S1JL-R2
S1JL-R2
    TAIWANSEMICONDUCTOR(台湾半导体)
    S1JL-R2
S1JL-R2 数据手册
S1AL - S1ML Taiwan Semiconductor CREAT BY ART 1A, 50V - 1000V Surface Mount Rectifier FEATURES - Glass passivated junction chip - Ideal for automated placement - Low-Profile Package - Low power loss, high efficiency - Moisture sensitivity level: level 1, per J-STD-020 - Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC - Halogen-free according to IEC 61249-2-21 definition Sub SMA MECHANICAL DATA Case: Sub SMA Molding compound, UL flammability classification rating 94V-0 Part No. with suffix "H" means AEC-Q101 qualified Packing code with suffix "G" means green compound (halogen-free) Terminal: Matte tin plated leads, solderable per JESD22-B102 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.019 g (approximately) MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25°C unless otherwise noted) PARAMETER SYMBOL Marking code S1AL S1BL S1DL S1GL S1JL S1KL S1ML UNIT 1AL 1BL 1DL 1GL 1JL 1KL 1ML Maximum repetitive peak reverse voltage VRRM 50 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 35 70 140 280 420 560 700 V Maximum DC blocking voltage VDC 50 100 200 400 600 800 1000 V Maximum average forward rectified current IF(AV) 1 A Peak forward surge current, 8.3 ms single half sine-wave superimposed on rated load IFSM 30 A VF 1.1 V Maximum instantaneous forward voltage (Note 1) @1A Maximum reverse current @ rated VR TJ=25°C TJ=125°C 5 IR μA 50 Typical junction capacitance (Note 2) CJ 9 pF Typical reverse recovery time (Note 3) trr 1.8 μs Typical thermal resistance Operating junction temperature range Storage temperature range RθJL RθJA 25 85 30 85 °C/W TJ - 55 to +175 °C TSTG - 55 to +175 °C Note 1: Pulse test with PW=300μs, 1% duty cycle Note 2: Measured at 1 MHz and Applied VR=4.0 Volts. Note 3: Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A Document Number: DS_D1410010 Version: O15 S1AL - S1ML Taiwan Semiconductor ORDERING INFORMATION PART NO. PART NO. PACKING CODE PACKING CODE PACKAGE PACKING Sub SMA Sub SMA Sub SMA Sub SMA Sub SMA Sub SMA Sub SMA Sub SMA Sub SMA Sub SMA 1,800 / 7" Plastic reel (8mm tape) 3,000 / 7" Plastic reel (8mm tape) 7,500 / 13" Paper reel (8mm tape) 7,500 / 13" Plastic reel (8mm tape) 10,000 / 13" Paper reel (8mm tape) 10,000 / 13" Plastic reel (8mm tape) 1,800 / 7" Plastic reel (12mm tape) 3,000 / 7" Plastic reel (12mm tape) 7,500 / 13" Paper reel (12mm tape) 7,500 / 13" Plastic reel (12mm tape) RH Sub SMA 10,000 / 13" Paper reel (12mm tape) MH Sub SMA 10,000 / 13" Plastic reel (12mm tape) SUFFIX S1xL (Note 1) SUFFIX RU RV RT MT RQ MQ R3 RF R2 M2 H G Note 1: "x" defines voltage from 50V (S1AL) to 1000V (S1ML) EXAMPLE PREFERRED PART NO. PART NO. PART NO. S1MLHRUG SUFFIX S1ML PACKING CODE PACKING CODE H DESCRIPTION SUFFIX RU AEC-Q101 qualified Green compound G RATINGS AND CHARACTERISTICS CURVES (TA=25°C unless otherwise noted) FIG.1- MAXIMUM FORWARD CURRENT DERATING CURVE 1 0.8 0.6 0.4 0.2 0 0 25 50 75 100 125 150 175 INSTANTANEOUS REVERSE CURRENT (μA) AVERAGE FORWARD CURRENT (A) 1.2 FIG. 2- TYPICAL REVERSE CHARACTERISTICS 100 10 TJ=125°C 1 TJ=75°C 0.1 0.01 TJ=25°C 0.001 0 LEAD TEMPERATURE (°C) 100 INSTANTANEOUS FORWARD CURRENT (A) PEAK FORWARD SURGE CURRENT (A) FIG. 3- MAXIMUM NON-REPETITIVE FORWARD SURGE CURRENT 10 8.3ms Single Half Sine Wave 20 40 60 80 100 120 PERCENT OF RATED PEAK REVERSE VOLTAGE (%) 140 FIG. 4- TYPICAL INSTANTANEOUS FORWARD CHARACTERISTICS 100 10 1 0.1 0.01 1 1 10 NUMBER OF CYCLES AT 60 Hz Document Number: DS_D1410010 100 0.4 0.6 0.8 1 1.2 1.4 1.6 1.8 2 FORWARD VOLTAGE (V) Version: O15 S1AL - S1ML Taiwan Semiconductor FIG. 5- TYPICAL JUNCTION CAPACITANCE JUNCTION CAPACITANCE (pF) 100 f=1.0MHz Vsig=50mVp-p 10 1 0.01 0.1 1 10 100 REVERSE VOLTAGE (V) PACKAGE OUTLINE DIMENSIONS Sub SMA Unit (mm) DIM. Unit (inch) Min Max Min Max B 1.70 1.90 0.067 0.075 C 2.70 2.90 0.106 0.114 D 0.16 0.30 0.006 0.012 E 1.23 1.43 0.048 0.056 F 0.80 1.20 0.031 0.047 G 3.40 3.80 0.134 0.150 H 2.45 2.60 0.096 0.102 I 0.35 0.85 0.014 0.033 J 0.00 0.10 0.000 0.004 SUGGESTED PAD LAYOUT Symbol Unit (mm) Unit (inch) A 1.4 0.055 B 1.2 0.047 C 3.1 0.122 D 1.9 0.075 E 4.3 0.169 MARKING DIAGRAM P/N = Marking Code G = Green compound Code YW = Date Code F = Factory Code Document Number: DS_D1410010 Version: O15 S1AL - S1ML Taiwan Semiconductor CREAT BY ART Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_D1410010 Version: O15
S1JL-R2 价格&库存
很抱歉,暂时无法提供与“S1JL-R2”相匹配的价格&库存,您可以联系我们找货
