The product information in this catalog is for reference only. Please request the Engineering Drawing for the most current and accurate design information.
All non-RoHS products have been discontinued, or will be discontinued soon. Please check the products status on the Hirose website RoHS search at www.hirose-connectors.com, or contact your Hirose sales representative.
SMT Stripline Mounting Fixed Attenuators
AT-2200 Series
■Features
1. Small Size and Lightweight
4mm x 3.6 mm x 1.4 mm max height and weighting
only 0.1g.
2. Wide Range of Variations for Each Type
of Attenuator
Attenuation levels available in 1 dB steps from 0 to
10 dB, and 20 dB for a total of 12 types of
variations.
3. Automatic placement
Supplied in embossed packaging to allow
placement with automatic equipment.
Individual piece packaging is also available.
■Product Specifications
Frequency range
Characteristic impedance
Maximum input power
Ratings
DC to 2.5GHz (Note)
50ø
1W
Operating temperature
Operating humidity
-10ç to +65ç
95% max.
Note: DC to 600MHz for AT-2220.
Item
Characteristic requirement
Conditions
Frequency of 10 to 2000 Hz, overall amplitude of 1.5mm,
acceleration of 98m/s2, 2 hours in each of the 3 directions.
1.Vibration
No electrical discontinuity of 1µs or more.
No damage, cracks, or parts dislocation.
2.Shock
Acceleration of 490m/s2, sine half-wave waveform, 3 cycles in
each of the 3 axis.
Temperature : -55ç / +15ç to +35ç / +85ç / +15ç to +35ç
Time
3.Temperature cycle
: 30
/ 2 to 3
/ 30
/ 2 to 3 (Minutes)
5 cycles
The test method conforms to MIL-STD-202.
■Materials
■Dimensions
Material
Finish
Attenuation element
Metal film
Tin-lead plated
■Ordering information
AT-2203 shown
4
3dB E
3.6
Component
1 AX:Fixed attenuator
2 Series name :2200 Series
3 Attenuation
00-(0) : 0 dB (Through)
01
: 1dB
06
: 6dB
4 (40): RoHS Compliant
(0.65)
4
(0.2)
3
1.2 0.8 1.2
2
(1.2)
1.6
(1.2)
Soldering areas
(0.2)
1
1.4MAX
AT - 22 01 (40)
04/2009
83
All non-RoHS
products have
been discontinued,
or will be Mounting
discontinued soon.
Please
AT-2200
Series●SMT
Stripline
Fixed
Attenuators
■Specifications
Attenuation (dB)
V.S.W.R (Max)
Part number DC~
1,000~
2,000~
1,000MHz 2,000MHz 2,500MHz
Characteristic Power
Mounting surface
DC~2,500MHz
Impedance (ø)
(W)
temperature (ç Max.) at time
of maximum input power
Weight
(g)
AT-2200-(0)(40)
0+0.3
50
1
+85
0.1
AT-2201(40)
1±0.3
1±0.5
1.2
50
1
+85
0.1
AT-2202(40)
2±0.3
2±0.5
1.2
50
1
+85
0.1
AT-2203(40)
3±0.3
3±0.5
1.2
50
1
+85
0.1
AT-2204(40)
4±0.3
4±0.5
1.2
50
1
+85
0.1
AT-2205(40)
5±0.3
5±0.5
1.2
50
1
+85
0.1
AT-2206(40)
6±0.3
6±0.5
1.2
50
1
+85
0.1
AT-2207(40)
7±0.3
7±0.5
1.2
50
1
+85
0.1
AT-2208(40)
8±0.3
8±0.5
1.2
1.25
50
1
+85
0.1
AT-2209(40)
9±0.3
9±0.5
1.2
1.25
50
1
+85
0.1
AT-2210(40)
10±0.3
1.2
1.25
50
1
+85
0.1
50
1
+85
0.1
10±0.5
10±0.7
20±1.5(DC to 600MHz)
AT-2220(40)
1.2(DC to 600MHz)
Note: When ordering packaged on tape and reel, add (06) after the end of the part number. One reel = 1,000 pieces
■Typical data
AT-2203(40)
AT-2210(40)
(dB)
1.75
(dB)
8.75
2.00
9.00
2.25
9.25
2.50
2.75
9.75
3.00
10.00
3.25
10.25
3.50
10.50
3.75
10.75
4.00
11.00
4.25
0.0
0.5
1.0
1.5
2.0
Frequency(GHz)
2.5
3.0
1.50
0.5
1.0
1.5
2.0
Frequency(GHz)
2.5
3.0
0.5
1.0
1.5
2.0
Frequency(GHz)
2.5
3.0
1.45
1.40
1.40
1.35
1.35
1.30
1.30
1.25
1.25
VSWR
VSWR
1.20
1.15
1.15
1.10
1.10
1.05
1.05
1.00
0.0
84
11.25
0.0
1.50
1.45
1.20
ATTENUATION
9.50
ATTENUATION
0.5
1.0
1.5
2.0
Frequency(GHz)
2.5
3.0
1.00
0.0
04/2009
RoHS search
or contact your
Hirose
AT-2200
Series●SMT
Stripline Mounting
Fixed
Attenuators
■Mounting and Soldering Recommendations
The attenuators can be placed using reflow or manual soldering
BRecommended Solder temperature profile
●Reflow Soldering (Temperature Profile Recommendations)
10 sec. max.
ç
250
230
200
180
150
100
90±30 sec.
30 sec. max.
50
Time(s)
Manual Soldering
Tip temperature: 350ç max. for 3 sec. max.
Note 1: Do not touch the ceramic portion with the soldering iron tip.
BRecommended Mounting Example
Ceramic Portion
Grounding Pattern
AT-2200(40)
Board
50øLine
πThe dotted line portion indicates the position of the pattern.
Note: This attenuator is intended for a one-time use. Do not re-solder or re-use.
04/2009
85
很抱歉,暂时无法提供与“AT-2200-(0)(40)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+83.68920
- 200+32.38920
- 500+31.25520
- 1000+30.69360
