MLI2012F-100KT
MLI2012F-100KT
    MELED(美莱)
    MLI2012F-100KT
MLI2012F-100KT 数据手册
Meled Specifications for Multi-layer Chip Ferrite Inductor S P E C I F I C AT I O N S Customer: Customer P/N: Seri es MLI-F Drawing No: Quantity: 0 Pcs. Meled P/N: Date : 2017/09/06 Series/參照 MLI-F SPECIFICATION ACCEPTED BY: COMPONENT ENGINEER ELECTRICAL ENGINEER MECHANICAL ENGINEER APPROVED REJECTED For Customer approval Only Qualification Status: Full Approved By Verified By Restricted Rejected Re-checked By Checked By Comments: Meled Electronics Co., Ltd. www.meledinc.com Meled Specifications for Multi-layer Chip Ferrite Inductor Version change history Rev. Effective Date Changed Contents Change Reasons Approved By 01 / New release / / www.meledinc.com Meled 1. Specifications for Multi-layer Chip Ferrite Inductor Scope This specification applies to MLI-F Series of multi-layer ferrite chip bead. 2. Product Description and Identification (Part Number) 1) 2) Description: MLI -F Series of multi-layer ferrite chip bead. Product Identification (Part Number) MLI F □□□□ -□□□ T □ Packaging Tolerance Inductance Material Code Dimension Scope 3.Rating O p e ra tin g T e m p e ra tu re : - 5 5 ℃ ~ 1 2 5 ℃ (In clu d in g se lf - te m p e ra tu re rise ) S to ra g e T e m p e ra tu re : - 5 5 ℃ ~ 1 2 5 ℃ (a fte r P C B ) - 5 ℃ ~ 4 0 ℃ ,H u m id ity 4 0 % ~ 7 0 % (b e fo re P C B ) 4. ShapeandDimensions 1) Dimensions and recommended PCB pattern for reflow soldering: See Fig.4-1, Fig.4-2 and Table 4-1. 2) Structure: See Fig. 4-3 and Fig. 4-4. Solder-resist Chip Bead C Land pattern B A B Fig. 4-2 Fig. 4-1 T Structure of Electro-plating L a ② Internal electrode (Ag) T a Ferrite Sn W ④-2 ① ② ③ ④ ① Ferrite for Bead Series ④-1 Terminal electrode: Inside (Ag) Ni ④-2 Outside (Electro-plating Ni-Sn) ④-1 Ag Fig. 4-4 Fig. 4-3 Unit: mm [inch] [Table 4-1] Type 1005 [0402] L 1.0±0.15 [0.039±0.006] W 0.5±0.15 [0.020±0.006] T 0.5±0.15 [0.020±0.006] a 0.25±0.1 [0.010±0.004] 1608 [0603] 1.6±0.15 [0.063±0.006] 0.8±0.15 [0.031±0.006] 0.8±0.15 [0.031±0.006] 0.3±0.2 [0.012±0.008] 1.25±0.2 [0.049±0.008] 1.6±0.2 [0.063±0.008] 0.85±0.2 [0.033±0.008] 0.85±0.2 [0.033±0.008] 0.5±0.3 [0.020±0.012] 0.5±0.3 [0.020±0.012] 2012 [0805] 3216 [1206] ③ Pull out electrode( Ag) 2.0 (+0.3, -0.1) [0.079(+0.012,-0.004)] 3.2±0.2 [0.126±0.008] A B C 0.45~0.55 0.40~0.50 0.45~0.55 0.60~0.80 0.60~0.80 0.60~0.80 0.80~1.20 0.80~1.20 0.90~1.60 1.80~2.50 1.00~1.50 1.20~2.00 Meled Specifications for Multi-layer Chip Ferrite Inductor Appendix A: Electrical Characteristics I. MLI1005F Series of Inductors Part Number MLI1005F-47NKT MLI1005F-68NKT MLI1005F-82NKT MLI1005F-R10KT MLI1005F-R12KT MLI1005F-R15KT MLI1005F-R18KT MLI1005F-R22KT MLI1005F-R27KT MLI1005F-R33KT MLI1005F-R39KT MLI1005F-R47KT MLI1005F-R56KT MLI1005F-R68KT MLI1005F-R82KT MLI1005F-1R0KT MLI1005F-1R2KT MLI1005F-1R5KT MLI1005F-1R8KT MLI1005F-2R2KT MLI1005F-2R7KT MLI1005F-3R3KT L Q (µH) Min. 0.047 0.068 0.082 0.1 0.12 0.15 0.18 0.22 0.27 0.33 0.39 0.47 0.56 0.68 0.82 1.0 1.2 1.5 1.8 2.2 2.7 3.3 10 10 10 10 10 10 10 10 15 15 20 20 20 20 20 20 20 20 20 20 20 20 L, Q Test. S.R.F Freq. Min. (MHz) (MHz) 50 50 50 25 25 25 25 25 25 25 10 10 10 10 10 10 10 10 10 10 10 10 220 210 200 200 165 140 120 110 95 85 85 80 75 70 65 40 35 30 30 28 28 28 L, Q Test. S.R.F Freq. Min. (MHz) (MHz) 50 50 50 25 25 25 25 25 25 25 25 25 25 25 25 10 10 10 10 10 10 10 260 250 245 240 205 180 165 150 136 125 110 105 95 90 85 75 65 60 55 50 45 40 DCR Max. (Ω) 0.45 0.45 0.45 0.8 0.8 0.9 0.9 1.2 1.2 1.25 0.6 0.7 0.8 0.9 0.9 0.9 1.2 1.2 1.45 1.7 2.4 2.7 Ir Max. (mA) 25 25 25 25 25 25 25 25 25 18 15 15 15 15 15 15 15 15 15 10 10 10 Thickness (mm) [inch] 0.5±0.15 [0.020±0.006] II. MLI1608F Series of Inductors Part Number MLI1608F-47NKT MLI1608F-68NKT MLI1608F-82NKT MLI1608F-R10KT MLI1608F-R12KT MLI1608F-R15KT MLI1608F-R18KT MLI1608F-R22KT MLI1608F-R27KT MLI1608F-R33KT MLI1608F-R39KT MLI1608F-R47KT MLI1608F-R56KT MLI1608F-R68KT MLI1608F-R82KT MLI1608F-1R0KT MLI1608F-1R2KT MLI1608F-1R5KT MLI1608F-1R8KT MLI1608F-2R2KT MLI1608F-2R7KT MLI1608F-3R3KT L Q (µH) Min. 0.047 0.068 0.082 0.1 0.12 0.15 0.18 0.22 0.27 0.33 0.39 0.47 0.56 0.68 0.82 1.0 1.2 1.5 1.8 2.2 2.7 3.3 10 10 10 15 15 15 15 15 15 15 15 15 15 15 15 35 35 35 35 35 35 35 www.meledinc.com DCR Max. (Ω) 0.3 0.3 0.3 0.5 0.5 0.6 0.6 0.8 0.8 0.85 1.0 1.35 1.55 1.7 2.1 0.6 0.8 0.8 0.95 1.15 1.35 1.55 Ir Max. (mA) 50 50 50 50 50 50 50 50 50 35 35 35 35 35 35 25 25 25 25 15 15 15 Thickness (mm) [inch] 0.8±0.15 [0.031±0.006] Meled Specifications for Multi-layer Chip Ferrite Inductor II. MLI1608F Series of Inductors Part Number MLI1608F-3R9KT MLI1608F-4R7KT MLI1608F-5R6KT MLI1608F-6R8KT MLI1608F-8R2KT MLI1608F-100KT MLI1608F-120KT MLI1608F-150KT MLI1608F-180KT MLI1608F-220KT MLI1608F-270KT MLI1608F-330KT L Q (µH) Min. 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 27 33 35 35 35 35 35 30 30 20 20 20 20 20 L, Q Test. S.R.F Freq. Min. (MHz) (MHz) 10 10 4 4 4 2 2 1 1 1 1 1 35 33 22 20 18 17 15 14 13 11 10 9 L, Q Test. S.R.F Freq. Min. (MHz) (MHz) 50 50 50 25 25 25 25 25 25 25 25 25 25 25 25 10 10 10 10 10 10 10 10 10 4 4 4 2 320 280 255 235 220 200 185 170 150 145 135 125 115 105 100 75 65 60 55 50 45 41 38 35 32 29 26 24 DCR Max. (Ω) 1.7 2.1 1.55 1.7 2.1 1.85 2.1 1.7 1.85 2.1 2.75 2.95 Ir Max. (mA) 15 15 5 5 5 3 3 1 1 1 1 1 Thickness (mm) [inch] 0.8±0.15 [0.031±0.008] III. MLI2012F Series of Inductors Part Number MLI2012F-47NKT MLI2012F-68NKT MLI2012F-82NKT MLI2012F-R10KT MLI2012F-R12KT MLI2012F-R15KT MLI2012F-R18KT MLI2012F-R22KT MLI2012F-R27KT MLI2012F-R33KT MLI2012F-R39KT MLI2012F-R47KT MLI2012F-R56KT MLI2012F-R68KT MLI2012F-R82KT MLI2012F-1R0KT MLI2012F-1R2KT MLI2012F-1R5KT MLI2012F-1R8KT MLI2012F-2R2KT MLI2012F-2R7KT MLI2012F-3R3KT MLI2012F-3R9KT MLI2012F-4R7KT MLI2012F-5R6KT MLI2012F-6R8KT MLI2012F-8R2KT MLI2012F-100KT L Q (µH) Min. 0.047 0.068 0.082 0.1 0.12 0.15 0.18 0.22 0.27 0.33 0.39 0.47 0.56 0.68 0.82 1.0 1.2 1.5 1.8 2.2 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 15 15 15 20 20 20 20 20 20 20 25 25 25 25 25 45 45 45 45 45 45 45 45 45 50 50 50 50 www.meledinc.com DCR Max. (Ω) 0.2 0.2 0.2 0.3 0.3 0.4 0.4 0.5 0.5 0.55 0.65 0.65 0.75 0.8 1 0.4 0.5 0.5 0.6 0.65 0.75 0.8 0.9 1 0.9 1 1.1 1.15 Ir Max. (mA) 300 300 300 250 250 250 250 250 250 250 200 200 150 150 150 50 50 50 50 30 30 30 30 30 15 15 15 15 Thickness (mm) [inch] 0.85±0.15 [0.033±0.008] Meled Specifications for Multi-layer Chip Ferrite Inductor III. MLI2012F Series of Inductors Part Number MLI2012F-120KT MLI2012F-150KT MLI2012F-180KT MLI2012F-220KT L Q (µH) Min. 12 15 18 22 50 30 30 30 L, Q Test. S.R.F Freq. Min. (MHz) (MHz) 2 1 1 1 22 19 18 16 L, Q Test. S.R.F Freq. Min. (MHz) (MHz) 1 0.4 2 2 2 1 1 1 14 13 8 7.5 7 6.5 6 5.5 L, Q Test. S.R.F Freq. Min. (MHz) (MHz) 50 50 50 25 25 25 25 25 25 25 25 25 25 25 25 10 10 10 10 10 320 280 280 235 220 200 185 170 150 145 135 125 115 105 100 75 65 60 55 50 DCR Max. (Ω) 1.25 0.8 0.9 1.1 Ir Max. (mA) 15 5 5 5 Thickness (mm) [inch] 0.85±0.15 [0.033±0.008] III. MLI2012F Series of Inductors Part Number MLI1F-8R2KT MLI2012F-270KT MLI2012F-330KT MLI2012F-390KT MLI2012F-470KT MLI2012F-560KT MLI2012F-680KT MLI2012F-820KT MLI2012F-101KT L Q (µH) Min. 27 33 39 47 56 68 82 100 30 30 35 35 25 25 25 25 DCR Max. (Ω) 1.15 1.25 2.9 3 3.1 2.9 3 3.1 Ir Max. (mA) 5 5 4 4 4 2 2 2 Thickness (mm) [inch] 1.25±0.15 [0.049±0.008] IV.MLI3216F Series of Inductors Part Number MLI3216F-47NKT MLI3216F-68NKT MLI3216F-82NKT MLI3216F-R10KT MLI3216F-R12KT MLI3216F-R15KT MLI3216F-R18KT MLI3216F-R22KT MLI3216F-R27KT MLI3216F-R33KT MLI3216F-R39KT MLI3216F-R47KT MLI3216F-R56KT MLI3216F-R68KT MLI3216F-R82KT MLI3216F-1R0KT MLI3216F-1R2KT MLI3216F-1R5KT MLI3216F-1R8KT MLI3216F-2R2KT L Q (µH) Min. 0.047 0.068 0.082 0.1 0.12 0.15 0.18 0.22 0.27 0.33 0.39 0.47 0.56 0.68 0.82 1.0 1.2 1.5 1.8 2.2 20 20 20 20 20 20 20 20 20 20 25 25 25 25 25 45 45 45 45 45 www.meledinc.com DCR Max. (Ω) 0.15 0.25 0.25 0.25 0.3 0.3 0.4 0.4 0.5 0.5 0.5 0.6 0.7 0.8 0.9 0.4 0.5 0.5 0.5 0.6 Ir Max. (mA) 300 300 300 250 250 250 250 250 250 250 200 200 150 150 150 100 100 50 50 50 Thickness (mm) [inch] 0.85±0.15 [0.033±0.008] Meled Specifications for Multi-layer Chip Ferrite Inductor IV.MLI3216F Series of Inductors Part Number MLI3216F-2R7KT MLI3216F-3R3KT MLI3216F-3R9KT MLI3216F-4R7KT MLI3216F-5R6KT MLI3216F-6R8KT MLI3216F-8R2KT MLI3216F-100KT MLI3216F-120KT MLI3216F-150KT MLI3216F-180KT MLI3216F-220KT MLI3216F-270KT L Q (µH) Min. 2.7 3.3 3.9 4.7 5.6 6.8 8.2 10 12 15 18 22 27 45 45 45 45 50 50 50 50 50 35 35 35 35 L, Q Test. S.R.F Freq. Min. (MHz) (MHz) 10 10 10 10 4 4 4 2 2 1 1 1 1 45 41 38 35 32 29 26 24 22 19 18 16 14 DCR Max. (Ω) 0.6 0.7 0.8 0.9 0.7 0.8 0.9 1 1.05 0.7 0.7 0.9 0.9 Ir Max. (mA) 50 50 50 50 25 25 25 25 15 5 5 5 5 Thickness (mm) [inch] 0.85±0.15 [0.033±0.008] IV.MLI3216F Series of Inductors Part Number MLI3216F-330KT MLI3216F-390KT MLI3216F-470KT MLI3216F-560KT MLI3216F-680KT MLI3216F-820KT MLI3216F-101KT L Q (µH) Min. 33 39 47 56 68 82 100 35 40 40 10 10 10 10 L, Q Test. S.R.F Freq. Min. (MHz) (MHz) 0.4 2 2 2 1 1 1 13 11 10 9.5 9.5 9 8 DCR Max. (Ω) 1.05 3 3.4 3.8 3 3.4 3.8 Ir Max. (mA) 5 5 5 4 4 4 4 Thickness (mm) [inch] 1.1±0.15 [0.043±0.008] Products with other electrical characteristic can be provided upon customer’s request. Please contact your local sales. www.meledinc.com
MLI2012F-100KT 价格&库存
很抱歉,暂时无法提供与“MLI2012F-100KT”相匹配的价格&库存,您可以联系我们找货
