SMB 600W Series
Version: A2 2016-05-27
Transient Voltage Suppressor
Features
Exterior
IEC 61000-4-2(ESD)±15KV(air), ±8KV(contact)
600Watts peak pulse power (tp=10/1000μS)
Low clamping voltage
Moisture sensitivity level: level 1
SMB
Agency Approvals
Application Information
DC Port
Icon
RS485/232/422
Description
Compliance with 2011/65/EU
I/O Port
Compliance with IEC61249-2-21:2003
Schematic Symbol
cathode
anode
UNI-directional
BI-directional
Part Numbering and Electrical Parameter
Part Number
Reverse
Marking
Stand off
Voltage
Max
VBR
VBR
min.
max.
(V)
(V)
It
(mA)
Clamping
Voltage
Max Peak
Max Reverse
Pulse
Leakage
Current
IR@VR
IPP○1 (A)
(uA)
9.2
65.3
800
10
10.3
58.3
800
7.98
10
11.2
53.6
500
7.78
8.6
10
12
50
200
7.5
8.33
9.21
1
12.9
46.6
100
B8
8
8.89
9.83
1
13.6
44.2
50
B8.5C
B8.5
8.5
9.44
10.4
1
14.4
41.7
BV-SMBJ9A
B9C
B9
9
10
11.1
1
15.4
39
10
BV-SMBJ10CA
BV-SMBJ10A
B10C
B10
10
11.1
12.3
1
17
35.3
5
BV-SMBJ11CA
BV-SMBJ11A
B11C
B11
11
12.2
13.5
1
18.2
33
1
BV-SMBJ12CA
BV-SMBJ12A
B12C
B12
12
13.3
14.7
1
19.9
30.2
1
BV-SMBJ13CA
BV-SMBJ13A
B13C
B13
13
14.4
15.9
1
21.5
28
1
BV-SMBJ14CA
BV-SMBJ14A
B14C
B14
14
15.6
17.2
1
23.2
25.9
1
BI
UNI
BI
UNI
VR(V)
BV-SMBJ5CA
BV-SMBJ5A
B5C
B5
5
6.4
7
10
BV-SMBJ6CA
BV-SMBJ6A
B6C
B6
6
6.67
7.37
BV-SMBJ6.5CA
BV-SMBJ6.5A
B6.5C
B6.5
6.5
7.22
BV-SMBJ7CA
BV-SMBJ7A
B7C
B7
7
BV-SMBJ7.5CA
BV-SMBJ7.5A
B7.5C
B7.5
BV-SMBJ8CA
BV-SMBJ8A
B8C
BV-SMBJ8.5CA
BV-SMBJ8.5A
BV-SMBJ9CA
1/5
www.bencent.com.cn
Vc@IPP○1
(V)
Specifications are subject to change without notice.
Customers should verify actual device performance in their specific applications
SMB 600W Series
Max
Part Number
Marking
Reverse
Stand off
Voltage
BI
UNI
BI
UNI
VR(V)
VBR
VBR
min.
max.
(V)
(V)
Clampin
Max Peak
Max Reverse
It
g
Pulse
Leakage
(mA)
Voltage
Current
IR@VR
Vc@I
1
PP
I
1
PP
(A)
(uA)
(V)
BV-SMBJ15CA
BV-SMBJ15A
B15C
B15
15
16.7
18.5
1
24.4
24.6
1
BV-SMBJ16CA
BV-SMBJ16A
B16C
B16
16
17.8
19.7
1
26
23.1
1
BV-SMBJ17CA
BV-SMBJ17A
B17C
B17
17
18.9
20.9
1
27.6
21.8
1
BV-SMBJ18CA
BV-SMBJ18A
B18C
B18
18
1
29.2
20.6
1
BV-SMBJ20CA
BV-SMBJ20A
B20C
B20
24.5
1
32.4
18.6
1
BV-SMBJ22CA
BV-SMBJ22A
B22C
B22
22
24.4
26.9
1
35.5
16.9
1
BV-SMBJ24CA
BV-SMBJ24A
B24C
B24
24
26.7
29.5
1
38.9
15.5
1
BV-SMBJ26CA
BV-SMBJ26A
B26C
B26
26
28.9
31.9
1
42.1
14.3
1
BV-SMBJ28CA
BV-SMBJ28A
B28C
B28
28
31.1
34.4
1
45.4
13.3
1
BV-SMBJ30CA
BV-SMBJ30A
B30C
B30
30
33.3
36.8
1
48.4
12.4
1
BV-SMBJ33CA
BV-SMBJ33A
B33C
B33
33
36.7
40.6
1
53.3
11.3
1
BV-SMBJ36CA
BV-SMBJ36A
B36C
B36
36
40
44.2
1
58.1
10.4
1
BV-SMBJ40CA
BV-SMBJ40A
B40C
B40
40
44.4
49.1
1
64.5
9.3
1
BV-SMBJ43CA
BV-SMBJ43A
B43C
B43
43
47.8
52.8
1
69.4
8.7
1
BV-SMBJ45CA
BV-SMBJ45A
B45C
B45
45
50
55.3
1
72.7
8.3
1
BV-SMBJ48CA
BV-SMBJ48A
B48C
B48
48
53.3
58.9
1
77.4
7.8
1
BV-SMBJ51CA
BV-SMBJ51A
B51C
B51
51
56.7
62.7
1
82.4
7.3
1
BV-SMBJ54CA
BV-SMBJ54A
B54C
B54
54
60
66.3
1
87.1
6.9
1
BV-SMBJ58CA
BV-SMBJ58A
B58C
B58
58
64.4
71.2
1
93.6
6.5
1
BV-SMBJ60CA
BV-SMBJ60A
B60C
B60
60
66.7
73.7
1
96.8
6.2
1
BV-SMBJ64CA
BV-SMBJ64A
B64C
B64
64
71.1
78.6
1
103
5.9
1
BV-SMBJ70CA
BV-SMBJ70A
B70C
B70
70
77.8
86
1
113
5.3
1
BV-SMBJ75CA
BV-SMBJ75A
B75C
B75
75
83.3
92.1
1
121
5
1
BV-SMBJ78CA
BV-SMBJ78A
B78C
B78
78
86.7
95.8
1
126
4.8
1
BV-SMBJ85CA
BV-SMBJ85A
B85C
B85
85
94.4
104
1
137
4.4
1
BV-SMBJ90CA
BV-SMBJ90A
B90C
B90
90
100
111
1
146
4.1
1
BV-SMBJ100CA
BV-SMBJ100A
B100C
B100
100
111
123
1
162
3.7
1
BV-SMBJ110CA
BV-SMBJ110A
B110C
B110
110
122
135
1
177
3.4
1
Note: Absolute maximum ratings measured at T= 25ºC RH = 45%-75% (unless otherwise noted).
1 Surge Waveform: 10/1000μS
Mark
BXXC
2/5
www.bencent.com.cn
BI: BXXC
BXX
UNI: BXX
SMB 600W Series
V-I Curve
IPP
VC VBR
VR
IR
It
IR
It
VC
VBR
VR
V
UNI-directional
BI- directional
IPP
Parameters
Definition
VF
Forward Voltage drop for UNI-directional
VC
Clamping Voltage
Ipp
Surge Waveform 10/1000μs
VR
Stand-off Voltage
VBR
Breakdown Voltage
IR
Reverse Leakage Current
It
Test Current
Ppp
Peak Pulse Power Dissipation
Thermal Considerations
symbol
Parameter
Value
Unit
TJ
Operating Junction Temperature Range
-55 to +150
TS
Storage Temperature Range
-55 to +150
Environmental Characteristics
Testing Items
High Temperature Reverse Bias Test
High Temperature Life Test
High-low Temperature Cycle Test
High Temperature &High Humidity Test
Pressure Cooker Test
Resistance of Soldering Heat
Technical Standards
Temperature: 150±3℃, Bias=80%VDRM
Time:96H
Temperature: 150℃
Time:168H
Temperature: From -40℃ to125℃
Dwell time: 30min, 10-100 cycles
Temperature: 85℃Humidity:85%
Test time:168H
Temperature: 121℃, 2atm. Humidity:100%
Test time: 24H to 168H
Temperature: 260±5℃
Time of dip soldering: 10s, 3times
Note: The above testing items can be specified by customers by contacting Bencent service
3/5
www.bencent.com.cn
SMB 600W Series
Product Dimensions
REF.
mm
inch
A
1.85--2.15
0.073--0.085
B
3.45--3.75
0.138--0.148
C
4.35--4.65
0.171--0.183
D
2.10--2.60
0.083--0.102
E
0.15--0.25
0.006--0.010
F
0.80--1.50
0.031--0.059
G
0.00--0.40
0.000--0.016
H
4.95--5.45
0.195--0.215
REF
mm
inch
A
5.45
0.215
B
2.45
0.097
C
2.15
0.085
Recommended Soldering Pad
Reflow Profile
Pre Heat
Pb-Free Assembly
Temperature Min.
+150°C
Temperature Max.
+200°C
Time(Min to Max)
60 – 180 secs.
Average ramp up rate(Liquidus
Temp(TL) to peak)
TS(max) to TL - Ramp-up Rate
- Temperature (TL)
Reflow
(Liquidus)
- Temperature (TL)
Peak Temp (TP)
Time within 5°C of actual Peak Temp
(TP)
60 – 150 secs.
30 secs.
Time 25°C to peak Temp (TP)
8 min. Max.
Do not exceed
+260°C
TL
TS(max)
Ramp-down
Preheat
TS(min)
+(260+0/-5 )°C
6°C/sec. Max.
www.bencent.com.cn
TL
3°C/sec. Max.
+217°C
Critical Zone
TL to TP
Ramp-up
3°C/sec. Max.
Ramp-down Rate
4/5
TP
TP
Temperature
Reflow Condition
TS
TL
25
time to peak temperature
Time
SMB 600W Series
Package
5/5
Reel
Information
REF
mm
inch
A
3.8+/-0.3
0.150+/-0.012
B
5.5+/-0.3
0.217+/-0.012
d
1.5+/-0.1
0.059+/-0.004
D
330+/-1
13+/-0.039
D1
72+/-3
2.835+/-0.118
D2
13+/-0.3
0.512+/-0.012
E
1.75+/-0.2
0.069+/-0.008
F
5.5+/-0.02
0.217+/-0.008
P
8.0+/-0.2
0.315+/-0.008
P0
4.0+/-0.2
0.157+/-0.008
P1
2.0+/-0.2
0.079+/-0.008
W
12.0+/-0.2
0.472+/-0.008
W1
18+/-2.0
0.709+/-0.079
Outline
Reel
(pcs)
Per Carton
(pcs)
Reel Diameters
(mm)
Taping
3,000
24,000
330
www.bencent.com.cn
Carton Size(mm)
L
W
H
360
360
380
很抱歉,暂时无法提供与“BV-SMBJ6.5CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.49367
- 10+0.38168
- 30+0.32573
- 100+0.28372
- 国内价格
- 1+0.61490
- 200+0.39600
- 1500+0.34430
- 3000+0.30580
