KSMBJ6.5CA-E3/52
KSMBJ6.5CA-E3/52
    KUU(永裕泰)
    SMB(DO-214AA)
    瞬态电压抑制器
KSMBJ6.5CA-E3/52 数据手册
KSMBJ Series -E3/52 TRANSIENT VOLTAGE SUPPRESSOR FEATURE  Plastic package.  Glass passivated chip junction in SMB Package  Excellent clamping capability.  Low zener impedance.  600W peak pulse power capability on 10/1000μs waveform.  Typical IR less than 1μA above 13V.  Fast response time: typically less than 1.0ps from 0 Volts to BV min. High temperature soldering guaranteed: 265℃/10 seconds MECHANICAL DATE  Case: JEDEC SMB Molded Plastic.  Terminals: Axial leads, solderable per MIL-STD-750, Method 2026.  Polarity: Color band denoted cathode except bidirectional.  Mounting Position: Any. MAXIMUM RATINGS AND CHRACTERISTICS Ratings at 25ć ambient temperature unless otherwise specified. RATING SYMBOL VALUE UNITS Peak Pulse Power Dissipation on 10/1000us waveform (Note1, Fig.1). PPPM Minimum 600 Watts Peak Pulse Current of on 10/1000us waveform.(Note1,Fig.3) IPPM See Table Amps Steady State Power Dissipation at TL =75℃,Lead lengths.375", (9.5mm) (Fig.5). PM(AV) 5.0 Watts Peak Forward Surge Current,8.3ms Single Half Sine-Wave Superimposed on Rated Load, (JEDEC Method) (Note 2,Fig.6). IFSM 100 Amps TJ , TSTG -55 to +150 ℃ Operating junction and Storage Temperature Range. Notes: 1. Non-repetitive current pulse, per Fig. 3 and derated above TA = 25℃ per Fig. 2. 2. 8.3ms single half sine-wave, or equivalent square wave, Duty cycle = 4 pulses per minutes maximum. 1/4 KSMBJ Series -E3/52 Item A B C D E F G H I J K L Millimeters Min. Max. 1.95 2.2 4.06 4.57 3.3 3.94 2.13 2.44 0.76 1.52 0.203 5.21 5.59 0.152 0.305 2.26 2.16 2.74 2.16 - Inches Min. Max. 0.077 0.086 0.16 0.18 0.13 0.155 0.084 0.096 0.03 0.06 0.008 0.205 0.22 0.006 0.012 0.089 0.085 0.107 0.085 - ELECTRICAL CHARACTERISTICS Part Number Marking Reverse Breakdown Breakdown Reverse Test Peak Maximum Stand-Off Voltage Voltage Leakage Current Pulse Voltage NIN.@IT MAX.@IT @VRWM Current Clamping Voltage @IPP VR(V) UNT BI UNT BI VBL(V) VBH(V) IR(uA) IT(mA) IPP(A) VCH(V) KSMBJ5.0A KSMBJ5.0CA KE AE 5.0 6.40 7.00 800 10 65.3 9.2 KSMBJ6.0A KSMBJ6.0CA KG AG 6.0 6.67 7.37 800 10 58.3 10.3 KSMBJ6.5A KSMBJ6.5CA KK AK 6.5 7.22 7.98 500 10 53.6 11.2 KSMBJ7.0A KSMBJ7.0CA KM AM 7.0 7.78 8.60 200 10 50.0 12.0 KSMBJ7.5A KSMBJ7.5CA KP AP 7.5 8.33 9.21 100 1 46.6 12.9 KSMBJ8.0A KSMBJ8.0CA KR AR 8.0 8.89 9.83 50 1 44.2 13.6 KSMBJ8.5A KSMBJ8.5CA KT AT 8.5 9.44 10.40 20 1 41.7 14.4 KSMBJ9.0A KSMBJ9.0CA KV AV 9.0 10.00 11.10 10 1 39.0 15.4 KSMBJ10A KSMBJ10CA KX AX 10 11.10 12.30 5 1 35.3 17.0 KSMBJ11A KSMBJ11CA KZ AZ 11 12.20 13.50 1 1 33.0 18.2 KSMBJ12A KSMBJ12CA LE BE 12 13.30 14.70 1 1 30.2 19.9 KSMBJ13A KSMBJ13CA LG BG 13 14.40 15.90 1 1 28.0 21.5 2/4 KSMBJ Series -E3/52 Part Number Reverse Breakdown Breakdown Reverse Test Peak Maximum Stand-Off Voltage Voltage Leakage Current Pulse Voltage NIN.@IT MAX.@IT @VRWM Current Clamping Voltage @IPP BI VR(V) VBL(V) VBH(V) IR(uA) IT(mA) IPP(A) VCH(V) Marking UNT BI KSMBJ14A KSMBJ14CA LK BK 14 15.60 17.20 1 25.9 23.2 KSMBJ15A KSMBJ15CA LM BM 15 16.70 18.50 1 1 24.6 24.4 KSMBJ16A KSMBJ16CA LP BP 16 17.80 19.70 1 1 23.1 26.0 KSMBJ17A KSMBJ17CA LR BR 17 18.90 20.90 1 1 21.8 27.6 KSMBJ18A KSMBJ18CA LT BT 18 20.00 22.10 1 1 20.6 29.2 KSMBJ20A KSMBJ20CA LV BV 20 22.20 24.50 1 1 18.6 32.4 KSMBJ22A KSMBJ22CA LX BX 22 24.40 26.90 1 1 16.9 35.5 KSMBJ24A KSMBJ24CA LZ BZ 24 26.70 29.50 1 1 15.5 38.9 KSMBJ26A KSMBJ26CA ME CE 26 28.90 31.90 1 1 14.3 42.1 KSMBJ28A KSMBJ28CA MG CG 28 31.10 34.40 1 1 13.3 45.4 KSMBJ30A KSMBJ30CA MK CK 30 33.30 36.80 1 1 12.4 48.4 KSMBJ33A KSMBJ33CA MM CM 33 36.70 40.60 1 1 11.3 53.3 KSMBJ36A KSMBJ36CA MP CP 36 40.00 44.20 1 1 10.4 58.1 KSMBJ40A KSMBJ40CA MR CR 40 44.40 49.10 1 1 9.3 64.5 KSMBJ43A KSMBJ43CA MT CT 43 47.80 52.80 1 1 8.7 69.4 KSMBJ45A KSMBJ45CA MV CV 45 50.00 55.30 1 1 8.3 72.7 KSMBJ48A KSMBJ48CA MX CX 48 53.30 58.90 1 1 7.8 77.4 KSMBJ51A KSMBJ51CA MZ CZ 51 56.70 62.70 1 1 7.3 82.4 KSMBJ54A KSMBJ54CA NE DE 54 60.00 66.30 1 1 6.9 87.1 KSMBJ58A KSMBJ58CA NG DG 58 64.40 71.20 1 1 6.5 93.6 KSMBJ60A KSMBJ60CA NK DK 60 66.70 73.70 1 1 6.2 96.8 KSMBJ64A KSMBJ64CA NM DM 64 71.10 78.60 1 1 5.9 103 KSMBJ70A KSMBJ70CA NP DP 70 77.80 86.00 1 1 5.3 113 KSMBJ75A KSMBJ75CA NR DR 75 83.30 92.10 1 1 5.0 121 KSMBJ78A KSMBJ78CA NT DT 78 86.70 95.80 1 1 4.8 126 KSMBJ85A KSMBJ85CA NV DV 85 94.4 104.0 1 1 4.4 137 KSMBJ90A KSMBJ90CA NX DX 90 100.0 111.0 1 1 4.1 146 KSMBJ100A KSMBJ100CA NZ DZ 100 111.0 123.0 1 1 3.7 162 KSMBJ110A KSMBJ110CA PE EE 110 122.0 135.0 1 1 3.4 177 KSMBJ120A KSMBJ120CA PG EG 120 133.0 147.0 1 1 3.1 193 KSMBJ130A KSMBJ130CA PK EK 130 144.0 159.0 1 1 2.9 209 KSMBJ150A KSMBJ150CA PM EM 150 167.0 185.0 1 1 2.5 243 KSMBJ160A KSMBJ160CA PP EP 160 178.0 197.0 1 1 2.3 259 KSMBJ170A KSMBJ170CA PR ER 170 189.0 209.0 1 1 2.2 275 KSMBJ180A KSMBJ180CA PT ET 180 201.0 222.0 1 1 2.1 292 KSMBJ190A KSMBJ190CA PA EC 190 209.0 243.0 1 1 2.0 308 KSMBJ200A KSMBJ200CA PV EV 200 224.0 247.0 1 1 1.9 324 KSMBJ220A KSMBJ220CA PX EX 220 246.0 272.0 1 1 1.7 356 KSMBJ250A KSMBJ250CA PZ EZ 250 279.0 309.0 1 1 1.5 405 KSMBJ300A KSMBJ300CA QE FE 300 335.0 371.0 1 1 1.3 486 KSMBJ350A KSMBJ350CA QG FG 350 391.0 432.0 1 1 1.1 567 KSMBJ400A KSMBJ400CA QK FK 400 447.0 494.0 1 1 0.9 648 KSMBJ440A KSMBJ440CA QM FM 440 492.0 543.0 1 1 0.9 713 UNT Notes: For bidirectional type having VRWM of 10 volts and less, the IR limit is double 3/4 KSMBJ Series -E3/52 RATINGS AND CHARACTERISTIC CURVES (TA=25℃ unless otherwise noted) Figure 1 - Peak Pulse Power Rating Curve Figure 2 - Pulse Derating Curve Figure 3 - Pulse Waveform Figure 4 - Typical Junction Capacitance Uni-Directional Figure 5 - Steady State Power Dissipation Derating Curve Figure 6 - Maximum Non-Repetitive Forward Surge Current Uni-Directional Only 4/4
KSMBJ6.5CA-E3/52 价格&库存
很抱歉,暂时无法提供与“KSMBJ6.5CA-E3/52”相匹配的价格&库存,您可以联系我们找货
KSMBJ6.5CA-E3/52
  • 20+0.34323
  • 200+0.28782
  • 600+0.25704
  • 3000+0.22140
  • 9000+0.20531
  • 21000+0.19667
库存:2753
