FMMT589
FMMT589
    SK(時科)
    SOT-23
    适用于开关和放大器应用。特别适用于音频驱动级和低功率输出级。作为互补类型的NPN晶体管
FMMT589 数据手册
FMMT589 PNP Silicon Epitaxial Planar Transistor For switching and amplifier applications. Especially suitable for AF-driver stages and low power output stages. As complementary type the NPN transistor 1.BASE 2.EMITTER 3.COLE L CTOR SOT-23 Plastic Package Absolute Maximum Ratings (Ta = 25 OC) Parameter Symbol Value Unit Collector Base Voltage -VCBO 40 V Collector Emitter Voltage -VCEO 25 V Emitter Base Voltage -VEBO 6 V Collector Current -IC 1 A Power Dissipation Ptot 350 mW Junction Temperature Tj 150 O Storage Temperature Range TS - 55 to + 150 O C C Characteristics at Ta = 25 OC Parameter Symbol Min. Max. Unit hFE 200 400 - - -ICBO - 100 nA -IEBO - 100 nA -V(BR)CBO 40 - V -V(BR)CEO 25 - V -V(BR)EBO 6 - V -VCE(sat) - 0.5 V -VBE(sat) - 1.2 V -VBE(on) - 1 V fT 120 - MHz DC Current Gain at -VCE = 1 V, -IC = 100 mA at -VCE = 1 V, -IC = 800 mA Collector Base Cutoff Current at -VCB = 35 V Emitter Base Cutoff Current at -VEB = 6 V Collector Base Breakdown Voltage at -IC = 100 µA Collector Emitter Breakdown Voltage at -IC = 2 mA Emitter Base Breakdown Voltage at -IE = 100 µA Collector Emitter Saturation Voltage at -IC = 800 mA, -IB = 80 mA Base Emitter Saturation Voltage at -IC = 800 mA, -IB = 80 mA Base Emitter Voltage at -VCE = 1 V, -IC = 10 mA Gain Bandwidth Product at -VCE = 10 V, -IC = 50 mA REV.08 1 of 3 FMMT589 REV.08 2 of 3 FMMT589 RESTRICTIONS ON PRODUCT USE • The information contained herein is subject to change without notice. • SK is continually working to improve the quality and reliability of its products. Nevertheless, semiconductor devices in general can malfunction or fail due to their inherent electrical sensitivity and vulnerability to physical stress. It is the responsibility of the buyer, when utilizing SK products, to comply with the standards of safety in making a safe design for the entire system, and to avoid situations in which a malfunction or failure of such SK products could cause loss of human life, bodily injury o r damage to property. In developing your designs, please ensure that SK products are used within specified operating ranges as set forth in the most recent SK products specifications. Also, please keep in mind the precautions and conditions set forth in the “Handling Guide for Semiconductor Devices,” or “SK Semiconductor Reliability Handbook” etc. • The SK products listed in this document are intended for usage in general electronics applications (computer, personal equipment, office equipment, measuring e quipment, industrial robotics, domestic appliances, etc.).These SK products are neither intended nor warranted for usage in equipment that requires extraordinarily high quality and/or reliability or a malfunction or failure of which may cause loss of human life or bodily injury (“Unintended Usage”). Unintended Usage include atomic energy control instruments, airplane or spaceship instruments, all types of safety devices, etc.. Unintended Usage of SK products listed in his document shall be made at the customer’s own risk. • The information contained herein is presented only as a guide for the applications of our products. No responsibility is assumed by SK for any infringements of patents or other rights of the third parties which may result from its use. No license is granted by implication or otherwise under any patents or other rights of SK or the third parties. • Please contact your sales representative for product-by-product details in this document regarding RoHS & REACH compatibility. Please use these products in this document in compliance with all applicable laws and regulations that regulate the inclusion or use of controlled substances. SK assumes no liability for damage or losses occurring as a result of noncompliance with applicable laws and regulations. REV.08 3 of 3
FMMT589 价格&库存
很抱歉,暂时无法提供与“FMMT589”相匹配的价格&库存,您可以联系我们找货
