4P-SDN
4P-SDN
    JST
    P=3.96mm
4P-SDN 数据手册
SDN CONNECTOR 3.96mm pitch/Board-in Crimp style connectors 1 2 3 4 5 Specifications ––––––––––––––––––– The SDN connector is a 3.96mm pitch board-in crimp style connector capable of connecting a wide variety of circuits including signal and power supply circuits. The connector features a slim, low-profile design. In addition, it has an exclusive lance construction to reduce insertion force, thus substantially improving the working efficiency in mounting the contact. • Current rating: 7A AC, DC (AWG #18) • Voltage rating: 250V AC, DC • Temperature range: -25˚C to +85˚C (including temperature rise in applying electrical current) • Insulation resistance: 1,000M Ω min. • Withstanding voltage: 1,500V AC/minute • Applicable wire: AWG #22 to #18 • Applicable PC board thickness: 1.6mm * Compliant with RoHS. * Refer to "General Instruction and Notice when using Terminals and Connectors" at the end of this catalog. * Contact JST for details. Standards –––––––––––––––––––––– • Slim, low-profile design • Easy and secure contact mounting • Improved solderability • Polarizing boss 0 Recognized E60389 1 Certified LR20812 2 R50100763 PC board layout (viewed from soldering side) and Assembly layout 6.2 3.96 ±0.05 2.5 min 1.98 ±0.05 7.0 2.7 ±0.05 4.0 min φ1.5 +0.1 0 3.9 φ1.55 ±0.05(Circuit No.1) Note: 1. Tolerances are non-cumulative: ±0.05mm for all centers. For connectors with 5 or more circuits the hole dimensions will differ from the above values. Contact JST for details. 2. Hole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. 1 SDN CONNECTOR Contact Applicable wire AWG # mm2 Model No. SDN-21T-P1.5 1.3 0.33∼0.83 Insulation O.D.(mm) Q’ty / reel 1.6∼3.0 5,000 22∼18 Material and Finish Phosphor bronze, tin-plated (reflow treatment) 10.1 4.8 1.5 RoHS compliance 1.9 Contact SDN-21T-P1.5 Crimping machine Crimp applicator AP-K2N Applicator Dies Crimp applicator with dies MKS-L MK/SDN-21-15 APLMK SDN21-15 −− −− −− Housing Circuits 2 3 B A 2.5 4 2.5 3.96 6.2 5 6 2 3 12 7 7.0 1 8 9 10 11 Polarizing boss φ1.2 1.98 12 Model No. With polarizing boss Without polarizing boss 2P-SDN-A 2P-SDN 3P-SDN-A 3P-SDN 4P-SDN-A 4P-SDN 5P-SDN-A 5P-SDN 6P-SDN-A 6P-SDN 7P-SDN-A 7P-SDN 8P-SDN-A 8P-SDN 9P-SDN-A 9P-SDN 10P-SDN-A 10P-SDN 11P-SDN-A 11P-SDN 12P-SDN-A 12P-SDN Dimensions (mm) A B Q'ty / bag 3.96 8.96 1,000 7.92 12.92 1,000 11.88 16.88 1,000 15.84 20.84 1,000 19.80 24.80 500 23.76 28.76 500 27.72 32.72 500 31.68 36.68 500 35.64 40.64 500 39.60 44.60 500 43.56 48.56 500 Material PA 66, UL94V-0, natural (white) RoHS compliance 2
4P-SDN 价格&库存
很抱歉,暂时无法提供与“4P-SDN”相匹配的价格&库存,您可以联系我们找货
4P-SDN
    • 1000+0.25010
    库存:3000
    4P-SDN
      • 1+0.797631+0.10283
      • 10+0.5609810+0.07232
      • 50+0.4908550+0.06328
      • 100+0.43826100+0.05650
      • 500+0.41197500+0.05311
      • 1000+0.394441000+0.05085
      • 2000+0.394442000+0.05085
      库存:586
      4P-SDN
      • 1000+0.690511000+0.08902
      4P-SDN
        • 100+0.23632
        库存:660
