WL10-PF-2
WL10-PF-2
    NIDEC(尼得科)
    漏液传感器
WL10-PF-2 数据手册
WL 10 LIQUID LEAK SENSORS INTERNAL STRUCTURE [PP type] marking Compatible with EMC directive 8 6 4 3 7 5 2 Part name 1 Material ■ FEATURES 1 Housing O Low effects at detection point by introduction of new optical technology ONeedless shade plate, High precision OCompact and Slim size (φ 25 mm, t = 10 mm) OLead-free Soldering 2 Cover 3 Mounting plate 4 Sealing cap 5 P.C. board Glass-Epoxy 6 Label Polyester film 7 Photo-interrupter 8 Cable PP — PVC ■ MODEL NUMBER DESIGNATION W L 1 0 - N P - 2 Series name Cable length 2:2 m(Standard) 4:4 m(Semi-Standard) Switch output interface Material of housing N:NPN open collector P:PNP open collector P:PP(Polypropylene) F:PFA(Perfluoroalkoxy alkane) ■ LIST OF MODEL NUMBERS Model number Switch output interface NPN Material of housing PNP PP PFA PP PFA 2m WL10-NP-2 WL10-NF-2 WL10-PP-2 WL10-PF-2 4m A WL10-NP-4 A WL10-NF-4 A WL10-PP-4 A WL10-PF-4 Cable length ※ Verify the above model numbers when placing orders. The products marked A are manufactured upon receipt of order basis. WL10 LIQUID LEAK SENSORS ■ STANDARD SPECIFICATIONS ● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 24 V DC. Item General specifications NPN − 10 ~ 60 35 ~ 85(No condensation) %RH Operating humidity − 20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum) °C Storage temp. Pressure medium Water (PP) / Corrosive fluids compatible with PFA PP/PFA Material of housing Net weight g Approx. 30 (WL10- * P-2) Approx. 50 (WL10- * P-4, WL10- * F-2) Approx. 80 (WL10- * F-4) 12 ~ 24 ± 10 % V DC Supply voltage mA maximum Consumption current Switching capacity Output PNP °C Operating temp. range Power WL10 Model number 10 (Except open collector output) Voltage endurance : 30 VDC Sink current : 50 mA maximum (Over current protection) Voltage endurance : 24 VDC Sourced current : 50 mA maximum (Over current protection) 1.0 V maximum 2.0 V maximum V maximum Residual voltage Normal condition : Switch output is ON / Green LED is ON Leakage detection : Switch output is OFF / Red LED is ON Operation grade ■ ENVIRONMENTAL CHARACTERISTICS Test item Test conditions Specification Vibration 10 ~ 500 Hz, 1.5 mm maximum / 98.1 m / S2, 3 directions for 2 hours each Shock 490 m/s2, 3 directions for 3 times each Protection grade IP67 EMC EMI : EN55011: 2007, A2 : 2007 Group 1, class Bý EMS : EN61326-1: 2006 Table 2 Meets standard specifications ■ INTERNAL ELECTRICAL SCHEMATICS ONPN OPNP LED Indicator Red LED Indicator Red Green Green Power B Main circuit Load Power B Main circuit S.Output S.Output Load Common Common WL10 LIQUID LEAK SENSORS ■ OUTLINE DIMENSION Unless otherwise specified, tolerance: ± 0.5 (Unit: mm) OMaterial of housing - PP L 50 ± 5 10 ± 2 3-core cable (φ 2.9) AWG28 ULNo.20276 φ 25 Wire color Brown Black Blue – 4. 5 5 8.1 9.9 16.5 Cable length WL10- ** -2 2000 ± 100 mm WL10- ** -4 4000 ± 200 mm Detecting element OMaterial of housing - PFA L 50 ± 5 φ PFA tube  4.4 PFA heat shrink tubing φ 25 – 5 Detecting element 5 10.6 φ 4. 9.9 2 8.1 7.6 16.5 26 18 LED Indicator 3-core cable (φ 2.9) AWG28 ULNo.20276 Connection Power B Output Common Model number 10.6 2 φ 7.6 26 18 LED Indicator 10 ± 2
WL10-PF-2
物料型号为WL10-NP-2、WL10-NF-2、WL10-PP-2、WL10-PF-2(2m电缆长度)和WL10-NP-4、WL10-NF-4、WL10-PP-4、WL10-PF-4(4m电缆长度)。
器件简介为一种液体泄漏传感器,采用新的光学技术,无需遮挡板,具有高精度。
尺寸紧凑且轻薄,铅免费焊接。
引脚分配为:1号引脚为接地,2号引脚为输出,3号引脚为电源。
参数特性包括工作温度范围-10℃至60℃,工作湿度35%至85%RH(无凝结),存储温度-20℃至70℃,压力介质为水(PP)或与PFA兼容的腐蚀性液体,外壳材料为PP或PFA,净重约为30克(2m电缆)或50克(4m电缆),供电电压为12至24V DC,最大消耗电流为10mA(除了开路集电极输出),开关输出能力为电压耐量30VDC,最大汇流电流50mA(过电流保护),最大残余电压1.0V(NPN)或2.0V(PNP)。
功能详解为在正常条件下开关输出为ON/绿色LED为ON,在泄漏检测时开关输出为OFF/红色LED为ON。
应用信息为与EMC指令兼容,适用于需要检测液体泄漏的场合。
封装信息为外壳材料为PP或PFA,尺寸为50±5mm(PP材料)或50±5mm(PFA材料),电缆为3芯AWG28 ULNo.20276,线色为棕色(电源)、黑色(输出)、蓝色(公共)。
WL10-PF-2 价格&库存
很抱歉,暂时无法提供与“WL10-PF-2”相匹配的价格&库存,您可以联系我们找货
WL10-PF-2
  • 1+1083.083381+140.74945
  • 6+1014.836046+131.88053
