KPTVSxxxS1UR
Surface mount transient voltage suppressor power 200 watts
Stand-Off Voltage: 5.0V~220V
PINNING
PIN
FEATURES
• For surface mounted applications in order to
DESCRIPTION
1
Cathode
2
Anode
optimize board space.
• Low profile package
1
2
• Glass passivated junction
Unipolar
• Low inductance
Top View
• Plastic package has Underwriters Laboratory
Simplified outline sSOD-123FL and symbol
Flammability
MECHANICAL DATA
▪Case: SOD-123FL
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪Approx. Weight:15mg 0.00048oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Parameter
Peak Pulse Power Dissipation on TA=2 5°C (Note 1,2,5, Fig1)
Peak Forward Surge Current (Note 3)
Symbol
Value
Unit
P PPM
200
W
I FSM
A
see Table 1
A
1
W
-55 to +150
°C
(UNI)
Peak Pulse Current on 10/1000 us waveform (Note 1 ) Fig 2
I PPM
Steady State Power Dissipation (Note 4)
P M(AV)
Operating Junction and Storage Range
T J,T STG
RθJA
Typical Thermal Resistance
NOTES
1. Non-repetitive current pulse per Fig 3 and derated above T A=25°C per Fig 2
2. Mounted on 5mm 2 copper pads to each terminal
3. 8.3ms single half sinewave, or equivalent square wave duty cycle=4 pulses per minutes maximum
4. lead temperature at T L=75°C
5. Peak pulse powe. waveform is tp=10/1000us
6. A transient suppressor is selected according to the working peak reverse voltage(V RWM), Which Should be
equal to or greater than the DC or continuous peak operating voltage level
www.cj-elec.com
1/4
180
°C
KPTVSxxxS1UR
Characteristics at Ta = 25°C
Test
Current
Breakdown
Voltage
Type
Marking
Reverse
Leakage
Max. Clamp
Voltage
Peak Pulse
Current
I R @ V RWM
V C @ I PP
I PP
A
V BR @ I T
V RMW
IT
Min
Max
Uni
Uni
V
V
V
mA
μA
V
KPTVS5V0S1UR
AE
5
6.4
7
10
200
9.2
21.7
KPTVS6V0S1UR
AG
6
6.67
7.37
10
100
10.3
19.4
KPTVS6V5S1UR
AK
6.5
7.22
7.98
10
75
11.2
17.9
KPTVS7V0S1UR
AM
7
7.78
8.6
10
50
12
16.7
KPTVS7V5S1UR
AP
7.5
8.33
9.21
1
50
12.9
15.5
KPTVS8V0S1UR
AR
8
8.89
9.83
1
25
13.6
14.7
13.9
KPTVS8V5S1UR
AT
8.5
9.44
10.4
1
10
14.4
KPTVS9V0S1UR
AV
9
10
11.1
1
5
15.4
13
KPTVS10VS1UR
AX
10
11.1
12.3
1
2.5
17
11.8
KPTVS11VS1UR
AZ
11
12.2
13.5
1
2.5
18.2
11
KPTVS12VS1UR
BE
12
13.3
14.7
1
2.5
19.9
10.1
KPTVS13VS1UR
BG
13
14.4
15.9
1
1
21.5
9.3
KPTVS14VS1UR
BK
14
15.6
17.2
1
1
23.2
8.6
KPTVS15VS1UR
BM
15
16.7
18.5
1
1
24.4
8.2
KPTVS16VS1UR
BP
16
17.8
19.7
1
1
26
7.7
KPTVS17VS1UR
BR
17
18.9
20.9
1
1
27.6
7.2
KPTVS18VS1UR
BT
18
1
1
29.2
6.8
KPTVS20VS1UR
BV
24.5
1
1
32.4
6.2
KPTVS22VS1UR
BX
22
24.4
26.9
1
1
35.5
5.6
KPTVS24VS1UR
BZ
24
26.7
29.5
1
1
38.9
5.1
KPTVS26VS1UR
CE
26
28.9
31.9
1
1
42.1
4.8
KPTVS28VS1UR
CG
28
31.1
34.4
1
1
45.4
4.4
KPTVS30VS1UR
CK
30
33.3
36.8
1
1
48.4
4.1
KPTVS33VS1UR
CM
33
36.7
40.6
1
1
53.3
3.8
KPTVS36VS1UR
CP
36
40
44.2
1
1
58.1
3.4
KPTVS40VS1UR
CR
40
44.4
49.1
1
1
64.5
3.1
KPTVS43VS1UR
CT
43
47.8
52.8
1
1
69.4
2.9
KPTVS45VS1UR
CV
45
50
55.3
1
1
72.7
2.8
KPTVS48VS1UR
CX
48
53.3
58.9
1
1
77.4
2.6
KPTVS51VS1UR
CZ
51
56.7
62.7
1
1
82.4
2.4
KPTVS54VS1UR
DE
54
60
66.3
1
1
87.1
2.3
KPTVS58VS1UR
DG
58
64.4
71.2
1
1
93.6
2.1
KPTVS60VS1UR
DK
60
66.7
73.7
1
1
96.8
1.8
KPTVS64VS1UR
DM
64
71.1
78.6
1
1
103
1.7
KPTVS70VS1UR
DP
70
77.8
86
1
1
113
1.5
KPTVS75VS1UR
DR
75
83.3
92.1
1
1
121
1.4
KPTVS78VS1UR
DT
78
86.7
95.8
1
1
126
1.4
KPTVS85VS1UR
DV
85
94.4
104
1
1
137
1.3
KPTVS90VS1UR
DX
90
100
111
1
1
146
1.2
KPTVS100VS1UR
DZ
100
111
123
1
1
162
1.1
KPTVS110VS1UR
EE
110
122
135
1
1
177
1
KPTVS120VS1UR
EG
120
133
147
1
1
193
0.9
KPTVS130VS1UR
EK
130
144
159
1
1
209
0.8
KPTVS150VS1UR
EM
150
167
185
1
1
243
0.7
KPTVS160VS1UR
EP
160
178
197
1
1
259
0.7
KPTVS170VS1UR
ER
170
189
209
1
1
275
0.6
KPTVS180VS1UR
ET
180
201
222
1
1
292
0.5
KPTVS200VS1UR
EX
200
224
247
1
1
324
0.5
KPTVS220VS1UR
E22
220
246
272
1
1
356
0.5
www.cj-elec.com
2/4
KPTVSxxxS1UR
Fig.2 Forward Current Derating Curve
PEAK PULSE POWER(PPP)OR CURRENT(Ipp)
DERATINGIN PERCENTAGE%
P PPM ,PEAK PULSE FORWARD ,kW
Fig.1 Peak Pulse Power Rating Curve
100
Non-Repetive Pulse.Wavefom
Shown in Figure.3
T A=25°C
10
1.0
0.1
0.1
1
10
100
1000
10000
100
80
60
40
I ppm ,Peak Pulse Current (%)
I FSM ,PEAK FORWARD SURGE CURRENT,
AMPERES
T A =25°C
100
Peak Value
Pulse Width (td) is Defined
as the Point where the Peak.
Current Decayst to 50% of Ipp
I ppm
80
Half Value-I pp /2
60
10/1000usec Waveform as Defined bye R.E.A.
40
2.0
3.0
100
125
150
175
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Pulse Waveform
t f =10usec
75
T A ,AMBIENT TEMPERATURE,°C
td,PULSE WIDTH ,us
120
50
4.0
T,TIME,ms
30
25
10
05
T J =T J max
8.3ms Single Half Sinepwave
JEDEC Method
10
Number of Cycles at 60Hz
www.cj-elec.com
3/4
100
KPTVSxxxS1UR
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-123FL
∠ALL ROUND
C
A
∠ALL ROUND
VM
D
E
A
g
g
pad
e
E
A
pad
HE
Top View
A
C
D
E
e
g
HE
max
1.1
0.20
2.9
1.9
1.1
0.9
3.8
min
0.9
0.12
2.6
1.7
0.8
0.7
3.5
max
43
7.9
114
75
43
35
150
min
35
4.7
102
67
31
28
138
UNIT
mm
mil
Bottom View
7°
The recommended mounting pad size
1.2
(47)
2.0
(79)
1.2
(47)
1.2
(47)
Unit: mm
(mil)
www.cj-elec.com
4/4
很抱歉,暂时无法提供与“KPTVS12VS1UR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.28730
- 100+0.23027
- 600+0.20176
- 1200+0.19873
- 3000+0.16147
- 国内价格
- 1+0.15070
- 3000+0.13310
- 国内价格
- 10+0.31342
- 100+0.25121
- 300+0.22011
- 3000+0.17615
- 6000+0.15747
- 9000+0.14818
