KBP310
KBP310
    YFW(佑风微)
    KBP
    桥式整流器/整流桥 KBP 1KV 5μA
KBP310 数据手册
KBP301 THRU KBP310 KBP 3.0A GLASS PASSIVATED BRIDGE RECTIFIER Reverse Voltage - 100 to 1000 V Forward Current – 3.0A FEATURES  High current capability  Low forward voltage drop  Glass Passivated Chip Junction  Low power loss, high efficiency  Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA  Case: KBP  Terminals: Solderable per MIL-STD-202, Method 208 1.Input pin(+) 2.Input pin(~) 3.Output Anode(~) 4.Output Cathode(-)  Approx. Weight: 1.52g / 0.05oz KBP Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Parameter Symbols KBP301 KBP302 KBP304 KBP306 KBP308 KBP310 Units Maximum Repetitive Peak Reverse Voltage VRRM 100 200 400 600 800 1000 V Maximum RMS voltage VRMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage VDC 100 200 400 600 800 1000 V Average Rectified Output Current I(AV) 3 IFSM 55 A IFSM 110 A VF 1.1 V Peak Forward Surge Current 8.3 ms Single Half Sine-Wave Superimposed on Rated Load (JEDEC method) Peak Forward Surge Current 1.0ms single half sine-wave @ Tj = 25 ℃ Forward Voltage per element @IF =3.0A and 25°C Maximum DC Reverse Current @Tj=25°C at Rated DC Blocking Voltage A 5 IR μA 500 @Tj=125°C I2t Rating for Fusing(3ms≤t≤8.3ms) It 2 17.5 AS Typical Junction Capacitance(Note1) Cj 60 pF Typical Thermal Resistance (Note2) RθJA/ RθJC 30/10 °C/W Tj, Tstg -55 ~ +150 °C Operating and Storage Temperature Range 2 (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)Thermal Resistance Junction to Case, Lead and Ambient. www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. KBP301 THRU KBP310 KBP FIG.2- MAXIMUM NON-REPETITIVE SURGE CURRENT FIG.1- FORWARD CURRENT DERATING CURVE 3 80 70 2.5 PEAK FORWARD SURGE CURRENT, (A) AVERAGE FORWARD CURRENT, (A) Heat sink : 30*30*1 mm Copper plate 2 Without heat sink 1.5 1 0.5 60 50 40 30 20 10 RESISTIVE OR INDUCTIVE LOAD 0 Single Half-Sine-Wave 0 0 25 50 75 100 125 150 1 10 CASE TEMAERATURE, (°C) FIG.3- TYPICAL JUNCTION CAPACITANCE FIG.4- TYPICAL FORWORD CHARACTERISTICS 100 INSTANTANEOUS FORWARD CURRENT, (A) 100 CAPACITANCE, (pF) 100 NUMBER OF CYCLES AT 60Hz 10 Tj=25°C, f=1MHz 1 10 Tj=125°C Tj=25°C 1 PULSE WIDTH : 300us 0.1 1 10 100 0.4 0.6 REVERSE VOLTAGE, (V) 0.8 1 1.2 1.4 1.6 INSTANTANEOUS FORWARD VOLTAGE, (V) FIG.5- TYPICAL REVERSE CHARACTERISTICS INSTANTANEOUS REVERSE CURRENT, (uA) 1000 Tj=125°C 100 10 1 0.1 Tj=25°C 0.01 0 100 200 300 400 500 600 700 800 900 RAT ED PEAK REVERSE VOLT AGE, (V) www.yfwdiode.com 2/3 Dongguan YFW Electronics Co, Ltd. KBP301 THRU KBP310 KBP Package Outline KBP KBP MIN. MAX. A 14.25 14.75 B 3.35 3.65 C 10.20 10.60 D 14.25 14.73 d 1.40 1.70 E 1.80 2.20 DIM. F 0.80 1.10 G 3.56 4.06 H 0.35 0.55 I 1.22 1.42 J 0.76 0.86 K + ~ ~ - 2.7 x 45° (Typ) L # 3° M # 2° All Dimensions in millimeter Summary of Packing Options Package KBP www.yfwdiode.com Packing Description Packing Quantity 500 BOX 3/3 Industry Standard EIA-481-1 Dongguan YFW Electronics Co, Ltd.
KBP310 价格&库存
很抱歉,暂时无法提供与“KBP310”相匹配的价格&库存,您可以联系我们找货
KBP310
  • 5+0.81608
  • 50+0.68219
  • 150+0.61519
  • 500+0.51054
  • 2500+0.47032
  • 5000+0.45021
库存:470
