ESD56181WXX
ESD56181WXX
1-Line, Uni-directional, Transient Voltage Suppressor
http//:www.sh-willsemi.com
Descriptions
The ESD56181WXX is a transient voltage suppressor
designed to protect power interfaces. It is suitable to replace
multiple discrete components in portable electronics.
The ESD56181WXX is specifically designed to protect power
lines.
SOD-323
The ESD56181WXX is available in SOD-323 package.
Standard products are Pb-free and Halogen-free.
Features
Pin1
Reverse stand-off voltage: 4.5V ~ 20V
Surge protection according to IEC61000-4-5
see Table 4
Pin2
Circuit diagram
ESD protection according to IEC61000-4-2
±30kV (contact and air discharge)
Low clamping voltage
Solid-state silicon technology
Applications
Power supply protection
X= Device code
Power management
* = Month code
Marking (Top View)
Order information
Table 1.
Device
Package
Shipping
Marking
ESD56181W04-2/TR
SOD-323
3000/Tape&Reel
TQ*
ESD56181W05-2/TR
SOD-323
3000/Tape&Reel
TR*
ESD56181W09-2/TR
SOD-323
3000/Tape&Reel
TL*
ESD56181W10-2/TR
SOD-323
3000/Tape&Reel
TS*
ESD56181W12-2/TR
SOD-323
3000/Tape&Reel
TM*
ESD56181W15-2/TR
SOD-323
3000/Tape&Reel
TN*
ESD56181W18-2/TR
SOD-323
3000/Tape&Reel
TT*
ESD56181W20-2/TR
SOD-323
3000/Tape&Reel
TU*
Will Semiconductor Ltd.
1
Revision 1.2, 2018/02/28
ESD56181WXX
Absolute maximum ratings
Table 2.
Parameter
Peak pulse power (tp = 8/20μs)
ESD according to IEC61000-4-2 air discharge
Symbol
Rating
Unit
Ppk
1800
W
±30
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
±30
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
TSTG
kV
125
o
-40~85
o
260
o
-55~150
o
C
C
C
C
Electrical characteristics (TA = 25oC, unless otherwise noted)
I
IPP
VF
Forward voltage
VRWM Reverse stand-off voltage
IF
Forward current
IR
Reverse leakage current
VFC
Forward clamping voltage
VBR
Reverse breakdown voltage
IPP
Peak pulse current
VCL
Clamping voltage
IPP
Peak pulse current
VFC VF
IBR
IR
VRWM VBR VCL
V
IF
IPP
Definitions of electrical characteristics
2
ESD56181WXX
o
Electrical characteristics (TA = 25 C, unless otherwise noted)
Table 3.
Reverse
Stand-off
Type number
Voltage
Breakdown voltage
VBR(V)
IBR = 1mA
VRWM (V)
Junction
Reverse
leakage current
IRM(μA) at VRWM
Forward voltage
capacitance
VF(V) IF = 20mA
F = 1MHz,
VR=0V (pF)
Max.
Min.
Typ.
Max.
Typ.
Max.
Min.
Max.
Typ.
Max.
ESD56181W04
4.5
5.2
5.7
6.2
2.0
0.60
1.10
1100
1200
ESD56181W05
5.0
6.6
7.1
7.6
1.0
0.60
1.10
1050
1150
ESD56181W09
9.0
9.7
10.5
11.3
0.1
0.60
1.10
600
700
ESD56181W10
10.0
10.7
11.5
12.3
0.1
0.60
1.10
545
650
ESD56181W12
12.0
12.8
13.6
14.5
0.1
0.60
1.10
425
500
ESD56181W15
15.0
16.0
17.5
19.0
0.1
0.60
1.10
320
350
ESD56181W18
18.0
19.2
21.1
23.0
0.1
0.60
1.10
260
300
ESD56181W20
20.0
21.4
23.2
25.0
0.1
0.60
1.10
240
275
Table 4.
Type number
Rated peak pulse current IPP (A)
1)2)
Clamping voltage
1)2)
VCL(V) at IPP(A)
Max.
Typ.
Max.
ESD56181W04
110
12.5
15
ESD56181W05
100
13.5
16
ESD56181W09
90
17.0
ESD56181W10
85
19.0
21
ESD56181W12
75
21.5
24
ESD56181W15
55
27.5
30
ESD56181W18
45
33.0
35
ESD56181W20
40
34.5
37
Notes:
1)
Non-repetitive current pulse, according to IEC61000-4-5. (8/20μs current waveform)
2)
Non-repetitive current pulse, according to IEC61000-4-2.
3)
Measured from pin 1 to pin 2.
3
ESD56181WXX
o
100
90
Front time: T1= 1.25 T = 8μs
100
90
Time to half-value: T2= 20μs
Current (%)
Peak pulse current (%)
50
T2
10
10
T
5
10
T1
15
Time (μs)
10
30
Peak pulse power (kW)
VC - Clamping voltage (V)
Pulse waveform: tp = 8/20s
ESD56181W20
ESD56181W18
ESD56181W15
25
ESD56181W12
ESD56181W10
ESD56181W09
15
ESD56181W05
10
5
ESD56181W04
Time (ns)
Contact discharge current waveform per IEC61000-4-2
8/20μs waveform per IEC61000-4-5
35
tr = 0.7~1ns
t
60ns
30ns
30
40
60
80
100
120
1
0.1
140
IPP - Peak pulse current (A)
Clamping voltage vs. Peak pulse current
1
10
100
Pulse time (s)
1000
Non-repetitive peak pulse power vs. Pulse time
2.5
IR -Leakage current (μA)
% of Rated power
100
80
60
40
1.5
1.0
0.5
0.0
50
75
100
125
150
ESD56181W04
ESD56181W05
-40
-20
60
80
100
o
TA - Ambient temperature ( C)
Power derating vs. Ambient temperature
Leakage current vs. Ambient temperature
o
4
ESD56181WXX
PACKAGE OUTLINE DIMENSIONS
SOD-323
D
A2
A1
b
E
D1
A
Side View
L1
L
c
θ
Top View
Side View
Dimensions in Millimeters
Symbol
Min.
Typ.
Max.
A
0.800
1.100
A1
0.800
0.850
0.900
A2
0.000
0.100
b
0.250
0.400
c
0.080
0.177
D1
1.600
1.700
1.800
D
2.300
2.800
E
1.150
1.400
L
0.475 Ref.
L1
0.100
0.500
θ
0°
8°
Recommended land pattern (Unit: mm)
0.80
1.40
Notes:
0.80
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
group to ensure your PCB design guidelines are met.
5
ESD56181WXX
TAPE AND REEL INFORMATION
RD
Reel Dimensions
W
Tape Dimensions
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
RD
Reel Dimension
W
Overall width of the carrier tape
P1
Pitch between successive cavity centers
Pin1
Pin1 Quadrant
7inch
13inch
1 8mm
12mm
16mm
2mm
4mm
8mm
Q1
Q2
Q3
6
Q4
很抱歉,暂时无法提供与“ESD56181W09-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.58698
- 50+0.47294
- 150+0.41591
- 国内价格
- 1+0.65120
- 200+0.42020
- 1500+0.36520
- 3000+0.32340
