Technical Data Sheet
LOCTITE MP 218
September-2016
PRODUCT DESCRIPTION
LOCTITE
MP
218
provides the
characteristics:
Technology
Application
following
product
Solder paste
Sn/Pb soldering
LOCTITE MP 218 solder paste is a halide-free, no clean, pin
testable solder paste, which has excellent humidity resistance
and a broad process window, both for reflow and printing.
LOCTITE MP 218 has high tack force to resist component
movement during high speed placement, long printer abandon
times and excellent solderability over a wide range of reflow
profiles in air and nitrogen and across a wide range of surface
finishes including HASL, Ni/Au, Immersion Sn, Immersion Ag
and OSP copper.
FEATURES AND BENEFITS
● Outstanding humidity resistance - gives excellent coalescence
even after 24 hours exposure to 75% RH, thus reducing process
variation due to environmental conditions
● Colorless residues for easy post-reflow inspection
● Soft, non-stick, pin testable residues allow easy in-circuit testing
● Suitable for fine pitch, high speed printing up to 150mm/s (6"/s)
● Extended open time and tack life leading to low wastage.
● Halide free flux classification: ROL0 to ANSI/J-STD-004 (Jan.
1995)
TYPICAL PROPERTIES
Based on Type 3 powder
Solder Paste Typical Properties
Alloys
Powder Particle Size, µm
Powder Size Coding
IPC Equivalent
Metal Loading (Weight %)
Slump J-STD-005, mm
RT, 15 minutes
0.33 x 2.03 mm pads
0.63 x 2.03 mm pads
150°C, 15 minutes
0.33 x 2.03 mm pads
0.63 x 2.03 mm pads
Sn62, SN63
25-45
AGS
Type 3
89.5% and 90%
IPC A21 Pattern
0.08
0.33
0.1
0.33
Brookfield Viscosity TF spindle, 25°C, 89.5% metal
5rpm after 2 minutes, mPa∙s
90% metal
Thixotropic Index (TI), 25°C
89.5% metal
(1.8/18 s-1 )
90% metal
Malcom Rheology, 25°C
89.5% metal
Shear rate 6 s-1
90% metal
Initial tack force, gF
126
Useful open time, hours
>24
850,000
950,000
0.43
0.52
2,140
2,170
Based on Type 4 powder
Alloys
Powder Size Coding
IPC Equivalent
Brookfield Viscosity @ 25ºC, mPa.s
Spindle TF, Speed 5 rpm, 2 minutes
Thixotropic Index (Ti)
Ti = log (1.8/18 s-1)
Malcom Viscosity @ 25ºC, Pa.s
@ Shear Rate of 6 s-1
Sn62, Sn63
38-20
DAP
Type 4
89.5
840,000
0.54
1,900
63S4 ANTI-TOMBSTONING ALLOY
63S4 alloy offers an instant solution where tombstoning is a particular
process problem. 63S4 alloy is a blend of different melting point alloys
with a special mix of solder particle sizes. This modification extends
the melting range of the alloy reducing the possibility that one solder
deposit at a component termination can fully reflow before the other.
Alloys
63S4
Powder Size Coding
ACP
89.5% metal
IPC A21 Pattern
Slump, J-STD-005, mm
RT, 15 minutes
0.08
0.33 x 2.03 mm pads
0.33
0.63 x 2.03 mm pads
150°C, 15 minutes
0.1
0.33 x 2.03 mm pads
0.33
0.63 x 2.03 mm pads
Brookfield Viscosity TF spindle, 25°C, 850,000
Thixotropic Index (Ti) @ 25 °C
0.43
Malcom Rheology @ 25ºC, Pa.s
2,140
@ Shear Rate of 6 s-1 , Speed 10 rpm
126
>24
Solder Powder:
Careful control of the atomisation process for production of
solder powders for LOCTITE MP 218 solder pastes ensures
that the solder powder is produced to a quality level that
exceeds IPC/J-STD-006 & EN29453 requirements for
sphericity, size distribution, impurities and oxide levels.
Minimum order requirements may apply to certain alloys and
powder sizes.
TDS LOCTITE MP 218, September-2016
DIRECTIONS FOR USE
Printing:
1. LOCTITE MP 218 is available for stencil printing down to 0.4mm
(0.016") pitch QFP devices, with type 3 (AGS) powder.
2. Printing at speeds between 25 mm/s (1 "/s) and 150 mm/s (6 "/s)
can be achieved by using laser cut, electropolished or
electroformed stencils and metal squeegees (preferably 60°).
3. Acceptable first prints have been achieved at 0.4 mm (16 mils)
pitch after printer down times of 60 minutes without requiring a
knead cycle.
Reflow:
● Any of the available methods of heating to cause reflow may be
used including IR, convection, hot belt, vapor phase and laser
soldering.
● LOCTITE MP 218 is not particularly sensitive to reflow profile
type.
● There is no single reflow profile which is suitable for all processes
and applications, but the following graphs show profile examples
that have given good results in practice.
● 63S4 anti-tombstoning is selected when tombstone defects are
experienced with standard alloys and when it is not possible to
eliminate by design changes.
● Typical reflow profile as follows:
1. Ramp to 130 to 165ºC at no more than 2ºC s-1 .
2. Hold at 130 to 165ºC for 60 to 120 seconds.
3. Ramp to peak reflow temperature at no more than 2ºC s-1 .
4. Recommended peak reflow temperature is 205 to 225ºC.
5. Dwell time above liquidus of 30 to 75 seconds.
Test
Copper Plate Corrosion
Copper Mirror Corrosion
Chlorides & Bromides
Surface Insulation
Resistance (without
cleaning)
Electromigration (ECM)
Flux Activity Classification
(without cleaning)
Specification
ANSI/J-STD-004
ANSI/J-STD-004
ANSI/J-STD-004
ANSI/J-STD-004
Results
Pass
Pass
Pass
Pass
Pass
Telecordia GR-78-Core Pass
ANSI/J-STD-004 (Jan. ROL0
1995)
STORAGE AND SHELF LIFE
Storage:
It is recommended to store LOCTITE MP 218 at 0 to 10°C. (NB
cartridges should be stored tip down to prevent the formation of air
pockets). The paste should be removed from cold storage a minimum
of 8 hours before use. Do not use forced heating methods to bring
solder paste up to temperature. LOCTITE MP 218 solder paste has
been formulated to minimize flux separation on storage but should this
occur, gentle stirring for 15 seconds will return the product to the
correct rheological performance. To prevent contamination of unused
product, do not return any material to its original container. For further
specific shelf life information, contact your local Technical Service
Center.
Shelf Life:
Provided Multicore LOCTITE MP 218 is stored tighly sealed in the
original container at 0 to 10°C, a minimum shelf life of 183 days can be
expected. Air shipment is recommended to minimize the time the
containers are exposed to higher temperatures. Short term storage at
room temperature during use is acceptable provided the paste is
sealed in original containers. Laboratory testing has shown that the
paste remains in a useable condition after 2 months of storage at room
temperature.
DATA RANGES
The data contained herein may be reported as a typical value
and/or a range. Values are based on actual test data and are
verified on a periodic basis.
GENERAL INFORMATION
For safe handling information on this product, consult the
Material Safety Data Sheet (MSDS).
Cleaning:
1. LOCTITE MP 218 solder pastes are no-clean and are designed
to be left on the PCB in many applications post-assembly since
they do not pose a hazard to long-term reliability.
2. Residue removal can be achieved using conventional cleaning
processes based on solvents such as LOCTITE MCF 800 or
suitable saponifying agents.
3. For stencil cleaning and cleaning board misprints, LOCTITE MSC
01 solvent cleaner is recommended.
RELIABILITY PROPERTIES
Solder Paste Medium:
LOCTITE MP 218 medium contains a stable resin system and slow
evaporating solvents. The formulation has been tested to the
requirements of ANSI/J-STD-004 for a type ROL0 classification.
Not for Product Specifications
The technical information contained herein is intended for reference
only. Please contact Henkel Technologies Technical Service for
assistance and recommendations on specifications for this product.
Conversions
(°C x 1.8) + 32 = °F
kV/mm x 25.4 = V/mil
mm / 25.4 = inches
µm / 25.4 = mil
N x 0.225 = lb
N/mm x 5.71 = lb/in
N/mm² x 145 = psi
MPa x 145 = psi
N·m x 8.851 = lb·in
N·m x 0.738 = lb·ft
N·mm x 0.142 = oz·in
mPa·s = cP
Disclaimer
Note:
The information provided in this Technical Data Sheet (TDS) including
the recommendations for use and application of the product are based
on our knowledge and experience of the product as at the date of this
---------------------------------------------------------------------------------------------------------------------------------------------------Americas
Europe
Asia
+1.888.943.6535
+32.1457.5611
+86.21.3898.4800
For the most direct access to local sales and technical support visit: www.henkel.com/electronics
TDS. The product can have a variety of different applications as well as
differing application and working conditions in your environment that
are beyond our control. Henkel is, therefore, not liable for the suitability
of our product for the production processes and conditions in respect
of which you use them, as well as the intended applications and
results. We strongly recommend that you carry out your own prior trials
to confirm such suitability of our product.
Any liability in respect of the information in the Technical Data Sheet or
any other written or oral recommendation(s) regarding the concerned
product is excluded, except if otherwise explicitly agreed and except in
relation to death or personal injury caused by our negligence and any
liability under any applicable mandatory product liability law.
In case products are delivered by Henkel Belgium NV, Henkel
Electronic Materials NV, Henkel Nederland BV, Henkel
Technologies France SAS and Henkel France SA please
additionally note the following:
In case Henkel would be nevertheless held liable, on whatever legal
ground, Henkel’s liability will in no event exceed the amount of the
concerned delivery.
In case products are delivered by Henkel Colombiana, S.A.S. the
following disclaimer is applicable:
TDS. Henkel is, therefore, not liable for the suitability of our product for
the production processes and conditions in respect of which you use
them, as well as the intended applications and results. We strongly
recommend that you carry out your own prior trials to confirm such
In case products are delivered by Henkel Corporation, Resin
Technology Group, Inc., or Henkel Canada Corporation, the
The data contained herein are furnished for information only and are
believed to be reliable. We cannot assume responsibility for the results
obtained by others over whose methods we have no control. It is the
user's responsibility to determine suitability for the user's purpose of
any production methods mentioned herein and to adopt such
precautions as may be advisable for the protection of property and of
persons against any hazards that may be involved in the handling and
use thereof. In light of the foregoing, Henkel Corporation specifically
disclaims all warranties expressed or implied, including
warranties of merchantability or fitness for a particular purpose,
arising from sale or use of Henkel Corporation’s products. Henkel
Corporation specifically disclaims any liability for consequential
or incidental damages of any kind, including lost profits. The
discussion herein of various processes or compositions is not to be
interpreted as representation that they are free from domination of
patents owned by others or as a license under any Henkel Corporation
patents that may cover such processes or compositions. We
recommend that each prospective user test his proposed application
before repetitive use, using this data as a guide. This product may be
covered by one or more United States or foreign patents or patent
applications.
Trademark usage
Except as otherwise noted, all trademarks in this document are
trademarks of Henkel Corporation in the U.S. and elsewhere. ®
denotes a trademark registered in the U.S. Patent and Trademark
Office.
Reference N/A
Americas
Europe
Asia
+1.888.943.6535
+32.1457.5611
+86.21.3898.4800
