L IT E - O N T E CH NO L O G Y CO RP O RAT IO N
Property of Lite-on Only
6N138, 6N139
Single Channel, High Speed Optocouplers
Dec.2008
Description
These high gain series couplers use a light
emitter diode and an integrated high gain
photo detector to provide extremely high
current transfer ratio between input and
output. Separate pins for the photodiode and
output stage result in TTL compatible
saturation voltage and high speed operation.
Where desired the Vcc and Vo terminals
may be tied together to achieve conventional
photo darlington operation. A base access
terminal allows a gain bandwidth adjustment
to be made.
Functional Diagram
NC
VCC
ANODE
VB
Cathode
VO
NC
GND
6N138 / 6N139
Truth Table (Positive Logic)
LED
OUT
ON
L
OFF
H
A 0.1µF bypass Capacitor must
be connected between Pin8 and
Pin5
Part No. : 6N138 / 6N139 series
BNS-OD-C131/A4
Features
High current transfer ratio – 2000%
typical.
Low input current requirements – 0.5mA
High output current – 60mA
CTR guarantee – 0~70℃.
Instantaneous common mode rejection
10KV/μsec
TTL compatible output – 0.1V VOL typical
UL, CSA approved.
APPLICATIONS
Digital logic ground isolation
Low input current line receiver
Telephone ring detector
EIA-RS-232C line receiver
Current loop receiver
High common mode noise line
receiver
Page : 1
of 15
Ordering Information
Minimum CMR
Part
Option
dV/dt
(V/µs)
VCM
(V)
CTR
Remarks
Single Channel, DIP-8
6N138
400
M
S
1,000
Single Channel, Wide Lead Spacing
Single Channel, SMD-8
10
6N139
M
S
BNS-OD-C131/A4
300
Page : 2
of 15
OUTLINE DIMENSIONS
8-pin DIP Package (6N138 / 6N139)
*1. Year date code.
*2. 2-digit work week.
*3. Factory identification mark
(Z : Taiwan, Y : Thailand).
Dimensions are in Millimeters and (Inches).
BNS-OD-C131/A4
Page : 3
of 15
OUTLINE DIMENSIONS
8-pin DIP Wide Lead Spacing Package (6N138M / 6N139M)
*1. Year date code.
BNS-OD-C131/A4
Page : 4
of 15
OUTLINE DIMENSIONS
8-pin DIP Surface Mount Package (6N138S / 6N139S)
*1. Year date code.
Page : 5
of 15
TAPING DIMENSIONS
6N138S/6N139S-TA
6N138S/6N139S-TA1
Description
Symbol
Dimensions in millimeters ( inches )
Tape wide
W
16 ± 0.3 ( .63 )
Pitch of sprocket holes
P0
4 ± 0.1 ( .15 )
Distance of compartment
F
P2
7.5 ± 0.1 ( .295 )
2 ± 0.1 ( .079 )
Distance of compartment to compartment
P1
12 ± 0.1 ( .472 )
BNS-OD-C131/A4
Page : 6
of 15
Recommended Lead Free Reflow Profile
BNS-OD-C131/A4
Page : 7
of 15
Absolute Maximum Ratings*1
Parameter
Symbol
Device
Min
TYP
Max
Units
Storage Temperature
TST
-55
125
o
Operating Temperature
TA
-20
85
o
6N138
6N139
5000
C
C
Isolation Voltage
VISO
VRMS
Supply Voltage
VCC
15
V
Lead Solder Temperature * 2
TSOL
260
°C
Average Forward Input Current
IF
mA
Reverse Input Voltage
VR
5
V
Input Power Dissipation
PI
35
mW
50
mA
Input
6N138
6N139
Output
Average Output Current
IO
6N138
6N139
6N138
Supply Voltage, Output Voltage
7
V
6N139
Output Collector Power Dissipation
-0.5
Vcc, VO
PO
6N138
6N139
-0.5
18
100
mW
1.Ambient temperature = 25oC, unless otherwise specified. Stresses exceeding the absolute maximum
ratings can cause permanent damage to the device. Exposure to absolute maximum ratings for long periods
of time can adversely affect reliability.
2. 260oC for 10 seconds. Refer to Lead Free Reflow Profile.
BNS-OD-C131/A4
Page : 8
of 15
Electrical Specifications
Parameters
Test Condition
Symbol
Device
Min
Typ
Max
Units
1.1
1.7
V
Input
Input Forward Voltage
IF =1.6mA, TA=25℃
Temperature Coefficient
IF=1.6mA
Input Reverse Voltage
IR = 10µA TA=25℃
BVR
5
V
Input Capacitance
VF=0; f=1MHZ
CIN
60
pF
300
1600
2600
400
2000
5000
500
1600
2600
0.1
0.4
0.1
VF
∆VF/∆Ta
mV/℃
-1.9
6N138
6N139
Detector
IF=1.6mA;Vo=0.4V;
Vcc=4.5V
Current transfer ratio
IF=0.5mA;Vo=0.4V;
Vcc=4.5V
6N138
CTR
IF=1.6mA;Vcc=0.4V;
Vcc=4.5V
Logic low output voltage
IF=1.6mA;Vcc=4.5V;
Io=4.8mA
IF=0.5mA;Vcc=4.5V;
Io=2mA
IF=1.6mA;Vcc=4.5V;
Io=8mA
IF=5mA;Vcc=4.5V;
Io=15mA
IF=12mA;Vcc=4.5V;
Io=24mA
6N138
VOL
V
6N139
IF=0mA, Vo=Vcc=7V
TA=25℃
Logic high output current
6N139
6N138
0.4
0.2
0.05
250
μA
IOH
IF=0mA, Vo=Vcc=18V
TA=25℃
6N139
0.1
100
Logic low supply current
IF=1.6mA, Vo=open
(Vcc=18V)
IccL
6N138
6N139
0.4
1.5
mA
Logic high supply current
IF=0mA, Vo=open ;
TA=25℃ (Vcc=18V)
IccH
6N138
6N139
0.01
10
uA
*All Typical at TA =25°C
BNS-OD-C131/A4
Page : 9
of 15
SWITCHING SPECIFICATIONS (AC)
TA=0~70℃, Vcc=5V, unless otherwise specified.
Parameter
Test Condition
Symbol
IF=1.6mA; RL= 2.2kΩ
Propagation Delay Time to
Low Output Level
IF=0.5mA; RL=4.7KΩ
Device
Min
Typ
Max
6N138
1.6
10
5
25
0.1
1
10
35
18
60
2
7
tPHL
μs
6N139
IF=12mA; RL=270Ω
IF=1.6mA; RL= 2.2kΩ
High Output Level
Units
IF=0.5mA; RL=4.7KΩ
6N138
tPLH
μs
6N139
IF=12mA; RL=270Ω
KV/µs
Logic High Common Mode
Transient Immunity
IF=0mA; |VCM|=10Vp-p
RL=2.2KΩ
|CMH|
6N138
6N139
1
10
KV/µs
Logic Low Common Mode
Transient Immunity
IF=1.6mA;
|VCM|=10Vp-p RL=2.2K
Ω
KV/µs
|CML|
6N138
6N139
1
10
KV/µs
BNS-OD-C131/A4
Page : 10
of 15
Isolation Characteristics
Parameter
Test Condition
Symbol
Input-Output Insulation
Leakage Current
45% RH, t = 5s,
o
VI-O = 3kV DC, TA = 25 C
II-O
Withstand Insulation
Test Voltage
RH ≤ 50%, t = 1min,
o
TA = 25 C
VISO
Input-Output Resistance
VI-O = 500V DC
RI-O
Min
Typ
Max
Units
1.0
µA
5000
VRMS
12
Ω
10
Notes,
1. AC For 1 Minute, R.H. = 40 ~ 60%. Isolation voltage shall be measured using the following method.
(1) Short between anode and cathode on the primary side and between collector and emitter on the secondary
side.
(2) The isolation voltage tester with zero-cross circuit shall be used.
(3) The waveform of applied voltage shall be a sine wave.
2. For 10 Seconds
3. Current Transfer Ratio (CTR) is defined as the ration of output collector current, Io, to the forward LED
input current, IF, times 100%.
4. Pin 7 open.
5. Instantaneous common mode rejection voltage "output (1)" represents a common mode voltage variation that can
hold the output above (1) level (Vo>2.0V).Instantaneous common mode rejection voltage "output (0)" represents a
common mode voltage variation that can hold the output above (0) level (Vo
很抱歉,暂时无法提供与“6N138S-L”相匹配的价格&库存,您可以联系我们找货
