MMBT4401
MMBT3904
AO3400
SI2305
MMBT4401
TRANSISTOR ( NPN)
FEATURES
Epitaxial Planar Die Construction
Complementary PNP Type Available (MMBT4403)
Ideal for Medium Power Amplification and Switching
SOT-23
1.BASE
2.EMITTER
3.COLLECTOR
MARKING: 2X
MAXIMUM RATINGS (TA=25℃ unless otherwise noted)
Symbol
Parameter
Value
Units
VCBO
Collector-Base Voltage
60
V
VCEO
Collector-Emitter Voltage
40
V
VEBO
Emitter-Base Voltage
6
V
IC
Collector Current -Continuous
600
mA
PC
Collector Power dissipation
0.3
W
Tj
Junction Temperature
150
Tstg
Storage Temperature
-55 to +150
RӨJA
Thermal Resistance, junction to Ambient
417
℃/mW
ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified)
Parameter
Symbol
Test
conditions
MIN
MAX
UNIT
Collector-base breakdown voltage
V(BR)CBO
IC= 100μA, IE=0
60
V
Collector-emitter breakdown voltage
V(BR)CEO
IC= 1mA, IB=0
40
V
Emitter-base breakdown voltage
V(BR)EBO
IE= 100μA, IC=0
6
V
Collector cut-off current
ICBO
VCB=50 V, IE=0
0.1
μA
ICEO
VCE=30 V, IB=0
0.1
μA
Emitter cut-off current
IEBO
VEB=5V, IC=0
0.1
μA
DC current gain
hFE
VCE=1V, IC=150mA
Collector-emitter saturation voltage
VCE(sat)
IC=150mA,
Base-emitter saturation voltage
VBE(sat)
IC= 150mA, IB=15mA
fT
Transition frequency
www.tw-gmc.com
1
B=15mA
VCE= 10V, IC= 20mA
f = 100MHz
100
250
300
0.4
V
0.95
V
MHz
MMBT4401
MMBT3904
AO3400
SI2305
Typical Characteristics
Static Characteristic
250
200
DC CURRENT GAIN
0.7mA
0.6mA
0.5mA
100
0.4mA
0.3mA
50
IC
Ta=100℃
hFE
IC
0.9mA
150
COMMON EMITTER
VCE= 1V
1mA
0.8mA
COLLECTOR CURRENT
(mA)
hFE
1000
COMMON
EMITTER
Ta=25℃
Ta=25℃
100
0.2mA
IB=0.1mA
1
3
COLLECTOR-EMITTER VOLTAGE
VBEsat ——
1000
10
4
1
VCEsat
1000
600
(mA)
IC
Ta=100 ℃
200
1
10
100
COLLECTOR CURRENT
IC
600
IC
Ta=100 ℃
100
400
Ta=25℃
10
0.5
0.1
600
VBE
fT
800
1000
10
1200
10
BASE-EMMITER VOLTAGE VBE (mV)
Cob/Cib
IC
COMMON EMITTER
VCE=10V
Ta=25℃
fT
600
400
(mA)
100
Ta=25℃
1
200
600
100
IC
TRANSITION FREQUENCY
(MHz)
IC
Ta=100 ℃
10
500
100
10
1
COLLECTOR CURRENT
(mA)
COMMON EMITTER
VCE=1V
COLLECTOR CURRENT
(mA)
COLLECTOR-EMITTER
SATURATION VOLTAGE VCEsat
(mV)
BASE-EMITTER
SATURATION VOLTAGE
VBEsat (mV)
Ta=25℃
100
600
100
β=10
800
IC
VCE (V)
IC
β=10
0.1
10
COLLECTOR CURRENT
VCB/VEB
COLLECTOR CURRENT
PC
400
IC
30
40
(mA)
Ta
f=1MHz
IE=0/IC=0
Ta=25 ℃
CAPACITANCE
(pF)
C
COLLECTOR POWER
DISSIPATION PC (mW)
Cib
10
Cob
1
0.1
200
100
REVERSE VOLTAGE
www.tw-gmc.com
300
10
V
30
50
75
AMBIENT TEMPERATURE
(V)
1
2
100
Ta
125
150
MMBT4401
MMBT3904
AO3400
SI2305
PACKAGE OUTLINE
Plastic surface mounted package; 3 leads
www.tw-gmc.com
SOT-23
1
3
2
很抱歉,暂时无法提供与“MMBT4401”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.28600
- 200+0.09548
- 1500+0.05962
- 3000+0.04741
