SB2200
SB2200
    YFW(佑风微)
    DO-15
SB2200 数据手册
SB220 THRU SB2200 DO-15 Schottky Barrier Rectifiers Reverse Voltage - 20 to 200 V Forward Current - 2 A FEATURES  Guardring for overvoltage protection  Low reverse leakage  High forward surge current capability  High temperature soldering guaranteed 250℃ /10 seconds at terminals  Lead free in comply with EU RoHS 2011/65/EU directives MECHANICAL DATA  Case: DO-15  Terminals: Solderable per MIL-STD-750, Method 2026 DO-15  Approx. Weight: 0.33g / 0.0116oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols SB220 SB240 SB260 SB280 SB2100 SB2150 SB2200 Units Maximum Repetitive Peak Reverse Voltage VRRM 20 40 60 80 100 150 200 V Maximum RMS voltage VRMS 14 28 42 56 70 105 140 V Maximum DC Blocking Voltage VDC 20 40 60 80 100 150 200 V Maximum Average Forward Rectified Current at Tc = 100 °C IF(AV) 2.0 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load IFSM 50.0 A Maximum Instantaneous Forward Voltage at 2.0A VF Parameter 0.55 Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a=125 °C Typical Thermal Resistance Operating junction temperature range Storage Temperature Range 0.70 0.5 50 IR RθJA Tj 0.85 0.95 0.05 10 Tstg -55 ~ +150 -55 ~ +150 mA °C/W 75 -55 ~ +125 V °C °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C www.yfwdiode.com 1/3 Dongguan YFW Electronics Co, Ltd. SB220 THRU SB2200 DO-15 Ratings And Characteristic Curves FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD SURGE CURRENT PERLEG 70 Peak Forward Surage Current Amperes 3.2 2.8 2.4 Amperes Average Forward Rectified Current FIG. 1- DERATING CURVE OUTPUT RECTIFIED CURRENT 2.0 1.6 1.2 0.8 SB220-SB260 SB280-SB2200 0.4 0.0 0 20 40 60 80 100 120 140 60 50 40 30 f=60Hz 20 10 1Cycle 0 160 1 10 100 Lead Temperature Number of cycles FIG. 3-TYPICAL FORWARD VOLTAGE CHARACTERISTICS FIG. 4-TYPICAL REVERSE LEAKAGE CHARACTERISTICS 50 100 TJ=25 C INSTANTANEOUS REVERSE CURRENT, MICROAMPERES INSTANTANEOUS FORWARD CURRENT,AMPERES SB220-SB260 SB280-SB2200 10.0 1 0.1 SB220-SB240 SB260 SB280-SB2100 SB2150-SB2200 0.01 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 INSTANTANEOUS FORWARD VOLTAGE, VOLTS 10 TJ=100 C 1 0.1 0.01 0.001 0 TJ=25 C 20 40 60 80 100 PERCENT OF PEAK REVERSE VOLTAGE,% www.yfwdiode.com 2/3 Dongguan YFW Electronics Co, Ltd. SB220 THRU SB2200 DO-15 Package Outline DO-15 D DIMENSIONS A DIM A B C D Cathode Mark B INCHES MIN .230 .104 .028 1.000 MAX .300 .140 .034 --- MM MIN 5.8 2.6 0.71 25.40 MAX 7.6 3.6 0.86 --- NOTE D C Summary of Packing Options Package DO-15 www.yfwdiode.com Packing Description Packing Quantity 500/3000 BOX 3/3 Industry Standard EIA-481-1 Dongguan YFW Electronics Co, Ltd.
SB2200 价格&库存
很抱歉,暂时无法提供与“SB2200”相匹配的价格&库存,您可以联系我们找货
SB2200
库存:2005
