P1
TAI-TECH
SMD Power Inductor
TMPC1206HP-Series(MG)-D
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
14/12/12
新發行
楊祥忠
詹偉特
何秦芝
備
註
P2
TAI-TECH
SMD Power Inductor
1. Features
1. Carbonyl Powder.
2. Compact design.
3. High current,low DCR,high efficiency.
Halogen
Pb
Halogen-free
Pb-free
4. Very low acoustic noise and very low leakage flux noise.
5. High reliability.
6. 100% Lead(Pb)-Free and RoHS compliant.
2. Applications
Note PC power system,incl. IMVP-6
DC/DC converter .
3. Dimensions
Dr. MOS application
Recommend PC Board Pattern
C
330
1349
D
L
H
E
B
A
G
Series
A(mm)
TMPC1206HP 13.5±0.5
B(mm)
C(mm)
12.5±0.3
5.7±0.3
D(mm)
2.3±0.3
E(mm)
L(mm)
G(mm)
H(mm)
4.7±0.3
14.2
8.0
5.0
4. Part Numbering
TMPC
1206
HP
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F: 印 D/C
330
MG
D
E
D
F
BxC
HP:H:Carbonyl Powder,P:PAD broaden.
330=33uH
M=±20%,Y=±30%
印字:黑色.330 及 D/C 1349 (13 年,49 週期,依實際生產周期而定)
P3
TAI-TECH
5. Specification
Part Number
Inductance
L0 (uH)±20% @ 0 A
I rms (A)
Typ.
I sat 1
(A)
Typ.
I sat 2
(A)
Typ.
DCR
(mΩ) Typ.
@25℃
DCR
(mΩ) Max.
@25℃
TMPC1206HP-1R5MG-D
1.50
26
43
50
2.7
3.2
TMPC1206HP-2R2MG-D
2.20
21
34
43
4.0
4.7
TMPC1206HP-3R3MG-D
3.30
17
28
35
5.8
7.1
TMPC1206HP-4R7MG-D
4.70
16
25
30
9.5
11.5
TMPC1206HP-5R6MG-D
5.60
15.5
22
28
10.8
12.6
TMPC1206HP-6R8MG-D
6.80
15
19
25
12
13.8
TMPC1206HP-100MG-D
10.0
11
15.5
21
18
20.7
TMPC1206HP-120MG-D
12.0
9.5
13.5
18
TMPC1206HP-150MG-D
15.0
9.0
13
16
25
29
TMPC1206HP-180MG-D
18.0
8.5
12
15
30
35
TMPC1206HP-220MG-D
22.0
8.0
11
14
34
39.5
TMPC1206HP-270MG-D
27.0
7.0
9.0
13
49
56
TMPC1206HP-330MG-D
33.0
6.0
8.0
12.0
65
75
TMPC1206HP-470MG-D
47.0
5.5
7.0
11.0
80
90
TMPC1206HP-560MG-D
56.0
5.3
6.5
10
101
118
.TMPC1206HP-680MG-D
68.0
5.0
6.0
9.0
120
140
.TMPC1206HP-820MG-D
82.0
4.5
5.5
8.5
138
161
TMPC1206HP-101MG-D
100
4.0
5.0
8.0
180
200
TMPC1206HP-121MG-D
120
3.5
4.5
7.0
210
235
TMPC1206HP-151MG-D
150
3.0
4.0
6.0
300
350
Note:
1.Test frequency : L : 100KHz /1.0V;
2.All test data referenced to 25℃ ambient.
3.Testing Instrument : L/Q: HP4284A,CH11025,CH3302,CH1320 ,CH1320S LCR METER / Rdc:CH16502,Agilent33420A MICRO OHMMETER.
4.Heat Rated Current (Irms) will cause the coil temperature rise approximately Δt of 40℃ (keep 1min.).
5.Saturation Current (Isat
1) will cause L0 to drop 20% typical. (keep quickly).
6.Saturation Current (Isat
2) will cause L0 to drop 30% typical. (keep quickly)
7.The part temperature (ambient + temp rise) should not exceed 125℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
8. Special inquiries besides the above common used types can be met on your requirement.
P4
TAI-TECH
6. Material List
NO
Items
1
Core
Carbonyl Powder.
Materials
2
Wire
Polyester Wire or equivalent.
3
Solder Plating
100% Pb free solder
7. Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Inductance
Refer to standard electrical characteristics list.
DCR
HP4284A,CH11025,CH3302,CH1320,CH1320S
LCR Meter.
CH16502,Agilent33420A Micro-Ohm Meter.
Saturation Current (Isat)
△L≦20% typical.
Saturation DC Current (Isat) will cause L0
to drop △L(%)(keep quickly).
Approximately △T≦40℃
△T(℃) without core loss.
1.Applied the allowed DC current(keep 1 min.).
2.Temperature measured by digital surface thermometer
Reliability Test
Preconditioning: Run through IR reflow for 2
times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature:125±2℃(Bead)
Life Test
Temperature: 85±2℃(Inductor)
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
times.( IPC/JEDEC
Humidity:85±2﹪ R.H,
Load Humidity
Temperature:85℃±2℃
Thermal
shock
Duration:1000hrs Min. with 100% rated current
times.( IPC/JEDEC J-STD-020DClassification
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Appearance:No damage.
Step2:25±2℃ ≦0.5min
Inductance:within±10% of initial value
Step3:105±2℃ 30±5min
Q:Shall not exceed the specification value.
Number of cycles: 500
RDC:within ±15% of initial value and shall not
Vibration
Shock
Bending
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Type
Peak
value
(g’s)
Normal
duration (D)
(ms)
Wave
form
Velocity
change
(Vi)ft/sec
SMD
1500
0.5
Half-sine
15.4
Lead
100
6
Half-sine
12.3
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805:40x100x1.2mm
=0805:1.2mm
0805:1kg ,
很抱歉,暂时无法提供与“TMPC1206HP-680MG-D”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+4.02840
- 10+3.24000
- 30+2.85120
