FN286B-4-06
FN286B-4-06
    SCHAFFNER(夏弗纳)
    Module
    FN286B-4-06
FN286B-4-06 数据手册
DATA SHEET Power Entry Module with EMC- Filter FN280 Compact filtered power entry module Complies with IEC/EN 60601-1 Approvals & Compliances Rated currents up to 10 A Single or dual-fuse holder Fuses Ø5 x 20 mm 2-pole rocker switch General purpose application Optional earth line choke (E type) Optional medical versions (B type) (CQC except HI-types) Features and Benefits High conducted attenuation performance, based on chokes with high saturation resistance and excellent thermal behavior Rear/front or snap-in mounting Performance indicators Single or dual-fuse holder 2-pole rocker switch Custom-specific versions are available on request Typical Applications Portable electrical and electronic equipment Consumer goods EDP and office equipment Single-phase power supplies, switch-mode power supplies Test and measurement equipment Medical equipment Technical Specifications Typical electrical schematic Maximum continuous operating voltage 250 VOLT, 50/60 Hz Operating frequency DC to 400 Hz Rated currents 1 to 10 A @ 40°C max High potential test voltage P –> PE 2000 VAC for 2 sec (standard types) P –> PE 2500 VAC for 2 sec (B types) P –> N 760 VAC for 2 sec Protection category IP 40 according to IEC 60529 Temperature range (operation and storage) -25°C to +85°C (25/85/21) Design corresponding to UL 1283, CSA 22.2 No. 8 1986, IEC/EN 60939 Flammability corresponding to UL 94 V-2 or better MTBF @ 40°C/230 V (Mil-HB-217F) 1,500,000 hours Fuse holder 1 or 2 fuses (Ø5 x 20 mm) (certified to IEC 60127-6) Marking ) Marking max. 250 V ~ (text is print. below fuse symbol) Rocker switch description Function 2-pole, dark not illuminated Marking I - 0 Electrical specifications Inrush current 82 A 6,000 on-off operations according to UL 1054, TV5 10,000 on-off operations according to ENEC Switch ratings * USA (UL) and Canada (C-UL) 10 A, 125 VAC; 10 A, 250 VAC; 1/3 HP Europe (ENEC) 10 A (4 A), 250 VAC* Mechanical life 50,000 cycles Value in () relates to the inductive current charge: cosφ = 0.65 2 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 15. Jun 2022 Filter Selection Table Filter Rated current Leakage current* @ 40°C (25°C) @ 230 VAC/50 Hz L1 L2 Cx [A] [μA] [mH] [mH] [nF] FN 281-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 FN 281-2-06 2 (2.4) 373 2 220 2.2 1000 FN 281-4-06 4 (4.8) 373 1 220 2.2 1000 FN 281-6-06 Inductance** Capacitance** Resistance** Output Fuses*** Weight Cy R connections [nF] [kΩ] [Qty] [g] 1 90 -06 1 90 -06 1 90 6 (7.2) 373 0.45 220 2.2 1000 -06 1 90 10 (11.6) 373 0.34 220 2.2 1000 -06 1 90 FN 282-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 2 90 FN 282-2-06 2 (2.4) 373 2 220 2.2 1000 -06 2 90 FN 282-4-06 4 (4.8) 373 1 220 2.2 1000 -06 2 90 FN 281-10-06 FN 282-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 2 90 10 (11.6) 373 0.34 220 2.2 1000 -06 2 90 FN 283-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 1 90 FN 283-2-06 2 (2.4) 373 2 220 2.2 1000 -06 1 90 FN 283-4-06 4 (4.8) 373 1 220 2.2 1000 -06 1 90 FN 283-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 1 90 10 (11.6) 373 0.34 220 2.2 1000 -06 1 90 FN 284-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 2 90 FN 284-2-06 2 (2.4) 373 2 220 2.2 1000 -06 2 90 FN 284-4-06 4 (4.8) 373 1 220 2.2 1000 -06 2 90 FN 284-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 2 90 10 (11.6) 373 0.34 220 2.2 1000 -06 2 90 FN 285-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 1 90 FN 285-2-06 2 (2.4) 373 2 220 2.2 1000 -06 1 90 FN 285-4-06 4 (4.8) 373 1 220 2.2 1000 -06 1 90 FN 282-10-06 FN 283-10-06 FN 284-10-06 FN 285-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 1 90 10 (11.6) 373 0.34 220 2.2 1000 -06 1 90 FN 286-1-06 1 (1.2) 373 7.5 220 2.2 1000 -06 2 90 FN 286-2-06 2 (2.4) 373 2 220 2.2 1000 -06 2 90 FN 286-4-06 4 (4.8) 373 1 220 2.2 1000 -06 2 90 FN 285-10-06 FN 286-6-06 6 (7.2) 373 0.45 220 2.2 1000 -06 2 90 FN 286-10-06 10 (11.6) 373 0.34 220 2.2 1000 -06 2 90 FN 283 E-1-06 1 (1.2) 373 7.5 0.4 220 2.2 1000 -06 1 100 FN 283 E-2-06 2 (2.4) 373 2 0.4 220 2.2 1000 -06 1 100 FN 283 E-4-06 4 (4.8) 373 1 0.4 220 2.2 1000 -06 1 100 FN 283 E-6-06 6 (7.2) 373 0.45 0.4 220 2.2 1000 -06 1 100 FN 284 E-1-06 1 (1.2) 373 7.5 0.4 220 2.2 1000 -06 2 100 FN 284 E-2-06 2 (2.4) 373 2 0.4 220 2.2 1000 -06 2 100 FN 284 E-4-06 4 (4.8) 373 1 0.4 220 2.2 1000 -06 2 100 FN 284 E-6-06 6 (7.2) 373 0.45 0.4 220 2.2 1000 -06 2 100 FN 282 B-1-06 1 (1.2) 2 7.5 220 1000 -06 2 90 FN 282 B-2-06 2 (2.4) 2 2 220 1000 -06 2 90 FN 282 B-4-06 4 (4.8) 2 1 220 1000 -06 2 90 6 (7.2) 2 0.45 220 1000 -06 2 90 10 (11.6) 2 0.34 220 1000 -06 2 90 FN 282 B-6-06 FN 282 B-10-06 *** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. *** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10% *** Filters are delivered without fuse. 3 Power Entry Module with EMC- Filter Filter Schaffner Group Rated current Leakage current* @ 40°C (25°C) @ 230 VAC/50 Hz L1 L2 Cx [A] [μA] [mH] [mH] [nF] FN 284 B-1-06 1 (1.2) 2 7.5 220 1000 FN 284 B-2-06 2 (2.4) 2 2 220 1000 FN 284 B-4-06 4 (4.8) 2 1 220 FN 284 B-6-06 Inductance** Capacitance** DATA SHEET Resistance** Output Cy R connections [nF] [kΩ] 15. Jun 2022 Fuses*** Weight [Qty] [g] -06 2 90 -06 2 90 1000 -06 2 90 6 (7.2) 2 0.45 220 1000 -06 2 90 10 (11.6) 2 0.34 220 1000 -06 2 90 FN 286 B-1-06 1 (1.2) 2 7.5 220 1000 -06 2 90 FN 286 B-2-06 2 (2.4) 2 2 220 1000 -06 2 90 FN 286 B-4-06 4 (4.8) 2 1 220 1000 -06 2 90 FN 286 B-6-06 6 (7.2) 2 0.45 220 1000 -06 2 90 10 (11.6) 2 0.34 220 1000 -06 2 90 FN 284 B-10-06 FN 286 B-10-06 *** Maximum leakage under normal operating conditions. Note: if the neutral line is interrupted, worst case leakage could reach twice this level. *** Tolerances apply: Inductance: -30/+50%, Capacitance: ±20%, Resistance: ±10% *** Filters are delivered without fuse. Product selector For example: FN 281-6-06, FN 283 B-04-06, FN 283 E-1-06 Typical Filter Attenuation Per CISPR 17; A=50 Ω/50 Ω sym; B=50 Ω/50 Ω asym; C=0.1 Ω/100 Ω sym; D=100 Ω/0.1 Ω sym 1 A types 2 to 6 A types 10 A types 4 Power Entry Module with EMC- Filter Schaffner Group DATA SHEET 15. Jun 2022 Mechanical Data FN 281/FN 282 FN 283/FN 284 FN 285/FN 286 Panel cut out Dimensions FN 281 FN 282 FN 283 FN 284 FN 285 FN 286 Tolerances A 32 32 50 50 32 32 ±0.3 B 82 82 65 65 65 65 ±0.3 C 72 72 40 40 D 43.1 43.1 43.1 43.1 43.6 43.6 ±0.3 E 28.5 28.5 28.5 28.5 28.5 28.5 ±0.25 F 5.5 5.5 5.5 5.5 5 5 ±0.3 G 59.95 max. 59.95 max. 59.95 max. 59.95 max. 59.95 max. 59.95 max. H Ø3.5 Ø3.5 Ø3.3 Ø3.3 I 13.4 16.2 13.4 16.2 13.9 16.7 J 22.5 22.5 22.5 22.5 22.5 22.5 M R ≤2.5 R ≤2.5 R ≤2.5 R ≤2.5 R ≤2.5 R ≤2.5 N 60 60 60 60 61.5+0.2/-0* 61.5+0.2/-0* +0.5/-0 P 29 29 29 29 29 29 +0.5/-0 R M3 M3 M3 M3 S 90° 90° 90° 90° * For a panel thickness between 0.8 and 3 mm All dimensions in mm; 1 inch = 25.4 mm Tolerances according: ISO 2768-m/EN 22768-m Please visit www.schaffner.com to find more details on filter connectors. ±0.1 ±0.3 5 Power Entry Module with EMC- Filter Headquarters, Global Innovation and Development Switzerland Schaffner Holding AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 info@schaffner.com Schaffner Group China Schaffner EMC Ltd. Shanghai T20-3 C, No 565 Chuangye Road,Pudong district 201201 Shanghai +86 2138139500 cschina@schaffner.com Spain Schaffner EMC España Calle Caléndula 93, Miniparc III, Edificio E El Soto de Moraleja, Alcobendas 28109 Madrid +34 917 912 900 spainsales@schaffner.com Finland Schaffner Oy Sauvonrinne 19 H 8500 Lohja +358 50 468 7284 finlandsales@schaffner.com Sweden Schaffner EMC AB Östermalmstrorg 1 114 42 Stockholm +46 8 5050 2425 swedensales@schaffner.com France Schaffner EMC S.A.S. 16-20 Rue Louis Rameau 95875 Bezons +33 1 34 34 30 60 francesales@schaffner.com Switzerland Schaffner EMV AG Industrie Nord Nordstrasse 11e 4542 Luterbach +41 32 681 66 26 switzerlandsales@schaffner.com India Schaffner India Pvt. Ltd Regus World Trade Centre WTC, 22nd Floor Unit No 2238, Brigade Gateway Campus, 26/1, Dr. Rajkumar Road Malleshwaram (W) 560055 Bangalore +91 8067935355 indiasales@schaffner.com © 2022 Schaffner Group The content of this document has been carefully checked and understood. However, neither Schaffner nor its subsidiaries assume any liability whatsoever for any errors or inaccuracies of this document and the consequences thereof. Published specifica-tions are subject to change without notice. Product suitability for any area of application must ultimately be determined by the customer. In all cases, products must never be operated outside their published specifications. Schaffner does not guarantee the availability of all published products. This disclaimer shall be governed by substantive Swiss law and resulting disputes shall be settled by the courts at the place of business of Schaffner Holding AG. Latest publications and a complete disclaimer can be downloa-ded from the Schaffner website. All trademarks recognized. 15. Jun 2022 Sales and Application Centers Germany Schaffner Deutschland GmbH Schoemperlenstrasse 12B 76185 Karlsruhe +49 721 56910 germanysales@schaffner.com To find your local partner within Schaffner‘s global network schaffner.com DATA SHEET Italy Schaffner EMC S.r.l. Via Ticino, 30 20900 Monza (MB) +39 039 21 41 070 italysales@schaffner.com Japan Schaffner EMC K.K. ISM Sangenjaya 7F 1-32-12 Kamiuma, Setagaya-ku 154-0011 Tokyo +81 3 5712 3650 japansales@schaffner.com Singapore Schaffner EMC Pte Ltd. Blk 3015A Ubi Road 1, #05-09, Kampong Ubi Industrial Estate 408705 Singapore +65 63773283 singaporesales@schaffner.com Taiwan Schaffner EMV Ltd. U-Town 20 Floor-2, No 97, Section 1, XinTai 5th Road, XiZhi District 22175 New Taipei City +886 226975500 taiwansales@schaffner.com Thailand Schaffner EMC Co. Ltd. Sathorn Square Tower Room 3780, 37FL, 98 North-Sathorn Rd, Silom, Bangrak 10500 Bangkok +66 621056397 thailandsales@schaffner.com United Kingdom Schaffner Ltd. 1, Oakmede Place Terrace Road RG42 4JF Binfield +44 118 9770070 uksales@schaffner.com United States Schaffner EMC Inc. 52 Mayfield Avenue Edison, New Jersey +1 732 225 9533 usasales@schaffner.com
FN286B-4-06 价格&库存
很抱歉,暂时无法提供与“FN286B-4-06”相匹配的价格&库存,您可以联系我们找货
