Metal thin film chip resistors
(high voltage operation)
■RGV series
AEC-Q200 Compliant
Features
・High voltage operation is possible because the limiting element voltage is hjgh.
(RGV3225 1000V)
・Long term stability with inorganic Passivation.
Thin film surface mount resistors
・Resistance tolerance : ±0.1% , TCR : ±25 ppm/℃
・Thin film structure enabling low noise and anti-sulfur
Applications
・Automotive electronics
RGT series
・Industrial measurement instrumentation, Industrial machies.
・High voltage circuit and equipment.
◆Part numbering system
RGV 3216
P - 2004 - B - T5
T1(1,000pcs) T5(5,000pcs)
Series code
Nominal resistance value(all 4 digit)
Temperature coefficient of resistance
◆Electrical Specification
Type
RGV3216
Power
ratings
Temperature
coefficient
of resistance
(ppm/℃)
Resistance range(Ω)
±0.1%(B)
±25(P)
1/4W
±0.5%(D)
Maximum
voltage
Resistance
value series
Operating
temperature
E-24, E-96
-55℃∼ 155℃
Packaging
quantity
700V
120KΩ≦R≦3MΩ
±50(Q)
RGV3225
±25(P)
1/3W
120KΩ≦R≦4.3MΩ
T1
T5
1000V
±50(Q)
◆Dimensions
L
Type
Size
(inch)
L
W
a
b
t
RGV3216
1206
3.20±0.20
1.60±0.25
0.50±0.25
0.50±0.20
0.40+0.15/-0.1
RGV3225
1210
3.20±0.20
2.50±0.25
0.50±0.25
0.50±0.20
0.40+0.15/-0.1
W
a
t
b
19
(unit:mm)
◆Reliability specification
規 格
Test items
Condition( IEC60115-1/JIS C5201-1)
※1
Standard
85℃, rated voltage , 90min. ON/ 30min. OFF, 1000hours
±0.05%+0.05Ω
High temperature high humidity
85℃、85%RH, 1/10 of rated power, 90min. ON/ 30min. OFF, 1000hours
±0.1%+0.05Ω
Temperature shock
-55℃ (30min) ∼ 125℃(30min) 1000 cycles
±0.1%+0.01Ω
High temperature exposure
155℃, no baias, not mounted, 1000h
±0.1%+0.01Ω
Resistance to soldering heat
260±5℃, 10seconds (reflow)
Life (baised)
±0.05%+0.01Ω
*1 Rated voltage is given by E=
RxP
E= rated voltage (V), R=nominal resistance value(Ω), P=rated power(W)
If rated voltage exceeds maximum voltage /element, maximum voltage/element is the rated voltage.
RGV series
Ratio to rated power (%)
◆Derating Curve
100
50
85 100
155
Ambient temperature (℃)
很抱歉,暂时无法提供与“RGV3216P-1503-B-T1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+3.347711+0.43357
- 10+2.7591910+0.35735
- 25+2.5638825+0.33205
- 50+2.4210150+0.31355
- 100+2.28796100+0.29632
- 250+2.12906250+0.27574
- 500+2.02129500+0.26178
- 国内价格 香港价格
- 1+3.346481+0.43341
