEMI Semiconductor products described or contained herein stipulate the performance, characteristics, and functions of the described products in the independent state, and are not guarantees of the performance, characteristics, and functions of the described products as mounted in the customer’s products or equipment. To verify symptoms and states that cannot be evaluated in an independent device, the customer should always evaluate and test devices mounted in the customer’sproducts orequipment. ■ MSKSEMI Semiconductor. strives to supply high-quality high-reliability products. However, any and all semiconductor products fail with someprobability. It is possiblethat these probabilistic failures could give rise to accidents or events that could endanger human lives, that could give rise to smoke or fire, or that could cause damage to other property. When designing equipment, adopt safety measures so that these kinds of accidents or events cannot occur. Such measures include but are not limited to protective circuits anderror prevention circuitsfor safedesign, redundant design, and structural design. ■ In the event that any or all MSKSEMI Semiconductor products(including technical data, services) described or contained herein are controlled under any of applicable local export control laws and regulations, such products must not be exported without obtaining the export license from theauthorities concerned in accordance with the above law. ■ No part of this publication may be reproduced or transmitted in any form or by any means, electronic or mechanical, including photocopying and recording, or any information storage or retrieval system, or otherwise, without the prior written permission of MSKSEMI Semiconductor. ■ Information (including circuit diagrams and circuit parameters) herein is for example only ; it is not guaranteed for volume production. MSKSEMI Semiconductor believes information herein is accurate and reliable, but no guarantees are made or implied regarding its use or any infringementsof intellectual property rights or other rightsof third parties. ■ Any and all information described or contained herein are subject to change without notice due to product/technology improvement, etc. Whendesigning equipment, referto the "Delivery Specification" for the MSKSEMI Semiconductor productthat you intend to use. www.msksemi.com
BTR9S23A10-MS
物料型号:BTR9S23A10-MS
器件简介: - 双向瞬态电压抑制器 - 低电容和低漏电流 - 符合IEC61000-4-2 Level 4的ESD保护 - SOD923 SMD封装,RoHS合规 - UL-94 V-0 / Green EMC - 无铅的亚光锡铅镀层
引脚分配:SOD-923封装,未明确列出引脚分配,但通常SOD923封装有2个引脚。
参数特性: - 最大反向峰值脉冲电流:5.0A - 空气ESD电压:±15kV - 接触ESD电压:±8kV - 结温:150°C - 存储温度:-55至+150°C - 功率耗散:150mW
功能详解: - 工作峰值反向电压:5.0V - 反向击穿电压:5.6V至8.2V - 反向电流:1.0μA - 二极管电容:13pF
应用信息: - 该器件不适用于需要极高可靠性的应用,如生命支持系统、飞机控制系统等。
封装信息: - 封装尺寸数据和建议的焊盘布局。
BTR9S23A10-MS 价格&库存
很抱歉,暂时无法提供与“BTR9S23A10-MS”相匹配的价格&库存,您可以联系我们找货
BTR9S23A10-MS
  • 20+0.23307
  • 200+0.19127
  • 600+0.16816
  • 2000+0.15423
  • 8000+0.10692
  • 16000+0.10044
库存:1913
