1N4148WT
特征 Features
小尺寸封装 Small Package
低反向电流 Low Reverse Current
开关速度快 Fast Switching Speed
适用于自动插件的理想的表贴封装 Surface Mount Package Ideally
Suited for Automatic Insertion
机械数据 Mechanical Data
MARKING: T4
封装: SOD-523 封 装 SOD-523 Small Outline Plastic Package
极性: 色环端为负极Polarity: Color band denotes cathode end
环氧树脂UL 易燃等级Epoxy UL: 94V-0
安装位置: 任意 Mounting Position: Any
极限值和温度特性(TA = 25℃ 除非另有规定)
Maximum Ratings & Thermal Characteristics (Ratings at 25℃ ambient temperature unless otherwise specified.)
参数 Parameters
符号Symbol
数值 Value
单位Unit
反向不重复峰值电压Non-Repetitive Peak Reverse Voltage
VRM
100
V
反向电压Reverse Voltage
VR
75
V
VR(RMS)
53
V
平均整流输出电流Average Rectified Output Current
IO
150
mA
正向连续电流Forward Continuous Current
IFM
300
mA
尖峰正向不重复浪涌电流Non-repetitive Peak Forward Surge
Current@t= 8.3ms
功率消耗Power Dissipation
IFSM
2.0
A
Pd
150
mW
Tj
150
存储温度Storage temperature range
TSTG
-55-+150
热阻Thermal Resistance from Junction to Ambient
RθJA
833
℃/W
峰值重复反向电压Peak Repetitive Reverse Voltage
VRRM
反向峰值工作电压Working Peak Reverse Voltage
VRWM
均方根反向电压RMS Reverse Voltage
结温Junction temperature
电特性 Electrical Characteristics (Ratings at 25℃
ambient temperature unless otherwise specified).
界限 Limits
符号
参数
测试条件
Symbols
Parameter
Test Condition
Min
IR=1uA
75
VR=20V
25
nA
VR=75
1
uA
IF=1mA
0.715
正向电压
IF=10mA
0.855
Forward Voltage
IF=50mA
1
IF=150mA
1.25
V(BR)
IR
VF
TRR
反向击穿电压
Breakdown Voltage
反向漏电电流
Reverse Leakage Current
反向恢复时间
IF = IR = 10mA,
Reverse Recovery Time
Irr=0.1*IR,
单位
Max
Unit
V
V
4
nS
2
pF
RL=100Ω,
C
www.yongyutai.com
结电容
Capacitance
VR=0V, f=1MHZ
PAGE 1
1N4148WT
典型特性Typical Characteristics
www.yongyutai.com
PAGE 2
1N4148WT
SOD-523封装外形尺寸图 SOD-523 Package Outline Dimensions
SOD-523焊盘设计参考 SOD-523 Suggested Pad Layout
www.yongyutai.com
PAGE 3
很抱歉,暂时无法提供与“1N4148WT”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.18810
- 200+0.06248
- 1500+0.03905
- 3000+0.03113
- 国内价格
- 50+0.06649
- 500+0.05212
- 3000+0.04392
- 6000+0.03909
- 24000+0.03500
- 51000+0.03273
