VDR Varistor
07D SERIES
嵩隆力上
SONGLONG LISHANG
METAL OXIDE VARISTOR – 07D SERIES
FEATURES
* Wide operating voltage (V1mA) range from 18V to 820V.
* Fast responding to transient over-voltage.
* Large absorbing transient energy capability.
* Low clamping ratio and no follow-on current.
* Meets MSL level 1, per J-STD-020
* Safety number : CUL- E317616
VDE- 40028836
CQC-12001076478
ISO9001-2018
APPLICATION
*Transistor, Diode, IC, Thyristor or Triac semiconductor protection.
* Surge protection in consumer electronics.
* Surge protection in industrial electronics.
* Surge protection in electronic home appliances, gas and petroleum appliances.
* Relay and electromagnetic valve surge absorption.
General Characteristics Definition
*Operating Temperature:
(-40 ℃ ~ +85 ℃ )
o
( -40 ℃ ~ +125 ℃)
o
*Storage Temperature:
(-40 C ~ +125 C)
*Working Surface Temperature:
+115 C
> 100M Ω
Flame-Retardant to UL 94 V-0
o
*Insulation Resistance:
*Coating (Epoxy Resin):
Material
*Coating:
Epoxy Resin
*Lead Wire:
The Copper Wire
*Electrode:
*Disk:
Silver
Solder
Zinc Oxide
PART NUMBER CODE
VDR
Brand Mark
D
K
Element Diameter
Type: D: Disk , S: Square
Varistor Voltage
Tolerance : K±10%, L±15%
Sapce:Straight 85℃
H:125℃
C:Crimped , Y:Y kink
I:Inner,Tor G :Plaster
Lead Form :
Short leg : NO :
E: 4KV2KA S:6KV/3KA Y:10KV/5KA
=ABCDEF Times
J:High Surge & High Energy
PH=Ultra Surge
Taping : TA : Ammo, TR : Reel
Page-1
VDR Varistor
07D SERIES
嵩隆力上
SONGLONG LISHANG
Part No.
Part No.
T Max.
D Max.
VDR-07D180L
VDR-07D220K
VDR-07D270K
VDR-07D330K
VDR-07D390K
VDR-07D470K
VDR-07D560K
VDR-07D680K
VDR-07D820K
VDR-07D101K
VDR-07D121K
VDR-07D151K
VDR-07D181K
VDR-07D201K
VDR-07D221K
VDR-07D241K
VDR-07D271K
VDR-07D301K
VDR-07D331K
VDR-07D361K
VDR-07D391K
VDR-07D431K
VDR-07D471K
VDR-07D511K
VDR-07D561K
VDR-07D621K
VDR-07D681K
VDR-07D751K
VDR-07D781K
VDR-07D821K
VDR-07D180LJ
VDR-07D220KJ
VDR-07D270KJ
VDR-07D330KJ
VDR-07D390KJ
VDR-07D470KJ
VDR-07D560KJ
VDR-07D680KJ
VDR-07D820KJ
VDR-07D101KJ
VDR-07D121KJ
VDR-07D151KJ
VDR-07D181KJ
VDR-07D201KJ
VDR-07D221KJ
VDR-07D241KJ
VDR-07D271KJ
VDR-07D301KJ
VDR-07D331KJ
VDR-07D361KJ
VDR-07D391KJ
VDR-07D431KJ
VDR-07D471KJ
VDR-07D511KJ
VDR-07D561KJ
VDR-07D621KJ
VDR-07D681KJ
VDR-07D751KJ
VDR-07D781KJ
VDR-07D821KJ
4.5
4.6
4.7
4.9
4.8
4.9
5.0
5.2
4.1
4.3
4.5
4.8
4.3
4.4
4.5
4.6
4.9
5.0
5.1
5.2
5.4
5.7
6.0
6.2
6.5
7.1
7.3
7.5
7.7
8.0
9.0
H Max.
S
I/C/Y
11.0
14.0
L min.
20.0
F ±0.8 d + 0.05
5.0
0.6
Page-2
VDR Varistor
07D SERIES
嵩隆力上
SONGLONG LISHANG
ELECTRICAL CHARACTERISTIC
Part Number
Standard
High Surge
Maximum
Varistor
Withstanding
Energy
Allowable
Voltage
Maximum
Clamping
Voltage
Voltage
Surge Current
10/1000μS
AC (V) DC (V)
V1mA(V)
IP(A) VC(V)
I(A)
I(A)
I(A)
I(A)
Standard High Surge Standard High Surge
Typical
Rated Capacitance
Powe (Reference)
(W)
@1KHzPF
07D180L 07D180LJ
11
14
18(15.0~21.6)
2.5
36
250
500
0.9
2.0
0.02
2800
07D220K 07D220KJ
14
18
22(19.5~26.0)
2.5
43
250
500
1.1
2.4
0.02
2300
07D270K 07D270KJ
17
22
27(24-31)
2.5
53
250
500
1.4
3.0
0.02
1800
07D330K 07D330KJ
33(29.5~36.5)
2.5
65
250
500
1.7
3.5
0.02
1500
07D390K 07D390KJ
25
31
39(35 ~43)
2.5
77
250
500
2.1
4.0
0.02
1300
07D470K 07D470KJ
30
38
47(42~52)
2.5
93
250
500
2.5
5.0
0.02
1100
07D560K 07D560KJ
35
45
56(50~62)
2.5
110
250
500
3.1
6.0
0.02
890
07D680K 07D680KJ
40
56
68(61~75)
2.5
135
250
500
3.6
7.0
0.02
740
07D820K 07D820KJ
50
65
82(74~90)
10
135
1200
1750
5.5
10.0
0.25
600
07D101K 07D101KJ
60
85
100(90~110)
10
165
1200
1750
6.5
12.0
0.25
500
07D121K 07D121KJ
75
100 120(108~132)
10
200
1200
1750
7.8
12.0
0.25
420
07D151K 07D151KJ
95
125 150(135~165)
10
250
1200
1750
9.7
13.0
0.25
330
07D181K 07D181KJ
115
150 180(162~198)
10
300
1200
1750
11.7
16.0
0.25
280
07D201K 07D201KJ
130
170 200(185~225)
10
330
1200
1750
13.0
17.0
0.25
250
07D221K 07D221KJ
140
180 220(198~242)
10
360
1200
1750
14.0
19.0
0.25
230
07D241K 07D241KJ
150
200 240(216~264)
10
395
1200
1750
15.0
21.0
0.25
210
07D271K 07D271KJ
175
225 270(243~297)
10
455
1200
1750
18.0
24.0
0.25
185
07D301K 07D301KJ
190
250 300(270~330)
10
505
1200
1750
20.0
26.0
0.25
165
07D331K 07D331KJ
210
275 330(297~363)
10
550
1200
1750
23.0
28.0
0.25
150
07D361K 07D361KJ
230
300 360(324~396)
10
595
1200
1750
25.0
32.0
0.25
140
07D391K 07D391KJ
250
320 390(351~429)
10
650
1200
1750
25.0
35.0
0.25
130
07D431K 07D431KJ
275
350 430(387~473)
10
710
1200
1750
28.0
40.0
0.25
115
07D471K 07D471KJ
300
385 470(423~517)
10
775
1200
1750
30.0
42.0
0.25
105
07D511K 07D511K
320
415 510(459~561)
10
845
1200
1750
30.0
45.0
0.25
100
07D561K 07D561KJ
350
460 560(504~616)
10
920
1200
1750
30.0
49.0
0.25
90
07D621K 07D621KJ
385
505 620(558~682)
10
1025
1200
1750
33.0
55.0
0.25
80
07D681K 07D681KJ
420
560 680(612~748)
10
1120
1200
1750
33.0
60.0
0.25
75
07D751K 07D751KJ
460
615 750(675~825)
10
1240
1200
1750
65.0
67.2
0.25
70
07D781K 07D781KJ
485
640 780(702~858)
10
1290
1200
1750
65.0
67.2
0.25
70
07D821K 07D821KJ
510
670 820(738~902)
10
1355
1200
1750
65.0
70.0
0.25
60
The tolerance of varistor voltage between 18V and 68V is more than 10%.
Page-3
嵩隆力上
SONGLONG LISHANG
Mechanical Ratings
VDR Varistor
07D SERIES
Reliability Test
Performance
Requirements
Test Parameter Test Condition / Description
Terminal Pull
Strength
After gradually applying the load specified below and keeping
the unit fixed for ten seconds, the terminal shall be visually
examined for any damage.
The unit shall be secured with its terminal kept vertical and the
weight specified below be applied in the axial direction. The
Terminal Bending
terminal shall gradually be bent by 90° in one direction, then 90°
Strength
in the opposite direction, and again back to the original position.
The damage of the terminal shall be visually examined.
Vibration
Solderingsolderability
SolderingResistance to
Solder Heat
Diameter
Loading
0.6mm
1.0 Kg
0.8mm
1.0 Kg
1.0mm
2.0 Kg
Diameter
Loading
0.6mm
0.5 Kg
0.8mm
0.5 Kg
1.0mm
1.0 Kg
The Specimen shall be vibrated by its lead wires with a total amplitude of 1.5㎜ and a
varying frequency of 10~55~10HZ(each minutes) for a period of 2 hours respectively in
each X,Yand Z directions.
No visible damage
No visible damage
No visible damage
△VB/VB%≦±5%
After dipping the terminal to depth of approximately 3㎜ from the specimen in a soldering
Terminations shall
bath of 260℃ for 10±1(D5: 5±1) seconds. Thereafter the terminal shall be visually
be uniformly tinned
examined.
After preheating the specimen, the specimen shall be completely immersed into a
soldering bath having a temperature of 260±5℃ for 10±1 (D5: 5±1) seconds or iron of
400±5℃ for 3±0.5 seconds. There after the change of Vb and mechanical damage shall
be examined.
No visible damage
△VB/VB%≦±5%
ENVIRONMENTAL RATINGS
The specimen shall be applied continuously the maximum allowable voltage at the
specified conditions for specified period and then stored at room temperature and normal
Dry Heat Loading humidity over 2 hours. Thereafter, the change of Vb and mechanical damage shall be
△VB/VB%≦±10%
examined.
Ambient
temp:125±2℃ ;
Period:1000±24hours.
High Temperature In a drying oven without load.
Storage
Ambient temp:125±2℃ ; period:1000±24hours
Damp Heat
Loading
△VB/VB%≦±5%
△VB/VB%≦±10%
examined.
Ambient
condition:40±2℃ , 90 to 95%R.H. ; period:1000±24 hours
Step
Temperature
Cycle
Condition the specimen to each temperature form step 1
to step 4 in this order for the period shown in the table of
specifications. The change of Vb and mechanical
damage shall be examined after 2 hours.
o
Period
o
Temp C
1
-40+3 C
30 min.
2
Room Temp
15 min.
3
85+2 C
30 min.
4
Room Temp
15 min.
o
Surge Lifetime
Rating
The change of Vb shall be measured after the impulse listed below is applied 10,000
times continuously with the interval of ten seconds at room temperature.
Voltage Proof
Voltage:2500VAC
Leakage Current≦0.5mA
Time:60 Seconds
No visible damage
△VB/VB%≦±10%
No visible damage
△VB/VB%≦±10%
No Breakdown
Page-4
VDR Varistor
07D SERIES
嵩隆力上
SONGLONG LISHANG
MARKING CODE
1 SongLong Lishang Logo
2 Disk Size
3 CUL Accreditation Logo
4 “Y” &“M” Product Line Code
5 Varistor Voltage
6 VDE Accreditation Logo
7 Energy and frequency of combined wave
“J” is High Surge Code,not “J” is Standard Surge
“H” is High temperature range ,not “H” is Standard
Packaging specification / bulk packaging quantity
Unit:Pcs
Dimension
Part No.
Bag
Small Carton
Carton
07D
180L to 821K
1,000
10,000
20,000
07D (Short leg)
180L to 821K
1,000
15,000
30,000
Page-5
很抱歉,暂时无法提供与“VDR-07D471K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.37692
- 100+0.30197
- 300+0.26460
- 1000+0.21352
