WS72321E-5/TR
WS72321E-5/TR
    WILLSEMI(韦尔)
    SOT23-5
WS72321E-5/TR 数据手册
WS72321 WS72321 Low-Power Rail-to-Rail Operational Amplifiers Input Output Http//:www.willsemi.com Descriptions The WS72321 series is a single low-voltage operational amplifier with rail-to-rail input/output swing. SOT353 SOT23-5L Ultra low quiescent current makes this amplifier ideal for portable, battery operated equipment. The common mode input range includes ground making the device useful for low−side current−shunt measurements. The ultra small packages allow for placement on the PCB in close proximity to the signal source thereby reducing noise pickup. SOT23-5L SOT353 (WS72321EO-5/TR) (WS72321B-5/TR) & SOT23-5L The WS72321 is available with MSL 3 Level in ( WS72321E-5/TR) SOT353(SC70-5L) package and SOT23-5L package. Pin configuration (Top view) Standard products are Pb-Free and halogen-Free. Applications  Active Filters  Smoke/Gas Sensors  Battery Powered Electronic Equipments  Personal Medical Care Features  Single Supply Voltage  Quiescent Current : 48A Typical  GBWP  SOT353 SOT23-5L SOT23-5L WS72321B-5/TR WS72321E-5/TR WS72321EO-5/TR Marking : 1.8~5.5V 2321 = Device code : 1.5MHz GA = Special code Slew Rate : 1.1V/s N5 = Special code  Offset Voltage : 3mV Maximum B5 = Special code  Offset Voltage Temp. Drift : 0.5V / °C Y = Year code  THD+N :-102dB@1kHz, W = Week code -90dB@10kHz  CMRR/PSRR : 104dB/111dB  Output Short-Circuit Curr. : 43mA  -40 C to 125 C Operation Range  Drives 2kΩ Resistive Loads  No Output Crossover Distortion  No Phase Reversal from Overdriven Input  Rail-to-Rail Input/Output Swing ° Order Information ° Will Semiconductor Ltd. 1 Device Package Shipping WS72321B-5/TR SOT353 3000/Reel &Tape WS72321E-5/TR SOT23 -5L 3000/Reel &Tape WS72321EO-5/TR SOT23 -5L 3000/Reel &Tape Aug, 2020 - Rev. 1.3 WS72321 Pin Descriptions (WS72321B-5/TR & WS72321E-5/TR) Pin Number Symbol Descriptions 1 +IN 2 V- Negative supply 3 -IN Inverting input 4 OUT 5 V+ Non-inverting input Output Positive supply Pin Descriptions (WS72321EO-5/TR) Pin Number Symbol Descriptions 1 OUT 2 V- 3 +IN Non-inverting input 4 -IN Inverting input 5 V+ Positive supply Output Negative supply Absolute Maximum Ratings Parameter Supply Voltage, ([V+] - [V-]) Input Differential Voltage Symbol Value Unit VS(2) 6 V VIDR(3) 6 Input Common Mode Voltage Range VICR (V )-0.2 to (V )+0.2 Output Short-Circuit Duration tSO Unlimited Operating Fee-Air Temperature Range TA -40 to 125 ° Storage Temperature Range TSTG -65 to 150 ° Junction Temperature Range TJ 150 ° 260 °C Lead Temperature Range - V + TL V / C C C Note: 1. Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. These are only stress ratings, and functional operation of the device at these or any other conditions beyond those indicated under recommended operating conditions are not implied. Exposure to absolute-maximum-rated conditions for extended periods may affect device reliability. 2. All voltage values, except differential voltage are with respect to network terminal. 3. Differential voltages are at +IN with respect to –IN. ESD, Electrostatic Discharge Protection Symbol Parameter Condition MIL-STD-883H Method 3015.8 Minimum level Unit ±8000 V HBM Human Body Model ESD MM Machine Model ESD JEDEC-EIA/JESD22-A115 ±500 V Charged Device Model ESD JEDEC-EIA/JESD22-C101E ±2000 V CDM Will Semiconductor Ltd. JEDEC-EIA/JESD22-A114A 2 Aug, 2020 - Rev. 1.3 WS72321 Electronics Characteristics The *denotes the specifications which apply over the full operating temperature range, otherwise specifications are at TA = 25°C. VS = 5V, VCM = VOUT = VS/2, Rload = 100kΩ, Cload = 100pF. Symbol Parameter Conditions VCM= VS/2 * Min. Typ. Max. Unit -3.0 0.1 3.0 mV VOS Input Offset Voltage VOS Input Offset Voltage Drift 0.5 μV/°C IIB Input Bias Current 10 pA IOS Input Offset Current 10 pA Vn Input Voltage Noise f=0.1Hz to10Hz 4 VP-P en Input Voltage Noise Density f=1kHz 30 f=10kHz 23 CMRR Common Mode Rejection Ratio VCM nV/√Hz * 80 Common Mode Input Voltage Range * (V-)-0.2 PSRR Power Supply Rejection Ratio * 80 111 dB AVOL Open Loop Large Signal Gain * 100 108 dB VOH High Level Output Voltage VOL Low Level Output Voltage ISC Output Short-Circuit Current IQ Quiescent Current PM Phase Margin GM Gain Margin GBWP Gain-Bandwidth Product Settling tS Time VCM=0.1V to 4.9V VOUT=0.1V to 4.9V, Rload=10k 50 Rload=10k 5 Rload=2k 40 Rload=10k 5 Source Current 43 Sink Current 47 * Rload=100k, Gain 48 V mV mV mA 65 A 60 degrees -14 dB f=1kHz 1.5 MHz 0.1% 1.9 0.1% 0.29 Cload=100pF Cload=100pF 2.45 to 2.55V, Unity dB (V+)+0.2 Rload=2k Rload=100k, 1.5 to 3.5V, Unity Gain 104 s AV=1, VOUT=1.5V SR Slew Rate to 3.5V, Rload=100k, 1.1 V/s 180 kHz Cload=100pF FPBW Full Power Bandwidth 2VP-P f=1kHz, AV=1, Rload=100k, THD+N Total Harmonic Distortion and Noise -102 VOUT=2VPP dB f=10kHz, AV=1, Rload=100k, -90 VOUT=2VPP Will Semiconductor Ltd. 3 Aug, 2020 - Rev. 1.3 WS72321 Note: 1. Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. 2. A heat sink may be required to keep the junction temperature below the absolute maximum rating when the output is shorted indefinitely. 3. Thermal resistance varies with the amount of PC board metal connected to the package. The specified values are for short traces connected to the leads. 4. Full power bandwidth is calculated from the slew rate FPBW = SR/(π • VP-P). Will Semiconductor Ltd. 4 Aug, 2020 - Rev. 1.3 WS72321 Typical Characteristics TA=25°C, VS=±2.5V, VCM=0V, unless otherwise noted Small-Siganl Step Response, 100mV Step Large-Siganl Step Response, 2V Step Over Shoot Voltage, Cload=47nF, Over Shoot Voltage, Cload=47nF, RFB=10kΩ, Gain=+1 Rload=40kΩ, Gain=-1 Open-Loop Gain and Phase Phase Margin vs. Cload (Stable for Any Cload) Will Semiconductor Ltd. 5 Aug, 2020 - Rev. 1.3 WS72321 Typical Characteristics (continued) TA=25°C, VS=±2.5V, VCM=0V, unless otherwise noted Input Offset Voltage vs. Temperature CMRR vs. Frequency Over-Shoot % vs. Cload Over-Shoot % vs. Cload Gain=-1, RFB=20kΩ Gain=+1 PSRR vs. Frequency Closed-Loop Output Impedance vs. Frequency Will Semiconductor Ltd. 6 Aug, 2020 - Rev. 1.3 WS72321 Typical Characteristics (continued) TA=25°C, VS=±2.5V, VCM=0V, unless otherwise noted Quiescent Supply Current vs. Temperature Quiescent Supply Current vs. Supply Voltage Short-Circuit Current vs. Supply Voltage Input Offset Voltage Distribution THD+Noise vs. Vin+ THD+Noise vs. Frequency Will Semiconductor Ltd. 7 Aug, 2020 - Rev. 1.3 WS72321 Typical Characteristics (continued) TA=25°C, VS=±2.5V, VCM=0V, unless otherwise noted VIN=-0.2V to 5.7V, No Phase Reversal 0.1Hz to 10Hz Integrated Input Noise, Gain = 10000 Will Semiconductor Ltd. 8 Aug, 2020 - Rev. 1.3 WS72321 PACKAGE OUTLINE DIMENSIONS SOT-353(SC70-5L) D θ b L L1 K M E E1 (Ⅰ ) (Ⅱ ) c e e1 A A1 SIDE VIEW A2 TOP VIEW SIDE VIEW Symbol Dimensions in Millimeters Min. Typ. Max. A 0.80 0.95 1.10 A1 0.00 - 0.10 A2 0.80 0.90 1.00 b 0.15 0.25 0.35 c 0.08 - 0.20 D 2.00 2.10 2.20 E1 1.15 1.25 1.35 E 2.15 2.30 2.45 e e1 0.65 Typ. 1.20 1.30 L1 1.40 0.50 Ref. L 0.26 0.36 0.46 M 0.10 0.15 0.25 K 0.00 - 0.25 θ 0︒ - 14︒ Will Semiconductor Ltd. 9 Aug, 2020 - Rev. 1.3 WS72321 TAPE AND REEL INFORMATION SOT-353(SC70-5L) Reel Dimensions RD Reel Dimensions Tape Dimensions W P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 User Direction of Feed RD Reel Dimension 7inch 13inch W Overall width of the carrier tape 8mm 12mm P1 Pitch between successive cavity centers 2mm 4mm 8mm Pin1 Pin1 Quadrant Q1 Q2 Q3 Will Semiconductor Ltd. 10 Q4 Aug, 2020 - Rev. 1.3 WS72321 PACKAGE OUTLINE DIMENSIONS SOT-23-5L D θ b L L1 K M E E1 (Ⅰ ) (Ⅱ ) c e e1 A A1 SIDE VIEW A2 TOP VIEW SIDE VIEW Symbol Dimensions in Millimeters Min. Typ. Max. A - - 1.45 A1 0.00 - 0.15 A2 0.90 1.10 1.30 b 0.30 0.40 0.50 c 0.10 - 0.21 D 2.72 2.92 3.12 E 2.60 2.80 3.00 E1 1.40 1.60 1.80 e 0.95 BSC e1 1.90 BSC L 0.30 0.45 0.60 M 0.10 0.15 0.25 K 0.00 - 0.25 θ 0° - 8° Will Semiconductor Ltd. 11 Aug, 2020 - Rev. 1.3 WS72321 TAPE AND REEL INFORMATION SOT-23-5L Reel Dimensions RD Reel Dimensions Tape Dimensions W P1 Quadrant Assignments For PIN1 Orientation In Tape Q1 Q2 Q1 Q2 Q3 Q4 Q3 Q4 RD Reel Dimension W Overall width of the carrier tape P1 Pitch between successive cavity centers Pin1 Pin1 Quadrant Will Semiconductor Ltd. User Direction of Feed 12 7inch 13inch 1 8mm 12mm 16mm 2mm 4mm 8mm Q1 Q2 Q3 Q4 Aug, 2020 - Rev. 1.3
WS72321E-5/TR 价格&库存
很抱歉,暂时无法提供与“WS72321E-5/TR”相匹配的价格&库存,您可以联系我们找货
