WL 10
LIQUID LEAK SENSORS
INTERNAL STRUCTURE
[PP type]
marking
Compatible with
EMC directive
8
6
4
3
7
5
2
Part name
1
Material
■ FEATURES
1
Housing
O Low effects at detection point by introduction of new
optical technology
ONeedless shade plate, High precision
OCompact and Slim size (φ 25 mm, t = 10 mm)
OLead-free Soldering
2
Cover
3
Mounting plate
4
Sealing cap
5
P.C. board
Glass-Epoxy
6
Label
Polyester film
7
Photo-interrupter
8
Cable
PP
PVC
■ MODEL NUMBER DESIGNATION
W L 1 0 - N P - 2
Series name
Cable length
2:2 m(Standard)
4:4 m(Semi-Standard)
Switch output interface
Material of housing
N:NPN open collector
P:PNP open collector
P:PP(Polypropylene)
F:PFA(Perfluoroalkoxy alkane)
■ LIST OF MODEL NUMBERS
Model number
NPN
Material of housing
PNP
PP
PFA
PP
PFA
2m
WL10-NP-2
WL10-NF-2
WL10-PP-2
WL10-PF-2
4m
A WL10-NP-4
A WL10-NF-4
A WL10-PP-4
A WL10-PF-4
Cable length
※ Verify the above model numbers when placing orders.
The products marked A are manufactured upon receipt of order basis.
WL10
LIQUID LEAK SENSORS
■ STANDARD SPECIFICATIONS
● Unless otherwise specified, the specs are defined at an ambient temperature of 25 ± 5 °C and excitation voltage of 24 V DC.
Item
General specifications
NPN
− 10 ~ 60
35 ~ 85(No condensation)
%RH
Operating humidity
− 20 ~ 70(Atmospheric pressure, humidity 65 %RH maximum)
°C
Storage temp.
Pressure medium
Water (PP) / Corrosive fluids compatible with PFA
PP/PFA
Material of housing
Net weight
g Approx. 30 (WL10- * P-2) Approx. 50 (WL10- * P-4, WL10- * F-2) Approx. 80 (WL10- * F-4)
12 ~ 24 ± 10 %
V DC
Supply voltage
mA
maximum
Consumption current
Switching capacity
Output
PNP
°C
Operating temp. range
Power
WL10
Model number
10 (Except open collector output)
Voltage endurance : 30 VDC
Sink current : 50 mA maximum
(Over current protection)
Voltage endurance : 24 VDC
Sourced current : 50 mA maximum
1.0 V maximum
2.0 V maximum
V
maximum
Residual voltage
Normal condition : Switch output is ON / Green LED is ON
Leakage detection : Switch output is OFF / Red LED is ON
Operation grade
■ ENVIRONMENTAL CHARACTERISTICS
Test item
Test conditions
Specification
Vibration
10 ~ 500 Hz, 1.5 mm maximum / 98.1 m / S2, 3 directions for 2 hours each
Shock
490 m/s2, 3 directions for 3 times each
Protection grade
IP67
EMC
EMI : EN55011: 2007, A2 : 2007 Group 1, class Bý
EMS : EN61326-1: 2006 Table 2
Meets standard specifications
■ INTERNAL ELECTRICAL SCHEMATICS
ONPN
OPNP
LED Indicator
Red
LED Indicator
Red
Green
Green
Power B
Main circuit
Load
Power B
Main circuit
S.Output
S.Output
Load
Common
Common
WL10
LIQUID LEAK SENSORS
■ OUTLINE DIMENSION
Unless otherwise specified, tolerance: ± 0.5 (Unit: mm)
OMaterial of housing - PP
L
50 ± 5
10 ± 2
3-core cable (φ 2.9) AWG28 ULNo.20276
φ
25
Wire color
Brown
Black
Blue
4.
5
5
8.1
9.9
16.5
Cable length
WL10- ** -2
2000 ± 100 mm
WL10- ** -4
4000 ± 200 mm
Detecting element
OMaterial of housing - PFA
L
50 ± 5
φ
PFA tube 4.4
PFA heat shrink tubing
φ
25
5
Detecting element
5
10.6
φ
4.
9.9
2
8.1
7.6
16.5
26
18
LED
Indicator
Connection
Power B
Output
Common
Model number
10.6
2
φ
7.6
26
18
LED
Indicator
10 ± 2
很抱歉,暂时无法提供与“WL10-NF-2”相匹配的价格&库存,您可以联系我们找货
